Home » Eclipse Projects » Equinox » NullPointer exception while installing (possibly incompatible) plugin
NullPointer exception while installing (possibly incompatible) plugin [message #109044] Fri, 02 May 2008 08:44 Go to next message
I got this npe, while I installed the texlipse plugin via p2. Even if the plugin
is designed for an older version of eclipse (I successfully installed/used
via update manager in 3.4M5 though), that shouldn't happen I guess.
Felix
org.eclipse.equinox.internal.p2.touchpoint.eclipse.Util.crea teBundleInfo(Util.java:137)
org.eclipse.equinox.internal.p2.touchpoint.eclipse.EclipseTo uchpoint.installBundle(EclipseTouchpoint.java:787)
org.eclipse.equinox.internal.p2.touchpoint.eclipse.EclipseTo uchpoint$2.execute(EclipseTouchpoint.java:200)
org.eclipse.equinox.internal.p2.engine.ParameterizedProvisio ningAction.execute(ParameterizedProvisioningAction.java:32)
org.eclipse.equinox.internal.provisional.p2.engine.Phase.mai nPerform(Phase.java:116)
at org.eclipse.equinox.internal.provisional.p2.engine.Phase.per form(Phase.java:67)
org.eclipse.equinox.internal.provisional.p2.engine.Installab leUnitPhase.perform(InstallableUnitPhase.java:41)
at org.eclipse.equinox.internal.provisional.p2.engine.Phase.per form(Phase.java:46)
org.eclipse.equinox.internal.provisional.p2.engine.PhaseSet. perform(PhaseSet.java:38)
at org.eclipse.equinox.internal.provisional.p2.engine.Engine.pe rform(Engine.java:53)
org.eclipse.equinox.internal.provisional.p2.ui.operations.Pr ovisioningUtil.performProvisioningPlan(ProvisioningUtil.java :229)
org.eclipse.equinox.internal.provisional.p2.ui.operations.Pr ofileModificationOperation.doExecute(ProfileModificationOper ation.java:58)
org.eclipse.equinox.internal.provisional.p2.ui.operations.Pr ovisioningOperation.execute(ProvisioningOperation.java:40)
org.eclipse.equinox.internal.provisional.p2.ui.ProvisioningO perationRunner$1.run(ProvisioningOperationRunner.java:76)
Re: NullPointer exception while installing (possibly incompatible) plugin [message #109057 is a reply to message #109044] Fri, 02 May 2008 10:00 Go to previous message
Hi Felix,
Please try this with M7 which should be declared today and among other
things should handle the problems you're seeing.
1) the NPE should now be trapped so at the very least if there is a genuine
problem a proper error message will be logged and returned.
2) Support for old style plugins is now in place so if it worked in old UM
it should now also work with p2.
HTH
-Simon
"Felix Dorner" <felix_do@web.de> wrote in message
news:fvf2b3$pml$1@build.eclipse.org...
> plugin is designed for an older version of eclipse (I successfully
> installed/used via update manager in 3.4M5 though), that shouldn't happen
> I guess.
> Felix
> java.lang.NullPointerException
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
Previous Topic:p2 provisioning non-Eclipse applications
Next Topic:osgi always terminates
Current Time: Sun Aug 31 21:04:56 EDT 2025
Powered by FUDForum. Page generated in 0.04727 seconds
