Home » Eclipse Projects » Linux Tools Project » Ecliipse causing Linux to run out of memory
Ecliipse causing Linux to run out of memory [message #10017] Tue, 09 June 2009 19:45 Go to next message
Hi all
I need to do some Qt development, and so have installed Eclipse Ganymede,
with the Qt Eclipse integration. My m/c has Fedora Core 9. When running
the IDE, my system runs out of memory after ~20 mins, and the IDE is
killed (I believe, by the OS). I'd be very grateful for any ideas on
what's causing this, and info on how to fix the problem.
P.S. I've done Qt work on my laptop w/ WinXP, no probs there. (my laptop
actually has lesser RAM!)
Re: Ecliipse causing Linux to run out of memory [message #10040 is a reply to message #10017] Wed, 10 June 2009 09:31 Go to previous message
What JVM are you running? You'll probably want to play with the
settings in eclipse.ini. It will be under your eclipse installation.
HTH,
Andrew
Re: Ecliipse causing Linux to run out of memory [message #566439 is a reply to message #10017] Wed, 10 June 2009 09:31 Go to previous message
HTH,
Andrew
Previous Topic:Ecliipse causing Linux to run out of memory
Next Topic:.cdtconfigure.Build file
Current Time: Fri May 09 17:57:01 EDT 2025
Powered by FUDForum. Page generated in 0.03375 seconds
