Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » Store Resource does not allow editing properties with EMF generated property editor
Store Resource does not allow editing properties with EMF generated property editor [message #109499] |
Wed, 30 January 2008 05:09  |
Hi!
After having solved the dependency problems with the plugins required by
Teneo, I'm now running into an odd quirk of the JPOXResource implementation
(though it could be EMF itself too). If I store the .ejdo within the plugin
and open the EMF editor using the URL I get from:
FileLocator.find(Activator.getDefault().getBundle(), new
Path("ejdo/masterDataEditor.ejdo"), null);
(bundleentry://65/ejdo/masterDataEditor.ejdo), the Property editor does not
allow any modifications. If however, I create the editor using a 'file:/'
based URL (file://home/fhackenberger/Desktop/masterDataEditor.ejdo), the
EMF property editor works as expected.
The code for the creation of the editor looks as follows:
final Properties props = readPropFile(file);
JpoxUtil.getCreateDataStore(props);
// now use the editor props to find the correct editor
final String editorextension =
doTrim(props.getProperty(Constants.PROP_EDITOR_EXTENSTION));
final String editorid = doTrim(props.getProperty(Constants.PROP_EDITOR_ID));
final String foundEditorID = getEditorID(editorid, editorextension);
// and open it
// property editor works with: page.openEditor(new
// URIEditorInput(URI.createURI(
// "file://home/fhackenberger/Desktop/masterDataEditor.ejdo")),
// foundEditorID);
//property editor does not work with:
page.openEditor(new URIEditorInput(URI.createURI(file.toString())),
foundEditorID);
I had a look at the Teneo source code, but was unable to find anything
related to read-only resources. Could someone knowledgeable please
elaborate?
Florian
Florian Hackenberger
Re: Store Resource does not allow editing properties with EMF generated property editor [message #109537 is a reply to message #109499] |
Wed, 30 January 2008 05:23   |
Florian,
Have a look at AdapterFactoryEditingDomain's isReadOnly methods. You
might need to specialize it. I definitely wouldn't expect a bundleentry
URI to be writeable since such a URI implies its a resource in the
installed environment.
DI Florian Hackenberger wrote:
> Hi!
> // and open it
> // foundEditorID);
> foundEditorID);
> elaborate?
> Cheers,
> Florian
Re: Store Resource does not allow editing properties with EMF generated property editor [message #112630 is a reply to message #109537] |
Tue, 19 February 2008 04:59   |
Just for documentation purposes. This can be solved by creating a class
similar to this one:
/** This class ensures that a resource created from an .ejdo is writeable.
* @author Florian Hackenberger (florian.hackenberger@acoveo.com)
public class CustomAdapterFactoryEditingDomain extends
AdapterFactoryEditingDomain {
public CustomAdapterFactoryEditingDomain(AdapterFactory adapterFactory,
CommandStack commandStack,
Map<Resource, Boolean> resourceToReadOnlyMap) {
super(adapterFactory, commandStack, resourceToReadOnlyMap);
protected boolean isReadOnlyURI(URI uri) {
boolean defaultReadOnly = super.isReadOnlyURI(uri);
if (defaultReadOnly == true
&& uri.fileExtension().compareTo(JpoxConstants.EJDO_EXTENSION) == 0) {
return false;
} else {
return defaultReadOnly;
And using an instance of this class as the editingDomain in the
initializeEditingDomain() method of the EMF generated XXXEditor class:
protected void initializeEditingDomain() {
editingDomain = new CustomAdapterFactoryEditingDomain(adapterFactory,
commandStack, new HashMap<Resource, Boolean>());
Florian
Re: Store Resource does not allow editing properties with EMF generated property editor [message #112706 is a reply to message #112630] |
Wed, 20 February 2008 10:46   |
Hi Florian,
Thanks for the update! Can I ask one (more) favor, can you enter a bugzilla for this and post the
code below in the bugzilla? Then I can add it to the documentation.
gr. Martin
> @Override
> return false;
> } else {
> Cheers,
> Florian
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Store Resource does not allow editing properties with EMF generated property editor [message #614230 is a reply to message #109499] |
Florian,
> Hi!
> // and open it
> // foundEditorID);
> foundEditorID);
> elaborate?
> Cheers,
> Florian
Re: Store Resource does not allow editing properties with EMF generated property editor [message #615514 is a reply to message #109537] |
return false;
} else {
Florian
Re: Store Resource does not allow editing properties with EMF generated property editor [message #615520 is a reply to message #112630] |
Hi Florian,
gr. Martin
> @Override
> return false;
> } else {
> Cheers,
> Florian
The Netherlands
Current Time: Sun Aug 31 13:28:18 EDT 2025
Powered by FUDForum. Page generated in 0.07674 seconds
