Can't install Linux Tools [message #9971] |
Tue, 09 June 2009 12:06  |
Hi, guys!
I try to install Linux tools from archive I downloaded from the internet.
I instruct Eclipse update manager with the location of the archive and
then start the installation process but I get error. I decided to install
autotools for starters but for some reason update manager thinks that some
other plugin that autotools relies on is missing. Error message is this:
Cannot complete the install because one or more required items could not
be found.
Software being installed: Autotools Feature (Incubation)
1.0.3.200905251648
(org.eclipse.linuxtools.cdt.autotools.feature.feature.group
1.0.3.200905251648)
Missing requirement: Autotools Feature (Incubation) 1.0.3.200905251648
1.0.3.200905251648) requires 'org.eclipse.cdt.make.core [5.0.0,6.0.0)' but
it could not be found
I looked at the list of installed plugins and it says that it has:
org.eclipse.cdt.make.core (6.0.0.200905061052) "C/C++ Standard make Build
Core" [Active]
Is there any way to manually override this?
I have Eclipse 3.5RC3 and CDT 6.0 (installed from latest CDT 6.0 master
archive!) on my computer.
Re: Can't install Linux Tools [message #481527 is a reply to message #479867] |
Fri, 21 August 2009 08:07   |
Andrew Overholt wrote:
> We're readying our 0.3 release with a plan of releasing it one week from
> day (the 19th of August). If you want to try it now, with an Eclipse
> SDK 3.5, use this update site:
> http://download.eclipse.org/technology/linuxtools/updates-ni ghtly
> If you can't use the update site, you can grab a zip of the latest build
> from here:
> https://build.eclipse.org/hudson/job/cbi-linuxtools-Galileo/ lastSuccessfulBuild/artifact/
> Click on build/<the directory with the big name including 200908something>
> Download linuxtools-Update-incubation-<same big date-string as above>.zip
> Use it as an archive as you've tried with the update manager
> The URI will indeed look funny with the jar and the ! but it is correct
> Please let us know if it doesn't work.
> Thanks and sorry for the delay,
> Andrew
I downloaded the zip, and extracted it in the dropins folder, but
eclipse does not seem to detect it...
dropins/
linuxtools/
eclipse/
<plugins> contents
<features> contents
where am I going wrong?
thanks in advance
Lorenzo
Lorenzo Bettini, PhD in Computer Science, DI, Univ. Torino
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
Re: Can't install Linux Tools [message #494404 is a reply to message #481527] |
Fri, 30 October 2009 10:33  |
Dropins isn't the best way to install things, but I suggest you ask the p2 team as they are experts in this area. i suggest using the UI to install from our update site or from a zip.
Re: Can't install Linux Tools [message #566405 is a reply to message #9971] |
Tue, 09 June 2009 17:18  |
> master archive!) on my computer.
Our update site is for Ganymede (CDT 5) dependencies. You can install
from a zip of our Galileo builds instead. Grab the latest one here:
After adding the zip as an archive in the update dialog, if you see
nothing listed in main pane it's because we have no categories.
Un-check the "group by categories" option at the bottom.
Our forth-coming (July) 0.3 release will target Galileo.
HTH,
Andrew
Re: Can't install Linux Tools [message #566867 is a reply to message #9994] |
Fri, 07 August 2009 04:30  |
Hi.
I download the latest Galileo build as archive.zip. In Eclipse 3.5 I go
to Preferences/"Install/Update"/Available Software Sites and click Add.
I then click "Archive..." and selects the archive.zip file I downloaded.
The site is added with the following URL:
jar:file:/home/micke/dev/galileo/update-sites/linux-tools/ar chive.zip!/
The URL looks exactly like this. It looks a bit strange to me. Is this
correct?
When I try to install anything from this site in the install dialog I
get an error saying "No repository found at
jar:file:/home/micke/dev/galileo/update-sites/linux-tools/ar chive.zip!/. "
What am I doing wrong?
Regards, Micke.
> HTH,
> Andrew
Re: Can't install Linux Tools [message #566915 is a reply to message #566884] |
> from here:
> Andrew
dropins/
linuxtools/
eclipse/
<plugins> contents
<features> contents
thanks in advance
Lorenzo
Re: Can't install Linux Tools [message #567364 is a reply to message #481527] |
FUDForum. Page generated in 0.05264 seconds
