Home » Eclipse Projects » Eclipse Platform » Copying from outline view
Copying from outline view [message #108558] Fri, 08 August 2003 03:37 Go to next message
Originally posted by: veith.pixel.de
hi,
AFAIK, in eclipse release 2.x you can copy an entry (for instance an
inner class) in the outline view and paste it into an editor. the entire
source of the class was copied.
in release 3.x only the string selected in the outline view gets copied.
Can I get the r. 2.1 behavior into r. 3.x ?
Gernot
Re: Copying from outline view [message #109690 is a reply to message #108558] Mon, 11 August 2003 12:59 Go to previous message
Originally posted by: adam_kiezun.ch.ibm.remove.com
Not at this point.
This was introduced as a tradeoff for https://bugs.eclipse.org/bugs/show_bug.cgi?id=37307
Only 1 thing can be copied to the text clipboard - either it's the name of the method or it is its content.
This behaviour was changed to fix the bug above and make it consistent for all elements.
You could enter a report and argue that for methods/imports/types/fields/package declarations
it's the source that should be put in the clipboard and for projects/java projects/source folders/packages/compilation
units/files/folders/jar files/source folders/class folders it should be the element's name. Or sth along these lines.
a.
eclipse.org
Previous Topic:Help needed in perspective
Next Topic:Has anyone seen this exception
Current Time: Sat Jul 12 07:34:09 EDT 2025
Powered by FUDForum. Page generated in 0.03438 seconds
