Very exciting project :) [message #830] |
Sun, 27 August 2006 18:13  |
Originally posted by: nicolas.bihan.free.fr
I want to be sure. Are you talking about to build a web application with
our "old" RCP existing code ?
In that case RAP is a very exciting project :)
Thx,
Nicolas
Re: Very exciting project :) [message #922 is a reply to message #891] |
Wed, 30 August 2006 07:52  |
Originally posted by: rherrmann.innoopract.com
Hello Dan,
in the current contribution there are no viewers yet. But for RAP we
need a component analogous to JFace which will provide the viewers. One
approach could be to implement this based on the w4t-viewers library,
but there is no final decision made yet.
Actually, we did some investigation using EMF inside RAP-Applications
(Yoxos on demand - http://ondemand.yoxos.com - uses an EMF-Model for
example). As the workbench part of RAP does not yet exist, there is too
much infrastructure missing to generate EMF-Editors.
Of course a webapplication adds a level of complexity due to its
multi-user nature. Therefore a RAP-based EMF-editor would be different
than its RCP counterpart. But apart from that, the transactional
behaviour of those EMF models would need to be solved at the model level.
Rüdiger
Dan Connelly wrote:
> Rudiger:
> Does the W4T code in CVS today have viewers for
> org.eclipse.jface.viewers.ITreeContentProvider?
> "Shall be possible to reuse Content- and Label-Providers" here is
> slightly ambiguos. I am trying to get specific about what is
> supported in the initial code drop at Eclipse. The Innopract W4T used
> a different Provider interface such that lazy loading of a large content
> tree from a JFace ContentProvider, for instance, looked difficult to
> implement.
> Ideally, I would like tto convert an EMF codegen "Editor" (plugin/rcp)
> to a Web application. (For example, the standard EMF "Library"
> tutorial turns a model into a JFace plugin for editing model data. I
> would like to make this into a web application.)
> Actually, the EMF codegen editor is not transactional over the
> application's data. From an application point of view, it is not
> mult-user. However, it uses only "core" JFace for the ui.
> Has anyone attempted to webify EMF Library Editor using RAP? Then I
> would really get excited.
> -- Dan
> Rüdiger Herrmann wrote:
>> Hi Nicolas,
>> the goal of RAP is to enable programmers to develop applications
>> 'the eclipse way' - using the plug-in mechanism, a java widget
>> toolkit and workbench services
>> We aim for enabling as much reuse of RCP application components
>> as possible. However, for the first release of RAP the UI part
>> of existing RCP applications needs to be rewritten; which means
>> that core plug-ins can be reused, as long as they are multi-user
>> capable. It shall be possible to reuse Content- and Label-Providers.
>> Regards
>> Rüdiger
>> Nicolas Bihan wrote:
>>> Hi,
>>> with our "old" RCP existing code ?
>>> Thx,
>>> Nicolas
FUDForum. Page generated in 0.04034 seconds
