Help needed in perspective [message #108614] |
Fri, 08 August 2003 04:00  |
Originally posted by: pkumar.louveciennes.sema.slb.com
hi
I am new to eclipse plugin development and need some help.
Context:
I am trying to make a new perspective(following "Using Perspectives in
the Eclipse UI" by Dave Springgay ). To which I would like to add some
views. I tried few things , but the only trick which worked was opening
the perspective then opening the views and then saving the perspective.
Problems:
1) Views are not added in right position.It seems it is following a
default behaviour. All the views are added to the right of EditorView.
2) I tried to add a view through program, no results seen.
Questions:(Which could be stupid !!!)
1) Is there some other way of adding a custom view to a custom
perspective ?
2) How can I change the position of the views?
Code:
public void createInitialLayout(IPageLayout layout)
defineActions(layout);
defineLayout(layout);
ššššššššššš
ššššššššššššššš
šššššššššššššššš
public void defineLayout(IPageLayout layout)
// Editors are placed for free.
String editorArea = layout.getEditorArea();
// hiding the editor
// Place navigator and outline to left of
// editor area.
IFolderLayout top =
layout.createFolder("top", IPageLayout.TOP, (float) 0.26,
editorArea);
top.addView(IPageLayout.ID_RES_NAV);
top.addView(IPageLayout.ID_OUTLINE);
// IFolderLayout bottom =
layout.createFolder("bottom",IPageLayout.BOTTOM, 0.50f, editorArea );
// never worked ??????
layout.addView("org.xyz.pk.views.SampleView",IPageLayout.BOTTOM, 0.50f,
editorArea);
Thanx in advance
PKumar
Re: Help needed in perspective [message #109658 is a reply to message #108614] |
Mon, 11 August 2003 11:06  |
Originally posted by: simon.ibm.oti.lab
"PKumar" <pkumar@louveciennes.sema.slb.com> wrote in message
news:bgvlaj$s1f$1@eclipse.org...
> hi
> Context:
> Problems:
If you do not define in your perspective where a view goes, then the
workbench takes a guess where it should open.
> perspective ?
Yes - its all explained in the article
What views? From where?
Did you check your .log file to see if there was any problems with your
perspective?
> Code:
FUDForum. Page generated in 0.04290 seconds
