Home » Newcomers » Newcomers » a question about Eclipse---Linux (AMD 64/GTK 2)
a question about Eclipse---Linux (AMD 64/GTK 2) [message #10014] Thu, 20 January 2005 19:01 Go to next message
Originally posted by: pavlidisp.edu.biology.uoc.gr
Hi!
I'm new in Eclipse. I have an AMD 64, with suse 9.2 installed, and I have
installed java sdk 1.5.
I have downloaded eclipse, for AMD64 (Linux (AMD 64/GTK 2)), but when I
want to run it, I see the following message.
btw, when I run eclipse Linux (x86/GTK 2) it runs normally. Couldd you
help me with that problem?
Thanks in advance
!SESSION Jan 21, 2005 01:20:28.61
eclipse.buildId=M200409161125
java.version=1.4.2_05
BootLoader constants: OS=linux, ARCH=amd64, WS=gtk, NL=en_US
!ENTRY org.eclipse.osgi Jan 21, 2005 01:20:28.62
!MESSAGE Application error
!STACK 1
java.lang.UnsatisfiedLinkError:
/home/pavlos/programs/eclipse/eclipse/plugins/org.eclipse.sw t.gtk64_3.0.1/os/linux/amd64/libswt-pi-gtk-3063.so:
cannot open shared object file: No such file or directory
at java.lang.ClassLoader$NativeLibrary.load(Native Method)
at java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1586)
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1495)
at java.lang.Runtime.loadLibrary0(Runtime.java:788)
at java.lang.System.loadLibrary(System.java:834)
at org.eclipse.swt.internal.Library.loadLibrary(Library.java:10 0)
at org.eclipse.swt.internal.gtk.OS.<clinit>(OS.java:19)
at org.eclipse.swt.internal.Converter.wcsToMbcs(Converter.java: 63)
at org.eclipse.swt.internal.Converter.wcsToMbcs(Converter.java: 54)
at org.eclipse.swt.widgets.Display.<clinit>(Display.java:118)
at org.eclipse.ui.internal.Workbench.createDisplay(Workbench.ja va:268)
at org.eclipse.ui.PlatformUI.createDisplay(PlatformUI.java:153)
org.eclipse.ui.internal.ide.IDEApplication.createDisplay(IDE Application.java:122)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:72)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:704)
at org.eclipse.core.launcher.Main.main(Main.java:688)
Re: a question about Eclipse---Linux (AMD 64/GTK 2) [message #10061 is a reply to message #10014] Thu, 20 January 2005 20:00 Go to previous message
Ok, I discovered the solution... :-))
The answer is after the question "Error, can not start eclipse" of Michael
Wang.
Pavlos wrote:
> Hi!
> Thanks in advance
> !STACK 1
> at
> at
> at
> at
> at
> at
Previous Topic:Error, can not start eclipse
Next Topic:Include RMI Stubs in Eclipse generated JAR
Current Time: Sat Jul 26 08:29:01 EDT 2025
Powered by FUDForum. Page generated in 0.24847 seconds
