Eclipse deletes in bin-directory [message #108608] |
Wed, 22 October 2003 05:13  |
Originally posted by: davidbaer.gmx.ch
In the bin directory, there are several different folders, which have no
equivalent in the source-folder (i.e. settings, preferences, imported
class-files,...)
how can i make sure, that eclipse doesn't delete all the time?
thank you!
david
Re: Eclipse deletes in bin-directory [message #108780 is a reply to message #108608] |
Wed, 22 October 2003 08:46  |
Originally posted by: olivier_thomann.ca.ibm.comNOSPAM
Le Wed, 22 Oct 2003 11:13:42 +0200, David Baer <davidbaer@gmx.ch> a
écrit :
>class-files,...)
You should put your imported class files into a class folder and all
your settings and preferences in a source folder. Then they will be
copied to the output folder for each full build.
Olivier
FUDForum. Page generated in 1.03306 seconds
