Home » Modeling » GMF (Graphical Modeling Framework) » SVG Custom Figure
SVG Custom Figure [message #108954] Mon, 05 March 2007 11:41 Go to next message
Originally posted by: sven.kaffille.wiai.uni-bamberg.de
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
I have a problem with the custom figure (for the empty box) in the
Taipan-Example, which I checked out from CVS.
I have the latest Milestone-Release of GMF (M5uh).
The Taipan-Editor works in a Eclipse-Application I run the workbench,
but instead of the empty box image (box.svg) a rectangle with a red
cross is displayed.
I get no error/exception message, but in the runtime workspace's log I
get the following Exception:
!ENTRY org.eclipse.gmf.runtime.draw2d.ui.render 4 4 2007-03-05 17:25:15.984
!MESSAGE org.eclipse.swt.SWTException: Unsupported or unrecognized format
!STACK 0
at org.eclipse.swt.SWT.error(SWT.java:3478)
at org.eclipse.swt.SWT.error(SWT.java:3401)
at org.eclipse.swt.SWT.error(SWT.java:3372)
at org.eclipse.swt.internal.image.FileFormat.load(FileFormat.ja va:82)
at org.eclipse.swt.graphics.ImageLoader.load(ImageLoader.java:1 27)
org.eclipse.gmf.runtime.draw2d.ui.render.internal.image.Imag eRenderedImage.renderImage(ImageRenderedImage.java:65)
org.eclipse.gmf.runtime.draw2d.ui.render.internal.AbstractRe nderedImage.getSWTImage(AbstractRenderedImage.java:130)
org.eclipse.gmf.runtime.draw2d.ui.render.internal.RenderHelp er$1.run(RenderHelper.java:103)
at java.lang.Thread.run(Unknown Source)
Did I miss any step?
Has anybody an idea what went wrong?
Kind regards
sven
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.5 (MingW32)
iD8DBQFF7EgvJkyiyyNQFhIRAr04AKDVkTvYLrqSYQTRc3xOAbW4jFWc3QCg knzJ
JEdoTQIHflGspPepaRov7n0=
=TsHa
-----END PGP SIGNATURE-----
Re: SVG Custom Figure [message #109189 is a reply to message #108954] Tue, 06 March 2007 06:34 Go to previous messageGo to next message
Originally posted by: 5d5.mail.ru
My guess is that something went wrong with Apache Batik plugin; do you
see any errors/warnings in error log? Disabled plugins?
> Hash: SHA1
> Hello,
> cross is displayed.
> !STACK 0
> at
> at
> at
> Kind regards
> sven
> =TsHa
Re: SVG Custom Figure [message #109368 is a reply to message #109189] Tue, 06 March 2007 13:30 Go to previous messageGo to next message
Hash: SHA1
Hi Dmitry,
I cannot find any disabled plugins.
The log says nothing but the error I described in my first post.
Thank you, anyway.
regards
sven
> Hello,
> cross is displayed.
> 17:25:15.984
> !STACK 0
> at
> at
> at
> Kind regards
> sven
iD8DBQFF7bM7JkyiyyNQFhIRAp6nAJ9jAIDw5azu3BVA6sJmZIvkbdTE8ACg 3zgM
tVAQpYjxOs39Z8vdICKPre4=
=xxvU
Re: SVG Custom Figure [message #114916 is a reply to message #109368] Wed, 28 March 2007 05:35 Go to previous messageGo to next message
Hi Sven!
Did you already solve that?
Because it seems like I got the same problem.
I don't know if the batik plugin is really causing that.
It seems something goes wrong in the RenderHelper class of
org.eclipse.gmf.runtime.draw2d.ui.render plugin.
org.eclips.swt.internal.image.FileFormat is used to check the format of
the InputStream. And since it doesn't understand SVG Images, we get the
error.
Thanks a lot
Philipp
> Hash: SHA1
> Hi Dmitry,
> Thank you, anyway.
> regards
> sven
>> Hello,
>> cross is displayed.
>> 17:25:15.984
>> !STACK 0
>> at
>> at
>> at
>> Kind regards
>> sven
> =xxvU
Re: SVG Custom Figure [message #114988 is a reply to message #114916] Wed, 28 March 2007 07:18 Go to previous messageGo to next message
Hi again!
Seems like the bug is already known (Bugzilla 116227).
Thanks a lot, anyway.
Philipp
Philipp Sponfeldner wrote:
> Hi Sven!
> error.
> Thanks a lot
> Philipp
>> Hash: SHA1
>> Hi Dmitry,
>> Thank you, anyway.
>> regards
>> sven
>>> Hello,
>>> cross is displayed.
>>> 17:25:15.984
>>> !STACK 0
>>> at
>>> at
>>> at
>>> Kind regards
>>> sven
>> =xxvU
Re: SVG Custom Figure [message #117741 is a reply to message #114916] Sat, 07 April 2007 17:47 Go to previous message
Originally posted by: volt.vega.eti.pg.gda.pl
I managed to use SVG in GMF (M5uh).
I started with BPMN tutorial
http://wiki.eclipse.org/index.php/GMF_Tutorial_BPMN#Custom_F igures
I downloaded the project and checked how its done there.
After fixing plug-in dependencies on my build path (took me a while) I was
happy...
....only for a short period:
I could draw shapes loaded from svg, but reopening the diagram would issue
some batik errors and thread access errors in eclipse (only some of svg
shapes where rendered).
Konrad
> Hi Sven!
> error.
> Thanks a lot
> Philipp
>> Hash: SHA1
>> Hi Dmitry,
>> Thank you, anyway.
>> regards
>> sven
>>> Hello,
>>> cross is displayed.
>>> 17:25:15.984
>>> format
>>> !STACK 0
>>> at
>>> at
>>> at
>>> at
>>> Kind regards
>>> sven
>> =xxvU
Previous Topic:PageWizard
Next Topic:How to coustmize properties view
Current Time: Sat Jul 26 23:09:17 EDT 2025
Powered by FUDForum. Page generated in 0.19653 seconds
