Home » Language IDEs » C / C++ IDE (CDT) » Slow Console When Building
Slow Console When Building [message #109834] Thu, 08 July 2004 11:32 Go to next message
Originally posted by: rolf.finecode.de-nospamremove.me
I've CDT 2.0 running with Eclipse 3.0 on WinXP.
I have an external cmd (batch)-File which performs the build
(Project/Properties/C/C++ Make Project/Build command). The ouput is
captured by the console view. But, it's very slow. Every half second there
is a rush of about 1000 chars coming in, and then a half second nothing
agian, repeating this behaviour until all the output was captured. This
slows down the entire build process dramatically.
You can verify with a cmd-script which does:
dir
dir
dir
Any ideas, guys?
Daniel
dipl.-inf. cand.-phys. Daniel Rolf
finecode software / www.finecode.de
Re: Slow Console When Building [message #109931 is a reply to message #109834] Fri, 09 July 2004 03:06 Go to previous messageGo to next message
Originally posted by: johan.nosp.m.appeal.se
The Bugzilla is your friend. Search for "console slow build" and you find:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=67718
//Johan
Daniel Rolf wrote:
> dir
> dir
> dir
> Any ideas, guys?
> Daniel
Re: Slow Console When Building [message #109942 is a reply to message #109931] Fri, 09 July 2004 07:06 Go to previous messageGo to next message
I see. How can I obtain a fixed version?
Daniel
"Johan Walles" <johan.nosp@m.appeal.se> schrieb im Newsbeitrag
news:cclg4i$ime$1@eclipse.org...
find:
> //Johan
> Daniel Rolf wrote:
> > Hi,
there
> > dir
> > dir
> > dir
> > Any ideas, guys?
> > Daniel
Re: Slow Console When Building [message #109949 is a reply to message #109942] Fri, 09 July 2004 07:40 Go to previous messageGo to next message
As I said, the Bugzilla is your friend.
If you'd read the last two comments (at the bottom of
"https://bugs.eclipse.org/bugs/show_bug.cgi?id=67718") you'd have seen:
I'm not yet comfortable enough with these changes to put them in 2.0,
so I'm changing the target milestone to 2.0.1
and
fix commited to both head and 2.0 branch.
This means you can either download the CVS version of the 2.0 CDT stream and
build it yourself or wait for 2.0.1 to be released.
//Johan
> Daniel
Re: Slow Console When Building [message #110508 is a reply to message #109949] Tue, 13 July 2004 12:59 Go to previous messageGo to next message
I obtained the CommandLauncher from the CVS and replace the one in the
eclipse\plugins\org.eclipse.cdt.core_2.0.0\cdtcore.jar with the compiled
class.
The problem still persists. Nothing seemed to have changed.
bye
Daniel
news:ccm06l$fa5$1@eclipse.org...
> and
> and build it yourself or wait for 2.0.1 to be released.
> //Johan
>> Daniel
Re: Slow Console When Building [message #110520 is a reply to message #110508] Tue, 13 July 2004 15:02 Go to previous messageGo to next message
In addition to the CommandLauncher, the fix for that bug also changed
org.eclipse.cdt.ui/src/org/eclipse/cdt/internal/ui/buildcons ole/BuildConsole
Partitioner.java
-Andrew
"Daniel Rolf" <rolf@finecode.de-nospamremove.me> wrote in message
news:cd14b6$av8$1@eclipse.org...
> class.
> bye
> Daniel
> > and
> > //Johan
> >> Daniel
Re: Slow Console When Building [message #110532 is a reply to message #110520] Tue, 13 July 2004 15:39 Go to previous messageGo to next message
Same problem.
I traced a little bit and found the following:
- CommandLauncher: inputPipe.available is more or less exactly once a second
1024 bytes which equals to PipedInputStream.PIPE_SIZE on my jdk j2sdk1.4.2
- ProcessClosure.ReaderThread: the writer.flush method sometimes needs one
second to complete. It seems like that, if the pipe is full, this threads
waits one second because it's not signaled that the pipe was drained. Yet, I
looked in the JDK-source-code, and they're doing a good job using wait /
notify stuff. I don't know what's wrong.
Daniel
"Andrew Niefer" <aniefer@ca.ibm.com> schrieb im Newsbeitrag
news:cd1bel$nq1$1@eclipse.org...
> Partitioner.java
> -Andrew
>> class.
>> bye
>> Daniel
>> > and
>> > stream
>> > //Johan
>> >> Daniel
Re: Slow Console When Building [message #110543 is a reply to message #110532] Tue, 13 July 2004 15:54 Go to previous messageGo to next message
Yes, it's really a bug in the j2sdk1.4.2:
There is a wait(1000) in the PipedInputStream.receive, when the pipe is
full.
But, the PipedInputStream.read doesn't call notifyAll after it removed data
to resume the writer thread.
What now?
bye
Daniel
"Daniel Rolf" <rolf@finecode.de-nospamremove.me> schrieb im Newsbeitrag
news:cd1dnj$rvt$1@eclipse.org...
> Same problem.
> second 1024 bytes which equals to PipedInputStream.PIPE_SIZE on my jdk
> j2sdk1.4.2
> I looked in the JDK-source-code, and they're doing a good job using wait /
> Daniel
>> Partitioner.java
>> -Andrew
>>> class.
>>> bye
>>> Daniel
>>> > seen:
>>> > and
>>> > stream
>>> > //Johan
>>> >> Daniel
Re: Slow Console When Building [message #110566 is a reply to message #110543] Tue, 13 July 2004 17:05 Go to previous messageGo to next message
You could try changing the command launcher to use a bigger pipe. Check out
the BiggerPipedInputStream at
http://www.cafeaulait.org/books/javaio/errata/08.html as an example. I
thought this was a bit of a hack and responsible flushing seemed to fix the
problem for me which is why I didn't make that change.
-Andrew
news:cd1ej6$t8c$1@eclipse.org...
> full.
data
> What now?
> bye
> Daniel
> > Same problem.
> > j2sdk1.4.2
one
threads
Yet,
> > Daniel
> >> Partitioner.java
> >> -Andrew
compiled
> >>> class.
> >>> bye
> >>> Daniel
> >>> > seen:
2.0,
> >>> > and
> >>> > stream
> >>> > //Johan
> >>> >> Daniel
Re: Slow Console When Building [message #110690 is a reply to message #110566] Wed, 14 July 2004 12:51 Go to previous message
I filed the bug to Sun. But, should we not provide a general solution, maybe
we roll our own PipedInputStream. Because, Sun is not likely to fix this bug
very soon... After all, the impl. has not changed since V1.32 January 2003.
Moreover, the Sun-JDK is quite commonly used. Can you check your JDK for the
bug (or mail me the source file)? I looked at the Kaffee-VM, it looks
better, but not very efficient...
A simple workaround is to derive from PipedInputStream, to override "read"
and to call notifyAll after calling "super.read".
bye
Daniel
news:cd1ikr$48b$1@eclipse.org...
> out
> the
> -Andrew
>> full.
> data
>> What now?
>> bye
>> Daniel
>> > Same problem.
>> > j2sdk1.4.2
> one
> threads
> Yet,
>> > wait
>> > Daniel
>> >> Partitioner.java
>> >> -Andrew
>> >>> the
> compiled
>> >>> class.
>> >>> bye
>> >>> Daniel
>> >>> > seen:
> 2.0,
>> >>> > and
>> >>> > stream
>> >>> > //Johan
>> >>> >> Daniel
Previous Topic:How to log debugger output
Next Topic:Debugging with CDT problem, newbie question
Current Time: Sun Aug 31 13:34:23 EDT 2025
Powered by FUDForum. Page generated in 0.05376 seconds
