Home » Newcomers » Newcomers » Classpath with Java
Classpath with Java [message #110116] Wed, 19 October 2005 12:09 Go to next message
Originally posted by: fa035530.skynet.be
I'm informed of your site by Gernot Schulz who gived me interess to
Eclipse.
I'm trying to setup the environment for a Java virtual Machine.(before)
I don't underestand why a i kept an error message.
I don't know if you can help me with this ? this come in pryority for me,
coz
I have a lot of applicatinos that I'd like to see running. I seted up
before but i forgot. I wrote this batch files to load classes en got this :
set
path=.;c:\windows\system32;c:\windows\system32\Wben;c:\Progr a~1\common\cc-res~1.000\build;c:\Progra~1\common\cc-res~1.00 0;c:\Progra~1\Java\jdk\bin;c:\Progra~1\Java\jre\bin;c:\Progr a~1\Java\source;c:\Progra~1\Java\jdk\netgraph\netgraph;c:\Pr ogra~1\common\common~1.011\web\web-inf\tlds;c:\Progra~1\comm on\common~1.011\web\web-inf;c:\Progra~1\common\common~1.011\ web\web-inf\classes;c:\Progra~1\common\common~1.011\common\s ource
set JAVA_HOME=C:\Progra~1\Java\jdk
set
CLASSPATH=.;%CLASSPATH%;c:\Progra~1\common\common~1.011\web\ WEB-INF\classes\log4j.properties;c:\Progra~1\common\common~1 .011\source\ApplicationResource_en.properties;c:\Progra~1\co mmon\cc-res~1.000\build\build.properties;C:\Progra~1\Java\jd k\jre\bin\client.jvm.dll;C:\Progra~1\Java\jdk\lib\rt.jar;C:\ Progra~1\Java\jdk\lib\javaws.jar;C:\Progra~1\Java\jdk\lib\to ols.jar;c:\Progra~1\Java\jdk\netgraph\netgraph\netgraph.jar
cd\
cd c:\Progra~1\common\cc-res~1.000
%comspec%
If I run Jview.exe , kept the message :
Class not registred, no virtual machine
The Java Virtual is not running ; How to make it go ??????????????
I use win xp.
Re: Classpath with Java [message #110143 is a reply to message #110116] Wed, 19 October 2005 12:51 Go to previous messageGo to next message
Originally posted by: beaner.yahoo.com
no
Re: Classpath with Java [message #110156 is a reply to message #110116] Wed, 19 October 2005 12:52 Go to previous messageGo to next message
1) You need to learn how to write and speak English in an accurate manner.
2) If you fail at Number 1), get out.
Re: Classpath with Java [message #110178 is a reply to message #110116] Wed, 19 October 2005 13:21 Go to previous messageGo to next message
> Eclipse.
> me, coz
> set
> set
> cd\
> %comspec%
> I use win xp.
Dear Frederic,
make sure u have administrator rights on ur windows, so u may install.
install java vm from http://java.sun.com/j2se/1.4.2/download.html
this should help.
If not, I would appreciate, helping u further.
kind regards
Astrid
Re: Classpath with Java [message #110191 is a reply to message #110156] Wed, 19 October 2005 13:25 Go to previous messageGo to next message
Dear beaner,
please, be friendly to other people.
kind regards.
Astrid
Re: Classpath with Java [message #110203 is a reply to message #110116] Wed, 19 October 2005 13:29 Go to previous messageGo to next message
I don't know if I can help much, but after the xenophobic responses I
saw, I thought I'd give it a try...
First, I know next to nothing about Jview except that when I run it on
my system, it is a Micro$oft "feature". The fact that I get it from
C:\WINNT\System32\ means that there is no such thing in the "normal"
JDKs. (I *always* have the JDK paths prior to the M$ ones to make sure I
get "real (TM) Java)"! :-)
So, looking at your path, it looks like you *used* to get Jview from M$
at C:\Windows\System32... which is now C:\WINNT\System32... (you
migrated from an older M$ OS to XP?) change the Windows in your path to
WINNTs and you might get back to your old behavior.
Now what this has to do with Eclipse I have not a clue... but I do know
it has even less to do with how well you do or do not speak English!
RDS
> Eclipse.
> me, coz
> set
> set
> cd\
> %comspec%
> I use win xp.
Re: Classpath with Java [message #110256 is a reply to message #110156] Wed, 19 October 2005 15:28 Go to previous messageGo to next message
1) You need to learn to exhibit respect, tolerance, and politeness.
3) Come to think of it, get out now and come back only if you succeed at
Number 1)
Eric
Re: Classpath with Java [message #110408 is a reply to message #110256] Thu, 20 October 2005 11:13 Go to previous messageGo to next message
Number 1)
Eric
Eric,
I don't know if you're from a foreign country or not, but we don't
need people like that around here. Look at all the things that happen b/c
people can't read or write English. You have foreigners driving on
Interstates and major highways and can't even read the signs, thus causing
accidents. So for you Eric:
1) I give respect to those that earn and deserve my respect, which you
don't fall into this category.
2) You don't EVER tell me what to do or what to say. I will gladly speak
my mind and acknowledge my rights.
3) If you try to take away these rights from me, there will be some
consequences, legal or physical. You pick.
Your great American pal,
Beaner
Re: Classpath with Java [message #110429 is a reply to message #110408] Thu, 20 October 2005 11:41 Go to previous messageGo to next message
> speak my mind and acknowledge my rights.
You tried to tell someone in 1) above what to say, or at least how to
say it, and you tried to tell someone in 2) above what to do.
Why do you have the right to do what you tell others not to do?
> Beaner
Are you saying "get out" as in out of America? I doubt they're in
America. Or are you saying to get out of eclipse.newcomer? I don't think
that's "yours". Sorry.
I'm still trying to learn the OSS process, as practiced in the Eclipse
community.... so... Eric, do you happen to know what the process is for
"dealing" with such conflicts and problems? I have my vote ready to go
in this manner if someone wants to initiate the process.
Everyone's pal (and in this community, who cares where I live or where
I'm from),
RDS
Re: Classpath with Java [message #110454 is a reply to message #110429] Thu, 20 October 2005 12:20 Go to previous messageGo to next message
I would like to ask for everyone's forgiveness. When I wrote these
things, I was heavily sedated by some pain killers, Percocets, and had
just watched a movie that got my feelings out of whack. Again, I
apologize and will refrain from doing such idiocies in the future.
Your pal,
Beaner
Re: Classpath with Java [message #110463 is a reply to message #110429] Thu, 20 October 2005 12:25 Go to previous messageGo to next message
Randy D. Smith wrote:
>> manner.
>> Beaner
> I'm from),
> RDS
Dear Randy,
we all know beaner is missbehaving. Just to prevent a useless flamewar,
we should ignore him. (Even though his behaviour is really disgusting)
Beaner should in fact not expect me (or so. else), to help him out with
any problem in the future, until he learns how to behave. >-(
I don't know whether there is a 'official' way to deal with this.
Deeply suffering from fear of having made any grammatical or spelling
mistakes :-D
king regards
Astrid
Astrid
Re: Classpath with Java [message #110475 is a reply to message #110454] Thu, 20 October 2005 12:28 Go to previous message
> Your pal,
> Beaner
accepted, so no combination of pain killers, watching movies AND
newsgrouping.
regards Astrid
Previous Topic:how do you add a double click listener to problems view pane?
Next Topic:Please Help: Confused - All I need is IDE to dev SOAP Web Services
Current Time: Mon Oct 27 07:27:30 EDT 2025
Powered by FUDForum. Page generated in 0.10566 seconds
