Home » Modeling » BPEL Designer » Use relative queries instead of absolute queries in XPath expressions ?
Use relative queries instead of absolute queries in XPath expressions ? [message #9951] Tue, 23 October 2007 05:28
I have a problem with the BPEL designer.
I just created a new BPEL process (synchronous process template). I want
to assign the content of the input message to the output message.
I create an Assign action, and a new Copy.
When I choose "input -> payload -> input" (variable / part / element) in
the from part of the copy, the designer generates an XPath query
"/tns:input".
I wonder why an absolute query is created there instead of a relative
query.
I think the context node in BPEL for XPath queries is the message part.
If the query is an absolute query ("/tns:input") the node is searched from
the document root (the message) and so the node "input" is not found.
If the query is relative ("tns:input"), the node is searched from the node
context.
I think this is shown in the examples of the section 8.2.6 of the BPEL
spec .
Is there a bug in the designer or did I misunderstand something in the
spec ?
Guillaume Porcher
Previous Topic:stand alone running bpel-designer
Next Topic:generating java code from BPEL file using oAW
Current Time: Fri May 09 18:07:37 EDT 2025
Powered by FUDForum. Page generated in 0.03685 seconds
