Home » Eclipse Projects » Eclipse Platform » Adding new "Default" editor choice
Adding new "Default" editor choice [message #109667] Mon, 11 August 2003 11:18 Go to next message
I wanted to know how to add an editor to the Navigator's list of editor
choices for a resource with a specific extension.
So, for example, for ".xml" resources (files), in addition "Text Editor" and
"Default Editor", I would like to add "Mike's editor".
I do not want my editor to ever (or not necessarily) be the default choice
for the resource.
Thanks -
Michael Blout
Re: Adding new "Default" editor choice [message #109685 is a reply to message #109667] Mon, 11 August 2003 11:31 Go to previous messageGo to next message
Originally posted by: richkulp.NOSPAM.us.ibm.com
Look up in the help under Platform Plug-in Developers
Guide->Reference->Extension Points
Reference->workbench->org.eclipse.ui.editors
Rich
Re: Adding new "Default" editor choice [message #110069 is a reply to message #109685] Mon, 11 August 2003 17:44 Go to previous messageGo to next message
Thank you.
I forgot to mention.....
The behavior I see is that, if I create an editor which defines
extensions="xml"
default="false"
and no other editor is registered for that extension, then my editor acts as
if it is the 'default'.
What I would like is to see my editor listed under the divider in the menu
for choosing the editor, much like Text, Default, and System Editor do.
And ideally, I would never be the choice if the user double-clicked; the
user would always have to explicitly pick me from the menu.
I hope I'm not just missing something obvious in the help!
Thanks again -
Michael Blout
"Richard L. Kulp" <richkulp@NOSPAM.us.ibm.com> wrote in message
news:bh8cmp$q5q$1@eclipse.org...
> Rich
Re: Adding new "Default" editor choice [message #110095 is a reply to message #110069] Mon, 11 August 2003 17:53 Go to previous message
That isn't possible with the api. As long as an editor is supplied in
the plugin xml for an extension, there will be a default editor. If you
happen to be the only one, you will be the default.
Below the line is hard-code in Eclipse.
Rich
Previous Topic:Java build path - "require plug-in entries"
Next Topic:event when the eclipse window is activated?
Current Time: Sun Jul 27 01:41:34 EDT 2025
Powered by FUDForum. Page generated in 0.47551 seconds
