Home » Archived » IMP » Regarding the IMP project!
Regarding the IMP project! [message #9937] Tue, 16 October 2007 07:14 Go to next message
Originally posted by: hiteshn.mail.gmail.com
Hi All,
I'm new to the news group as well as with the IMP project. I have gone
through the steps given in
http://eclipse-imp.sourceforge.net/documentation/users_guide .html but still
few things aren't clear as:
1) I cannot find "File" -> "New" -> "IDE Language Support" -> "Parser
Services" -> "LPG Grammar and Parser for UIDE"
instead I get "File" -> "New" -> "IDE Language Support" -> "LPG" ->
"New LPG Grammar with Parser Wrapper".
Are these options the same thing?
2)When I proceed further using the option "New LPG Grammar with Parser
Wrapper", the package of AST remains empty (no classes/interfaces are
generated in it) and due to this I get errors in other packages...
Finally, I want to know in more clear terms how to test it after successful
completion of all the steps? (I did not understand the same in user guide)
Thanks for your co-operation!
Hitesh...
Answers to questions on the IMP project [message #9984 is a reply to message #9937] Tue, 16 October 2007 15:55 Go to previous messageGo to next message
Hitesh Nembhwani wrote:
> Hi All,
Yes, these are the same thing. This is a case where the documentation
is lagging behind our recent changes to other parts of the system.
Thanks for pointing this out.
I can't say about this without more information. The LPG builder should
run automatically when you generate the grammar files using this wizard
(or later modify one of these files).
Are you running in a level 1 workspace? Is the LPG Runtime feature
installed? (This feature contains the LPG builder. Current version is
2.0.6, I believe.) Is the LPG builder running at all? Are there new
Java classes generated in the parser package? (E.g., for a language
"Lang", there should be "LangLexer.java", "LangParser.java", and other
lexer- and parser-related classes). Do you see any exception traces in
the console window or get any error messages in the Error Log view?
This is a good question--we need some documentation about this. You can
run through all of the steps (or a subset of them) and get a working IDE
for our example language without doing any other work. This is what we
do when we give an IMP demo.
The grammar templates that are generated by the "New LPG Grammar with
Parser Wrapper" contain grammar rules for an example language, "LEG" (or
"leg")--anyway, that's what we call it (for "Little Expression
Grammar"), although you can name it anything.
The skeleton implementations that are generated for the other services
all contain working example implementations that are based on the
example grammar. Each time you add a language service you should be
able to restart the IDE being developed and see that service working on
programs in the example language.
To run your new IDE, you need to run a level 2 workspace, that is, a
runtime workbench starting from the development workspace in which you
are building the IDE. The IDE should function automatically within the
level 2 workspace when you are working on programs in your new language
(just as the JDT operates automatically on Java programs).
We recommend creating a Java project for developing programs in your new
language and seeing how your new IDE works. In the "src" folder of the
Java project, create a file in the new language. (I'll post an example
separately in this newsgroup.) In order to be recognized by the new
IDE, source programs in the new language must be given the filename
extension that was specified in the "Programming language descriptor"
wizard (we use "leg" for our example LEG-language extension). When you
open a file with the appropriate filename extension, it should appear
automatically in the editor of the new IDE. Depending on what other
services have been instantiated in the IDE, you may see an outline view,
syntax highlighting, source folding, and so on.
You don't have to follow the whole IDE development process to the end.
You can rerun the IDE each time you add a new service. The IDE actually
becomes operational as soon as the parser is defined. If you run the
IDE then, you should see little more than a basic Eclipse text editor,
but it should already have integrated parsing--in other words, you
should see annotations for syntax errors. When we give the IMP demo, we
then usually add syntax highlighting (token coloring), outlining, and
source text viewing, and rerun the IDE after that.
This all works with the example LEG language and the example
implementations for the various services. We think this grammar and
these service implementations are fairly typical, but each language and
IDE will be different. You may be able to start developing your own
language and IDE by adapting the IMP LEG examples, or you may want to
remove all of our example code and write your own grammar and servie
implementations from scratch.
> Hitesh...
Thanks for the good questions!
Stan Sutton
Re: Answers to questions on the IMP project [message #12251 is a reply to message #9984] Wed, 17 October 2007 14:10 Go to previous messageGo to next message
Hi Stanley,
Yes, LPG Runtime feature is installed, version 2.0.8.
I created a plug-in project named "Sample". When I used the option "New LPG
Grammar with Parser Wrapper", two packages,
(1) sample.imp.parser
(2) sample.imp.parser.AST are created.
Package 1 has following files:
SampleASTNodeLocator.java
SampleParseController.java
SampleParser.java
SampleKWLexer.gi
SampleLexer.gi
SampleLexer.l
SampleParser.g
SampleParser.l
But package 2 is completely empty... (no classe/interfaces in it) and
because of this I get errors in SampleASTNodeLocator & SampleParseController
files saying "ASTNode cannot be resolved to a type".
The SampleASTNodeLocator & SampleParseController files use "import
sample.imp.parser.Ast.ASTNode"...
Also, how do I check if LPG builder is running or not?
Hitesh...
"Stanley Sutton" <suttons@us.ibm.com> wrote in message
news:ff34v5$ind$1@build.eclipse.org...
>> Hi All,
>> still few things aren't clear as:
> Yes, these are the same thing. This is a case where the documentation is
> lagging behind our recent changes to other parts of the system. Thanks for
> pointing this out.
> 2.0.6, I believe.) Is the LPG builder running at all? Are there new Java
> classes generated in the parser package? (E.g., for a language "Lang",
> there should be "LangLexer.java", "LangParser.java", and other lexer- and
> parser-related classes). Do you see any exception traces in the console
>> successful completion of all the steps? (I did not understand the same in
>> user guide)
> for our example language without doing any other work. This is what we do
> "leg")--anyway, that's what we call it (for "Little Expression Grammar"),
> The skeleton implementations that are generated for the other services all
> contain working example implementations that are based on the example
> grammar. Each time you add a language service you should be able to
> restart the IDE being developed and see that service working on programs
> runtime workbench starting from the development workspace in which you are
> building the IDE. The IDE should function automatically within the level
> 2 workspace when you are working on programs in your new language (just as
> separately in this newsgroup.) In order to be recognized by the new IDE,
> source programs in the new language must be given the filename extension
> that was specified in the "Programming language descriptor" wizard (we use
> "leg" for our example LEG-language extension). When you open a file with
> the appropriate filename extension, it should appear automatically in the
> editor of the new IDE. Depending on what other services have been
> instantiated in the IDE, you may see an outline view, syntax highlighting,
> You don't have to follow the whole IDE development process to the end. You
> becomes operational as soon as the parser is defined. If you run the IDE
> then, you should see little more than a basic Eclipse text editor, but it
> should already have integrated parsing--in other words, you should see
> annotations for syntax errors. When we give the IMP demo, we then usually
> add syntax highlighting (token coloring), outlining, and source text
> implementations for the various services. We think this grammar and these
> service implementations are fairly typical, but each language and IDE will
> be different. You may be able to start developing your own language and
> IDE by adapting the IMP LEG examples, or you may want to remove all of our
> example code and write your own grammar and servie implementations from
> scratch.
>> Hitesh...
> Stan Sutton
Re: Answers to questions on the IMP project [message #12284 is a reply to message #12251] Thu, 18 October 2007 10:32 Go to previous messageGo to next message
Hello Hitesh,
If the LPG Runtime feature is installed, then the LPG builder should be
available through that. If it were running successfully, there should
be another 8 or 9 Java classes in sample.imp.parser, and you should have
a set of AST classes in the *.AST package (and a few other classes). If
it were running unsuccessfully then you might see an exception stack
trace or error message on the console or you might get an error message
in the Error Log view. Do you see either of these things?
Another thing to look at: If LPG is installed properly, and you right
click on the project Sample (or any other one, for that matter), you
should see a menu item "Enable LPG Builder." (If the rest of SAFARI is
installed properly, you should see some other "Enable *** Builder"
items, as well, such as "Enable X10 Builder.") If LPG is properly
installed then you should see the corresponding menu item. If you don't
then that's a problem.
Of course, if the LPG builder is properly installed, it should be
running automatically and you should see the additional classes that I
mentioned above. I just tried this with the current IMP release on SF
and using your names of "Sample" and "sample" for the project and
language, and it worked for me. If you don't see the additional classes
but you do have the "Enable LPG Builder" menu item, then you could try
selecting that so as to manually enable the builder. That shouldn't be
necessary, but see if it has some effect.
Stan Sutton
> Hi Stanley,
> SampleParser.java
> SampleKWLexer.gi
> SampleLexer.gi
> SampleLexer.l
> SampleParser.g
> SampleParser.l
> Hitesh...
>>> Hi All,
>> pointing this out.
>>> user guide)
>> scratch.
>>> Hitesh...
>> Stan Sutton
Re: Answers to questions on the IMP project [message #12306 is a reply to message #12284] Fri, 19 October 2007 08:18 Go to previous messageGo to next message
Hello!
LPG
> > SampleParser.java
> > SampleKWLexer.gi
> > SampleLexer.gi
> > SampleLexer.l
> > SampleParser.g
> > SampleParser.l
I have the same problem. It may be of help to notice that sometimes the
exception below appears in the console. In the wizard, the fields at the
bottom are disabled and there's a message "can't create wizard page".
best regards,
Vlad
!ENTRY org.eclipse.imp.runtime 4 0 2007-10-19 14:06:13.687
!MESSAGE Could not create wizard page
!STACK 0
org.eclipse.imp.wizards.ExtensionPointEnabler.loadImpExtensi onsModel(Extensi
onPointEnabler.java:506)
org.eclipse.imp.wizards.IMPWizardPage.discoverProjectLanguag e(IMPWizardPage.
java:240)
org.eclipse.imp.wizards.ExtensionPointWizardPage.createContr ol(ExtensionPoin
tWizardPage.java:407)
org.eclipse.jface.wizard.Wizard.createPageControls(Wizard.ja va:180)
org.eclipse.jface.wizard.WizardDialog.createPageControls(Wiz ardDialog.java:6
14)
org.eclipse.jface.wizard.WizardDialog.createContents(WizardD ialog.java:502)
at org.eclipse.jface.window.Window.create(Window.java:426)
at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1124)
org.eclipse.ui.internal.actions.NewWizardShortcutAction.run( NewWizardShortcu
tAction.java:102)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:499 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(Action
ContributionItem.java:539)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionI
tem.java:488)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContribu
tionItem.java:400)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)
org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3348)
org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2968)
org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1930)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1894)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:422)
org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.
java:78)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(
EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAp
pLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl
..java:25)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
Re: Answers to questions on the IMP project [message #12317 is a reply to message #12306] Fri, 19 October 2007 08:25 Go to previous messageGo to next message
Oh, I see now that all IMP features have been installed outside of the main
Eclipse installation (I have some external product extension locations) and
maybe that's what makes it blow... (that path has spaces in it)
I'll be back with details.
regards,
Vlad
"Vlad D." <vladdu55@gmail.com> wrote in message
news:ffa7ad$nl5$1@build.eclipse.org...
> Hello!
"New
> LPG
> > > SampleParser.java
> > > SampleKWLexer.gi
> > > SampleLexer.gi
> > > SampleLexer.l
> > > SampleParser.g
> > > SampleParser.l
> best regards,
> Vlad
> !STACK 0
> java.lang.NullPointerException
> at
> at
> java:240)
> at
> at
> at
> 14)
> at
> at
> tAction.java:102)
> at
> at
> tem.java:488)
> at
> tionItem.java:400)
> at
> at
> at
> at
> at
> at
> at
> at
> java:78)
> at
> at
> pLauncher.java:68)
> at
> at
> at
> at
> .java:25)
Re: Answers to questions on the IMP project [message #12333 is a reply to message #12284] Fri, 19 October 2007 08:44 Go to previous messageGo to next message
1)Stanley, thanks a lot for the mails and help.
2)No, i don't see any other Java classes other than what I had mentioned
earlier. (*.AST is completely empty) I have attached the snap shot of my
project exlporer, this should show you what files are generated in the
packages. Alao, attached are the error log & problem views...
3)Yup, I can see "Enable LPG builder" menu item along with others...
4)I tried doing by even selecting the "Enable LPG builder" manually but
still dont have any luck going my way :(
Hitesh...
news:ff7qpn$tdu$1@build.eclipse.org...
> Hello Hitesh,
> Stan Sutton
>> Hi Stanley,
>> LPG
>> SampleParser.java
>> SampleKWLexer.gi
>> SampleLexer.gi
>> SampleLexer.l
>> SampleParser.g
>> SampleParser.l
>> Thanks,
>> Hitesh...
>>>> Hi All,
>>>> "LPG" ->
>>> is
>>> for
>>> pointing this out.
>>> Java
>>> and
>>>> in
>>>> user guide)
>>> do
>>> Grammar"),
>>> all
>>> are
>>> level
>>> as
>>> IDE,
>>> use
>>> with
>>> the
>>> highlighting,
>>> You
>>> IDE
>>> it
>>> usually
>>> these
>>> will
>>> our
>>> scratch.
>>>> Hitesh...
>>> Stan Sutton
Re: Answers to questions on the IMP project [message #12344 is a reply to message #12317] Fri, 19 October 2007 08:45 Go to previous messageGo to next message
news:ffa7nj$pga$1@build.eclipse.org...
main
and
Yes, that was it --- it seems something doesn't stand spaces in path
names...
best regards,
Vlad
Re: Answers to questions on the IMP project [message #12364 is a reply to message #12344] Sun, 21 October 2007 11:29 Go to previous messageGo to next message
Vlad,
Thanks very much for your observations about this. We have known that
there are some problems with spaces in pathnames that occur in relation
to LPG, but it seems that your problems occurred when you were trying to
do something unrelated to LPG, so maybe the problem is more widespread
than we had thought. I will post an advisory message about this problem
and we will be looking into it (although most of the IMP team will be
away this coming week, so it may take a little time).
Stan Sutton
> main
> and
> names...
> best regards,
> Vlad
Re: Answers to questions on the IMP project [message #12381 is a reply to message #12333] Sun, 21 October 2007 11:52 Go to previous messageGo to next message
Hello Hitesh,
From what you sent it does seem that the LPG builder is installed but
that it is not running.
Looking at what I can see in the Error Log image, I would guess that the
NullPointerException at the base of the log is the cause of the problem.
You should expand this item and see where the exception is occurring.
One consideration: In this thread Vlad D has reported a
NullPointerException that is due to the occurrence of a space in the
pathname to his Eclipse installation. He also has a problem where the
wizard page cannot be created (which I see too in your error log).
Maybe you have the same problem? Is there a space in the path name to
your Eclipse installation? (We should be able to handle that, but it
seems we may still have some work to do to get that right.)
You're welcome for the help!
Stan
> Hitesh...
>> Hello Hitesh,
>> Regards,
>> Stan Sutton
>>> Hi Stanley,
>>> LPG
>>> SampleParser.java
>>> SampleKWLexer.gi
>>> SampleLexer.gi
>>> SampleLexer.l
>>> SampleParser.g
>>> SampleParser.l
>>> Thanks,
>>> Hitesh...
>>>>> Hi All,
>>>>> "LPG" ->
>>>> is
>>>> for
>>>> pointing this out.
>>>> Java
>>>> and
>>>>> in
>>>>> user guide)
>>>> do
>>>> Grammar"),
>>>> all
>>>> are
>>>> level
>>>> as
>>>> IDE,
>>>> use
>>>> with
>>>> the
>>>> highlighting,
>>>> You
>>>> IDE
>>>> it
>>>> usually
>>>> these
>>>> will
>>>> our
>>>> scratch.
>>>>> Hitesh...
>>>> Stan Sutton
Re: Answers to questions on the IMP project [message #12409 is a reply to message #12381] Mon, 22 October 2007 02:52 Go to previous messageGo to next message
Yes, that was it for me too :)
The spaces in the path name was the problem! Its solved now.. Thanks Stan
and Vlad.
There's one more query. As per the IMP User Guide
( http://eclipse-imp.sourceforge.net/documentation/users_guide .html) for
creating a hyperlinking service, wizard
"File" -> "New" -> "IDE Language Support" -> "Editor Services" -> "Hyperlink
Detector" is to be used
and as per the Cheat sheets, wizard
"File" -> "New" -> "IDE Language Support" -> "Editor Services" -> "Reference
Resolver" is to be used
But we don't have either "Reference Resolver" or "Hyperlink Detector" under
"Editor Services".
Instead, we have "Reference Resolver" under "Core Services". So, what/where
is the substitute for "Hyperlink Detector"?
Hitesh...
news:fffsk2$uql$1@build.eclipse.org...
> Hello Hitesh,
> From what you sent it does seem that the LPG builder is installed but that
> it is not running.
> wizard page cannot be created (which I see too in your error log). Maybe
> you have the same problem? Is there a space in the path name to your
> Eclipse installation? (We should be able to handle that, but it seems we
> Stan
>> Hitesh...
>>> Hello Hitesh,
>>> Regards,
>>> Stan Sutton
>>>> Hi Stanley,
>>>> "New LPG
>>>> SampleParser.java
>>>> SampleKWLexer.gi
>>>> SampleLexer.gi
>>>> SampleLexer.l
>>>> SampleParser.g
>>>> SampleParser.l
>>>> Thanks,
>>>> Hitesh...
>>>>>> Hi All,
>>>>>> gone
>>>>>> "Parser
>>>>>> "LPG" ->
>>>>> is
>>>>> for
>>>>> pointing this out.
>>>>>> Parser
>>>>> should
>>>>> wizard
>>>>> is
>>>>> Java
>>>>> "Lang",
>>>>> and
>>>>> console
>>>>>> same in
>>>>>> user guide)
>>>>> can
>>>>> IDE
>>>>> we do
>>>>> (or
>>>>> Grammar"),
>>>>> all
>>>>> programs
>>>>> are
>>>>> level
>>>>> (just as
>>>>> new
>>>>> the
>>>>> example
>>>>> IDE,
>>>>> extension
>>>>> use
>>>>> with
>>>>> the
>>>>> highlighting,
>>>>> You
>>>>> IDE
>>>>> it
>>>>> usually
>>>>> these
>>>>> will
>>>>> and
>>>>> our
>>>>> from
>>>>> scratch.
>>>>>> Hitesh...
>>>>> Stan Sutton
Re: Answers to questions on the IMP project [message #12421 is a reply to message #9984] Mon, 22 October 2007 03:30 Go to previous messageGo to next message
Stan.
Just a reminder to post the example which you were supposed to! (demo for
working IDE)
Hitesh..
>> Hi All,
> pointing this out.
>> user guide)
> scratch.
>> Hitesh...
> Stan Sutton
Re: Answers to questions on the IMP project [message #12439 is a reply to message #12421] Mon, 22 October 2007 09:38 Go to previous messageGo to next message
Please, make it ASAP. I need it urgently...
Many Thanx!
Hitesh...
"Hitesh Nembhwani" <hiteshn.mail@gmail.com> wrote in message
news:ffhjio$1op$1@build.eclipse.org...
> Stan.
> working IDE)
> Hitesh..
>>> Hi All,
>>> in user guide)
>> all contain working example implementations that are based on the example
>> use "leg" for our example LEG-language extension). When you open a file
>> with the appropriate filename extension, it should appear automatically
>> in the editor of the new IDE. Depending on what other services have been
>> usually add syntax highlighting (token coloring), outlining, and source
>>> Hitesh...
>> Stan Sutton
Re: Answers to questions on the IMP project [message #14382 is a reply to message #12439] Mon, 22 October 2007 09:52 Go to previous messageGo to next message
Finally Done!!! :)
news:ffi94c$4k1$1@build.eclipse.org...
> Many Thanx!
> Hitesh...
>> Stan.
>> working IDE)
>> Thanks,
>> Hitesh..
>>>> Hi All,
>>>> "LPG" -> "New LPG Grammar with Parser Wrapper".
>>>> in user guide)
>>>> Hitesh...
>>> Stan Sutton
Re: Answers to questions on the IMP project [message #14440 is a reply to message #14382] Mon, 22 October 2007 22:21 Go to previous message
Hi Hitesh,
I hope you got things worked out. I have posted a top-level message
with more information about examples. I apologize that it took some
time to get this additional information up, but I'm out of the office
this week with duties unrelated to IMP.
Good luck!
Stan Sutton
Answers to questions on the IMP project [message #567358 is a reply to message #9937] Tue, 16 October 2007 15:55 Go to previous message
> Hi All,
> Hitesh...
Stan Sutton
Re: Answers to questions on the IMP project [message #567609 is a reply to message #9984] Wed, 17 October 2007 14:10 Go to previous message
Hi Stanley,
SampleParser.java
SampleKWLexer.gi
SampleLexer.gi
SampleLexer.l
SampleParser.g
SampleParser.l
Hitesh...
>> Hi All,
> pointing this out.
>> user guide)
> scratch.
>> Hitesh...
> Stan Sutton
Re: Answers to questions on the IMP project [message #567745 is a reply to message #12251] Thu, 18 October 2007 10:32 Go to previous message
Hello Hitesh,
Stan Sutton
> Hi Stanley,
> SampleParser.java
> SampleKWLexer.gi
> SampleLexer.gi
> SampleLexer.l
> SampleParser.g
> SampleParser.l
> Hitesh...
>>> Hi All,
>> pointing this out.
>>> user guide)
>> scratch.
>>> Hitesh...
>> Stan Sutton
Re: Answers to questions on the IMP project [message #567799 is a reply to message #12284] Fri, 19 October 2007 08:18 Go to previous message
Hello!
LPG
> > SampleParser.java
> > SampleKWLexer.gi
> > SampleLexer.gi
> > SampleLexer.l
> > SampleParser.g
> > SampleParser.l
best regards,
Vlad
!STACK 0
java:240)
14)
tAction.java:102)
tem.java:488)
tionItem.java:400)
java:78)
pLauncher.java:68)
..java:25)
Re: Answers to questions on the IMP project [message #567827 is a reply to message #12306] Fri, 19 October 2007 08:25 Go to previous message
regards,
Vlad
> Hello!
"New
> LPG
> > > SampleParser.java
> > > SampleKWLexer.gi
> > > SampleLexer.gi
> > > SampleLexer.l
> > > SampleParser.g
> > > SampleParser.l
> best regards,
> Vlad
> !STACK 0
> at
> at
> java:240)
> at
> at
> at
> 14)
> at
> at
> tAction.java:102)
> at
> at
> tem.java:488)
> at
> tionItem.java:400)
> at
> at
> at
> at
> at
> at
> at
> at
> java:78)
> at
> at
> pLauncher.java:68)
> at
> at
> at
> at
> .java:25)
Re: Answers to questions on the IMP project [message #567862 is a reply to message #12284] Fri, 19 October 2007 08:44 Go to previous message
Hitesh...
> Hello Hitesh,
> Stan Sutton
>> Hi Stanley,
>> LPG
>> SampleParser.java
>> SampleKWLexer.gi
>> SampleLexer.gi
>> SampleLexer.l
>> SampleParser.g
>> SampleParser.l
>> Thanks,
>> Hitesh...
>>>> Hi All,
>>>> "LPG" ->
>>> is
>>> for
>>> pointing this out.
>>> Java
>>> and
>>>> in
>>>> user guide)
>>> do
>>> Grammar"),
>>> all
>>> are
>>> level
>>> as
>>> IDE,
>>> use
>>> with
>>> the
>>> highlighting,
>>> You
>>> IDE
>>> it
>>> usually
>>> these
>>> will
>>> our
>>> scratch.
>>>> Hitesh...
>>> Stan Sutton
Re: Answers to questions on the IMP project [message #567895 is a reply to message #12317] Fri, 19 October 2007 08:45 Go to previous message
main
and
names...
best regards,
Vlad
Re: Answers to questions on the IMP project [message #567970 is a reply to message #12344] Sun, 21 October 2007 11:29 Go to previous message
Vlad,
Stan Sutton
> main
> and
> names...
> best regards,
> Vlad
Re: Answers to questions on the IMP project [message #568022 is a reply to message #12333] Sun, 21 October 2007 11:52 Go to previous message
Hello Hitesh,
Stan
> Hitesh...
>> Hello Hitesh,
>> Regards,
>> Stan Sutton
>>> Hi Stanley,
>>> LPG
>>> SampleParser.java
>>> SampleKWLexer.gi
>>> SampleLexer.gi
>>> SampleLexer.l
>>> SampleParser.g
>>> SampleParser.l
>>> Thanks,
>>> Hitesh...
>>>>> Hi All,
>>>>> "LPG" ->
>>>> is
>>>> for
>>>> pointing this out.
>>>> Java
>>>> and
>>>>> in
>>>>> user guide)
>>>> do
>>>> Grammar"),
>>>> all
>>>> are
>>>> level
>>>> as
>>>> IDE,
>>>> use
>>>> with
>>>> the
>>>> highlighting,
>>>> You
>>>> IDE
>>>> it
>>>> usually
>>>> these
>>>> will
>>>> our
>>>> scratch.
>>>>> Hitesh...
>>>> Stan Sutton
Re: Answers to questions on the IMP project [message #568114 is a reply to message #12381] Mon, 22 October 2007 02:52 Go to previous message
and Vlad.
"Editor Services".
Hitesh...
> Hello Hitesh,
> it is not running.
> Stan
>> Hitesh...
>>> Hello Hitesh,
>>> Regards,
>>> Stan Sutton
>>>> Hi Stanley,
>>>> "New LPG
>>>> SampleParser.java
>>>> SampleKWLexer.gi
>>>> SampleLexer.gi
>>>> SampleLexer.l
>>>> SampleParser.g
>>>> SampleParser.l
>>>> Thanks,
>>>> Hitesh...
>>>>>> Hi All,
>>>>>> gone
>>>>>> "Parser
>>>>>> "LPG" ->
>>>>> is
>>>>> for
>>>>> pointing this out.
>>>>>> Parser
>>>>> should
>>>>> wizard
>>>>> is
>>>>> Java
>>>>> "Lang",
>>>>> and
>>>>> console
>>>>>> same in
>>>>>> user guide)
>>>>> can
>>>>> IDE
>>>>> we do
>>>>> (or
>>>>> Grammar"),
>>>>> all
>>>>> programs
>>>>> are
>>>>> level
>>>>> (just as
>>>>> new
>>>>> the
>>>>> example
>>>>> IDE,
>>>>> extension
>>>>> use
>>>>> with
>>>>> the
>>>>> highlighting,
>>>>> You
>>>>> IDE
>>>>> it
>>>>> usually
>>>>> these
>>>>> will
>>>>> and
>>>>> our
>>>>> from
>>>>> scratch.
>>>>>> Hitesh...
>>>>> Stan Sutton
Re: Answers to questions on the IMP project [message #568143 is a reply to message #9984] Mon, 22 October 2007 03:30 Go to previous message
Stan.
working IDE)
Hitesh..
>> Hi All,
> pointing this out.
>> user guide)
> scratch.
>> Hitesh...
> Stan Sutton
Re: Answers to questions on the IMP project [message #568240 is a reply to message #12421] Mon, 22 October 2007 09:38 Go to previous message
Many Thanx!
Hitesh...
> Stan.
> working IDE)
> Hitesh..
>>> Hi All,
>>> in user guide)
>>> Hitesh...
>> Stan Sutton
Re: Answers to questions on the IMP project [message #568333 is a reply to message #12439] Mon, 22 October 2007 09:52 Go to previous message
Finally Done!!! :)
> Many Thanx!
> Hitesh...
>> Stan.
>> working IDE)
>> Thanks,
>> Hitesh..
>>>> Hi All,
>>>> in user guide)
>>>> Hitesh...
>>> Stan Sutton
Re: Answers to questions on the IMP project [message #568396 is a reply to message #14382] Mon, 22 October 2007 22:21 Go to previous message
Hi Hitesh,
Good luck!
Stan Sutton
Previous Topic:IMP Examples
Next Topic:IMP Examples
Current Time: Sun Aug 31 00:37:25 EDT 2025
Powered by FUDForum. Page generated in 0.08372 seconds
