Home » Newcomers » Newcomers » Spring Framework plug in not installing
Spring Framework plug in not installing [message #9988] Thu, 20 January 2005 12:45 Go to next message
Originally posted by: gerwyn.lineone.net
I am trying to get the spring framework plugin installed
I go to install new features I set up Spring ide to be
http://springframework.sourceforge.net/spring-ide/eclipse/up datesite/
It connects and gives me 2 check boxes for Spring Framework and Spring
IDE. I select these click next and get nothing.
Can anyone help on how i can get this plugin to work.
Cheers
Reservoirduck
Re: Spring Framework plug in not installing [message #11309 is a reply to message #9988] Fri, 21 January 2005 10:12 Go to previous messageGo to next message
Originally posted by: Chris_Laffra.ca.ibm.com
I just tried, and the update wizard said this:
"Spring IDE - Beans Configuration Support (1.0.3) requires plug-in
"org.eclipse.gef"."
when I selected the Spring IDE.
Do you have GEF installed? What version of Eclipse are you using?
Chris Laffra, http://eclipsefaq.org
"reservoirduck" <gerwyn@lineone.net> wrote in message
news:csoqn8$age$1@www.eclipse.org...
> Cheers
> Reservoirduck
Re: Spring Framework plug in not installing [message #19557 is a reply to message #11309] Fri, 28 January 2005 07:37 Go to previous message
I have installed gef I am using eclipse 3.0.1 and the version of gef is
3.0.1 as well, however I still can't see the spring features.
reservoiduck
> "org.eclipse.gef"."
Previous Topic:Using CDT to Develop OpenGL and Glut
Next Topic:Eclipse based ( RCP ) product not picking up the plugins
Current Time: Fri Jul 18 05:50:07 EDT 2025
Powered by FUDForum. Page generated in 0.09447 seconds
