Server Startup Error using Lomboz w/Eclipse Tomcat 5 [message #9939] |
Thu, 20 January 2005 11:15 |
Trying to start the Tomcat 5.0.28 server using Lomboz 3.0.1\eclipse 3.0.1
for j2EE servlet testing. Outside of Eclipse/Lomboz Tomcat Server comes
up fine and executes servlets as desired... Unable to get Lomboz to run
Tomcat 5 Server only without startup error... No further indication in
either Tomcat/Eclipse error logs... No sure what is wrong as Tomcat works
fine when started outside eclipse/lomboz??? Appears to be in last steps of
Tomcat startup when fails...
Eclipse Console posts the following:
Jan 20, 2005 10:51:39 AM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 1212 ms
Jan 20, 2005 10:51:39 AM org.apache.catalina.core.StandardService start
INFO: Starting service Apache-Tomcat Container
Jan 20, 2005 10:51:39 AM org.apache.catalina.core.StandardEngine start
INFO: Starting Servlet Engine: Apache Tomcat/5.0.28
Jan 20, 2005 10:51:40 AM org.apache.catalina.core.StandardHost start
INFO: XML validation disabled
Jan 20, 2005 10:51:40 AM org.apache.catalina.core.StandardHost getDeployer
INFO: Create Host deployer for direct deployment ( non-jmx )
Jan 20, 2005 10:51:40 AM org.apache.catalina.core.StandardHostDeployer
install
INFO: Installing web application at context path /cmplus from URL
file:C:/tomcat/webapps/cmplus
Jan 20, 2005 10:51:41 AM org.apache.catalina.core.StandardHostDeployer
install
INFO: Installing web application at context path /myweb from URL
file:C:/tomcat/webapps/myweb
install
INFO: Installing web application at context path /balancer from URL
file:C:\tomcat\webapps\balancer
install
INFO: Installing web application at context path /CactusTest from URL
file:C:\tomcat\webapps\CactusTest
Jan 20, 2005 10:51:41 AM org.apache.catalina.loader.WebappClassLoader
validateJarFile
INFO:
validateJarFile(C:\tomcat\webapps\CactusTest\WEB-INF\lib\ser vletapi-2.3.jar)
- jar not loaded. See Servlet Spec 2.3, section 9.7.2. Offending class:
javax/servlet/Servlet.class
install
INFO: Installing web application at context path /examples from URL
file:C:\tomcat\webapps\examples
Jan 20, 2005 10:51:42 AM org.apache.catalina.core.StandardHostDeployer
install
INFO: Installing web application at context path /jsp-examples from URL
file:C:\tomcat\webapps\jsp-examples
install
INFO: Installing web application at context path from URL
file:C:\tomcat\webapps\ROOT
install
INFO: Installing web application at context path /servlets-examples from
URL file:C:\tomcat\webapps\servlets-examples
install
INFO: Installing web application at context path /tomcat-docs from URL
file:C:\tomcat\webapps\tomcat-docs
install
INFO: Installing web application at context path /webdav from URL
file:C:\tomcat\webapps\webdav
java.lang.reflect.InvocationTargetException
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:2 87)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:42 5)
Caused by: java.lang.NoSuchFieldError: oname
at org.apache.jk.server.JkCoyoteHandler.start(JkCoyoteHandler.j ava:185)
org.apache.coyote.tomcat5.CoyoteConnector.start(CoyoteConnec tor.java:1527)
org.apache.catalina.core.StandardService.start(StandardServi ce.java:489)
at org.apache.catalina.core.StandardServer.start(StandardServer .java:2313)
at org.apache.catalina.startup.Catalina.start(Catalina.java:556 )
... 6 more
Any further insight as to a resolution much appreciated...
FUDForum. Page generated in 0.06812 seconds
