Can't see source using remote debugger [message #9958] |
Wed, 30 April 2003 15:05  |
Originally posted by: jake_kugel.yahoo.com
I'm using Eclipse 2.0, and connecting the debugger to a remote JVM. I
recently moved from Win 2000 to Win XP. I copied my workspace,
reinstalled Eclipse, and tried to use the remote debugger again. The
debugger seems to attach ok, and it will stop when breakpoints are hit,
but the source where the breakpoint is at doesn't get displayed. In the
metadata/.log file, I see this exception when attaching to the remote JVM
(see end of the note). The remote JVM is IBM JRE 1.4, but it had worked
before on Win 2000. Has anyone seen anything like this?
Jake
!SESSION Apr 30, 2003 11:34:14.136
java.fullversion=J2RE 1.3.1 IBM Windows 32 build cn131-20020710 (JIT
enabled: jitc)
Command-line arguments: -os win32 -ws win32 -arch x86 -data C:\WSWB
-install file:C:/Program Files/IBM/CSA/VisualBuilder/eclipse/
!ENTRY org.eclipse.ui 4 4 Apr 30, 2003 11:34:14.136
!MESSAGE Unhandled exception caught in event loop.
!ENTRY org.eclipse.ui 4 0 Apr 30, 2003 11:34:14.136
!MESSAGE java.lang.NullPointerException
!STACK 0
org.eclipse.jdt.launching.sourcelookup.JavaSourceLocator.get SourceLocations(JavaSourceLocator.java:366)
org.eclipse.jdt.launching.sourcelookup.JavaSourceLocator.ini tializeDefaults(JavaSourceLocator.java:284)
org.eclipse.jdt.debug.ui.JavaUISourceLocator.initializeDefau lts(JavaUISourceLocator.java:248)
org.eclipse.debug.internal.core.LaunchConfiguration.initiali zeSourceLocator(LaunchConfiguration.java:165)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:147)
org.eclipse.debug.internal.ui.actions.RelaunchActionDelegate .relaunch(RelaunchActionDelegate.java:56)
org.eclipse.debug.internal.ui.actions.RelaunchActionDelegate .relaunch(RelaunchActionDelegate.java:32)
org.eclipse.debug.internal.ui.actions.RelaunchHistoryLaunchA ction$1.run(RelaunchHistoryLaunchAction.java:59)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:66)
org.eclipse.debug.internal.ui.actions.RelaunchHistoryLaunchA ction.run(RelaunchHistoryLaunchAction.java:57)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:749 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:407)
org.eclipse.jface.action.ActionContributionItem$ActionListen er.handleEvent(ActionContributionItem.java(Compiled
Code))
Code))
Code))
org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va(Compiled
Code))
Code))
Code))
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java (Compiled
Code))
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a(Compiled
Code))
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1239)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:775)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:462)
at java.lang.reflect.Method.invoke(Native Method)
at org.eclipse.core.launcher.Main.basicRun(Main.java:247)
at org.eclipse.core.launcher.Main.run(Main.java:703)
at org.eclipse.core.launcher.Main.main(Main.java:539)
Re: Can't see source using remote debugger [message #10007 is a reply to message #9958] |
Wed, 30 April 2003 15:18   |
Looks like https://bugs.eclipse.org/bugs/show_bug.cgi?id=26648
Please read the details in the bug report to be sure.
This is fixed in 2.1
HTH
Darins
"Jake Kugel" <jake_kugel@yahoo.com> wrote in message
news:b8p6q5$ilu$1@rogue.oti.com...
> Jake
> enabled: jitc)
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> !STACK 0
> at
> at
> at
Locator.java:248)
> at
> at
on.java:147)
> at
> at
> at
> at
> at
> at
> Code))
> at
> Code))
> at
> Code))
> at
> Code))
> at
> Code))
> at
> Code))
> Code))
> Code))
> at
a:775)
Re: Can't see source using remote debugger [message #10849 is a reply to message #10007] |
Wed, 30 April 2003 21:23  |
That was the problem. I had unchecked the 'Use default classpath' checkbox
in the launch configuration and the classpath didn't match what was in the
project. Thanks,
Jake
> HTH
> Darins
> > Thanks,
> > Jake
> > enabled: jitc)
> > !STACK 0
> > at
> > at
> > at
> Locator.java:248)
> > at
> > at
> on.java:147)
> > at
> > at
> > at
> > at
> > at
> > at
> > Code))
> > at
> > Code))
> > at
> > Code))
> > at
> > Code))
> > at
> > Code))
> > at
> > Code))
> > Code))
> > Code))
> > at
> a:775)
FUDForum. Page generated in 0.02992 seconds
