Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » Teneo or CDO?
Teneo or CDO? [message #108357] |
Sat, 26 January 2008 06:55  |
We have about 15 EMF models at the moment in our product that uses the
default XMI persistance in EMF. Now we have requirements to let multiple
user read and write in the same model instances. As I understand EMFT
provides two solutions for this: CDO and Teneo.
What are the differences between these two frameworks?
Which framework would be "best" for us?
Henrik
Re: Teneo or CDO? [message #108536 is a reply to message #108449] |
Sun, 27 January 2008 06:42   |
Hi Henrik,
My answer is very much the same as Eike's. Just check out both solutions (Teneo's can be found here:
http://www.elver.org) and see what fits best.
Teneo is very much focused on the mapping any type of model to a relational store. The mapping
support is very complete (imho) with support for most EMF constructs (for example, featuremaps,
mixed, etc.). Teneo offers a default mapping logic which you can easily override using jpa
annotations in the model or in a separate xml file.
See here for a more detailed listing of features:
http://www.elver.org/hibernate/features.html
Btw, it is on my wishlist to integrate CDO and Teneo combining the client-server layer of CDO/Net4j
with the relational mapping capabilities of Teneo. Until now I have not yet found the time to do so :-(.
gr. Martin
Eike Stepper wrote:
> Hi Henrik,
> I believe both CDO and Teneo solve some very similar problems and can be
> what you're looking for.
> As the author of CDO, what should I say? ;-)
> You can find a feature list of CDO (and a bit more information) at
> http://wiki.eclipse.org/CDO
> What about evaluating both technologies and report your experiences here?!
> That'd be very interesting.
> Of course, if you have more detailed questions with respect to CDO, I'm
> here ;-)
> Eike Stepper
> http://wiki.eclipse.org/Net4j
> Henrik Jönsson schrieb:
>> multiple user read and write in the same model instances. As I
>> understand EMFT provides two solutions for this: CDO and Teneo.
>> Regards
>> Henrik
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Teneo or CDO? [message #109086 is a reply to message #108357] |
Tue, 29 January 2008 09:35   |
I'll add a bit of a "neutral" voice to this thread.
*** disclaimer ***
I am only reporting from about one week personal playing with both CDO
and Teneo.
What I write here is my personal experience. This report is thus quite
subjective.
If I missed any feature or functionality or reported something wrong,
please, Eike, Martin, do correct me.
*** disclaimer end ***
A bit of personal motivation (just to clarify my environment and
requirements):
I want to build a research prototype which converts text-documents or
other more or less structured collections of text to models (like - e.g.
making one model-element "Paragraph" out of one text-paragraph with an
attribute "content") and then apply algorithms to them. I use models as
a common platform to apply my algorithms to texts of whichever format,
so models are a form of abstraction for me.
I quickly found out that working with huge models with EMF is a bit
problematic, because resources in EMF are atomar - i.e. you can only
load or unload a resource as a whole, not work with parts of it.
Additionally storing huge models in a database seemed to make more sense
than working with XMI files.
So I was pointed to EMFT Teneo and CDO.
I started playing around with Teneo/Hibernate.
Pros:
- Easy installable using update site
- Works almost out of the box with existing ecore-based model
- Storage Annotations can be added to the .genmodel
- Mapping is generated on the fly (but can also be changes as far as I
know, didn't try this out)
- Uses Hibernate -> can be used with lots of databases
- Tutorials and documentation at http://www.elver.org/hibernate/ are in
most parts usable for a quick start
- Lazy loading (not using EMF-proxies but Hibernate cglib proxies)
- Excellent support in the newsgroup
Cons:
- No client-server architecture (besides the db-server/-client - so you
have the eclipse application and the database server) - so I think no
mechanism to propagate changes between multiple concurrent users
- No re-proxying (you can't lazy-load your object-net and then throw
away part of that net while still keeping the other part) - this is
unsuitable for working with large models
Because of the last point I started playing around with CDO:
Pros:
- Client-Server architecture with change notifications between the
clients (didn't try that out)
- It's possible to put client and repository management into the same
application, so Client/Server is optional
- Lazy-loading and Lazy-unloading is possible (and is done
transparently, so no management needed for this).
- If the basic framework is set up, you can simply work naturally with
the model, and commit() whenever you like
Cons:
- Documentation (mostly the Wiki) is incomplete - so setting up the
basic framework is a bit tricky (but as stated above, newsgroup support
is excellent ;-))
- Subjectively higher learning curve than with Teneo for setting up the
infrastructure
- Only works with mysql, derby and hsqldb (as well as with a memory-only
store) - more to come (I think)
- No direct influence on the database mapping (some parameters for the
mapping strategy can be tuned)
Regarding performance, I can not make any statement, as I haven't tried
any of the technologies with huge models.
In one sentence I would characterize Teneo as an ORM-solution for EMF,
while CDO is a client-server architecture for EMF models.
In a recent post, Martin stated, that he'll try to integrate Teneo and CDO.
I think that would be the ultimate client-server ORM solution for EMF.
As stated above, these lists are very subjective and they are guaranteed
to be incomplete.
Maybe they are a starting point and I would like if other users of any
of both technologies could add to any of the lists.
Cheers
Stefan
> Regards
> Henrik
Re: Teneo or CDO? [message #109126 is a reply to message #109086] |
Tue, 29 January 2008 10:04   |
Originally posted by: stepper.sympedia.de
Stefan,
Thanks for your excellent (from my perspective) analysis!
More comments below...
Stefan Winkler schrieb:
> *** disclaimer ***
> and Teneo.
> subjective.
> requirements):
> e.g. making one model-element "Paragraph" out of one text-paragraph
> with an attribute "content") and then apply algorithms to them. I use
> models as a common platform to apply my algorithms to texts of
> whichever format, so models are a form of abstraction for me.
> sense than working with XMI files.
> Pros:
> in most parts usable for a quick start
> Cons:
> you have the eclipse application and the database server) - so I think
> no mechanism to propagate changes between multiple concurrent users
> Pros:
> Cons:
> support is excellent ;-))
Apologies for that! I guess one reason that open source developers
choose to work without being paid is that they are free to postpone
documentation tasks as long as there are coding tasks in the list ;-)
> the infrastructure
Agreed. Do you think this is an implication of the incomplete
documentation? Or do you have suggestions to simplify the setup?
> memory-only store) - more to come (I think)
Contributions of additional DB adapters are welcome ;-)
> tried any of the technologies with huge models.
I think this is a good summary.
> CDO.
Volunteers hands up ;-)
Unfortunately Martin and I didn't have time so far to dig into this
issue although we're both sure that this effort could deliver a great
solution.
Eike Stepper
> guaranteed to be incomplete.
> Cheers
> Stefan
>> the default XMI persistance in EMF. Now we have requirements to let
>> Regards
>> Henrik
Re: Teneo or CDO? [message #109152 is a reply to message #109126] |
Tue, 29 January 2008 10:27   |
Hi Stefan,
Also from my point of view your post contains a balanced pro/con overview.
I am very interested in integrating Teneo with cdo. With Teneo I have/will never have the intention
to offer client-server functionality. On the other hand I see a clear requirement from Teneo users
for this functionality and CDO seems to me as a perfect solution to this.
Posts like yours and the others which appeared the past few days help to put this integration much
higher (somewhere around the top :-) of my priority list.
gr. Martin
Eike Stepper wrote:
> Stefan,
>> *** disclaimer ***
>> and Teneo.
>> subjective.
>> requirements):
>> Pros:
>> Cons:
>> Pros:
>> Cons:
>> the infrastructure
>> CDO.
> solution.
> Eike Stepper
>> Cheers
>> Stefan
>>> Hi,
>>> Regards
>>> Henrik
The Netherlands
Re: Teneo or CDO? [message #109241 is a reply to message #109152] |
Tue, 29 January 2008 13:26   |
Originally posted by: tom.eiswind.de
HI Martin,
I only came across CDO this morning and it seems to be what I didnt know
that I want it so much. As with the others teneo integration is whats
missing the most. Why create another database mapping solution when
hibernate is around and so well supported. (this is what i dislike on
cdo most at the first glance) I will dive into CDO the next days as Im
currently off project and have some time to do so. WHat I think we have
to look at is the following: hibernate does its lazy loading through its
own custom proxies. I will have to see how it is done with cdo. I
remember I saw some implementation of custom lazy loading with remote
ejbs strategy on the hibernate wiki
http://www.hibernate.org/377.html
but i wonder how this would go with cdo. cdo has its own proxies, so we
would have to teach hibernate to use those and put a tuplizer in the
hibernate mapping. dont know if this is so easy and what would be the
best way.
I havent seen much of the CDO implementation, but I think at least this
should be possible to achieve without too much trouble.
Martin Taal schrieb:
> Hi Stefan,
> have/will never have the intention to offer client-server functionality.
> On the other hand I see a clear requirement from Teneo users for this
> put this integration much higher (somewhere around the top :-) of my
> priority list.
> gr. Martin
> Eike Stepper wrote:
>> Stefan,
>>> Hi,
>>> *** disclaimer ***
>>> CDO and Teneo.
>>> quite subjective.
>>> requirements):
>>> Pros:
>>> I know, didn't try this out)
>>> Cons:
>>> think no mechanism to propagate changes between multiple concurrent
>>> users
>>> Pros:
>>> with the model, and commit() whenever you like
>>> Cons:
>>> the infrastructure
>>> the mapping strategy can be tuned)
>>> and CDO.
>> solution.
>> Regards,
>> Eike Stepper
>>> any of both technologies could add to any of the lists.
>>> Cheers
>>> Stefan
>>>> Hi,
>>>> Regards
>>>> Henrik
Re: Teneo or CDO? [message #110090 is a reply to message #109126] |
Wed, 30 January 2008 08:22   |
Hi Eike,
comments below ...
Eike Stepper schrieb:
> Stefan,
>> *** disclaimer ***
>> CDO and Teneo.
>> quite subjective.
>> requirements):
>> Pros:
>> Cons:
>> users
>> Pros:
>> Cons:
I fully understand that - so no apology necessary :-)
I know loads of better things to do with my unpaid free time - so I
really acknowledge all the resources you (and Martin and all of the
other OSS developers) spend!
>> the infrastructure
I think it simply is a consequence of the more complex architecture. In
contrast to Teneo/Hibernate which only needs the Hibernate engine to be
initialized, which is done in 3 LOC, setting up the
client-server-infrastructure and establishing the communication between
both needs some more understanding of the underlying concepts (or a good
tutorial ;-)).
At the same time - as I am experiencing right now - a lot can go wrong
before you can commit your first EObject ...
So what is needed - as Thomas stated in another post - is a getting
started tutorial (maybe one for client-server scenario and one for my
case with the single-user approach) and a small knowledge base, which
lists some common errors (like mine) which can occur during the first steps.
Both things do not have to be written by you. As soon as I got my basic
code working over here, I am willing contribute a small tutorial to the
wiki - at least if you can say that the API is stable enough.
>> and CDO.
> solution.
Well, I personally don't really need Hibernate support - I need the
lazy-loading-and-unloading properties which CDO provides.
Stefan
Re: Teneo or CDO? [message #110166 is a reply to message #110090] |
Wed, 30 January 2008 08:42   |
>>> the infrastructure
> In contrast to Teneo/Hibernate which only needs the Hibernate engine
> to be initialized, which is done in 3 LOC, setting up the
> between both needs some more understanding of the underlying concepts
> (or a good tutorial ;-)).
> steps.
> basic code working over here, I am willing contribute a small tutorial
> to the wiki - at least if you can say that the API is stable enough.
That'd be most welcome ;-)
The API is quite stable although new features could change it (doesn't
affect users) or new IStore implementations (only effects other extenders).
From time to time I apply a bit of renaming or moving to enhance the
internal structure.
This is the benefit I take from not being allowed to publish a 1.0.0
release (Ed will want to comment on the word "allowed" ;-) )
>>> and CDO.
>> solution.
Don't you even need any RDB store? May be a file based persistency
solution is adequate for you, too?
I already thought about providing such a store implementation which
would even be better aligned with modeling needs...
Eike Stepper
Re: Teneo or CDO? [message #111208 is a reply to message #110166] |
Thu, 31 January 2008 04:04   |
Basically, the only hard requirement I have is the ability to be able to
manage models as huge as several GB as transparently as possible.
I don't need revisions, client-server, multi-user or RDB, really.
(However, I have a feeling that an RDB would do a better job in keeping
that amount of data compared to files, but who knows. And as I am doing
research and want to do some statistical analysis of the outcome of my
experiments, I could do some quick SQL queries on the RDB to achieve
that which could save me some time later...).
Stefan
Re: Teneo or CDO? [message #111250 is a reply to message #111208] |
Thu, 31 January 2008 04:20  |
> to manage models as huge as several GB as transparently as possible.
> keeping that amount of data compared to files, but who knows. And as I
> am doing research and want to do some statistical analysis of the
> outcome of my experiments, I could do some quick SQL queries on the
> RDB to achieve that which could save me some time later...).
Martin and I are making some progress on the Hibernate Store. Let's see
what that leads to ;-)
Eike Stepper
Re: Teneo or CDO? [message #614100 is a reply to message #108357] |
Sat, 26 January 2008 10:04  |
Hi Henrik,
here ;-)
Eike Stepper
> Regards
> Henrik
Re: Teneo or CDO? [message #614106 is a reply to message #108449] |
Hi Henrik,
gr. Martin
Eike Stepper wrote:
> Hi Henrik,
> here ;-)
> Eike Stepper
>> Regards
>> Henrik
The Netherlands
Re: Teneo or CDO? [message #614148 is a reply to message #108357] |
*** disclaimer ***
and Teneo.
subjective.
requirements):
Pros:
Cons:
Pros:
Cons:
is excellent ;-))
infrastructure
to be incomplete.
Cheers
Stefan
> Regards
> Henrik
Re: Teneo or CDO? [message #614151 is a reply to message #109086] |
Stefan,
> *** disclaimer ***
> and Teneo.
> subjective.
> requirements):
> Pros:
> Cons:
> Pros:
> Cons:
> the infrastructure
> CDO.
solution.
Eike Stepper
> Cheers
> Stefan
>> Regards
>> Henrik
Re: Teneo or CDO? [message #614153 is a reply to message #109126] |
Hi Stefan,
gr. Martin
Eike Stepper wrote:
> Stefan,
>> *** disclaimer ***
>> and Teneo.
>> subjective.
>> requirements):
>> Pros:
>> Cons:
>> Pros:
>> Cons:
>> the infrastructure
>> CDO.
> solution.
> Eike Stepper
>> Cheers
>> Stefan
>>> Hi,
>>> Regards
>>> Henrik
The Netherlands
Re: Teneo or CDO? [message #614160 is a reply to message #109152] |
HI Martin,
best way.
> Hi Stefan,
> priority list.
> gr. Martin
> Eike Stepper wrote:
>> Stefan,
>>> Hi,
>>> *** disclaimer ***
>>> CDO and Teneo.
>>> quite subjective.
>>> requirements):
>>> Pros:
>>> Cons:
>>> users
>>> Pros:
>>> Cons:
>>> the infrastructure
>>> and CDO.
>> solution.
>> Regards,
>> Eike Stepper
>>> Cheers
>>> Stefan
>>>> Hi,
>>>> Regards
>>>> Henrik
Re: Teneo or CDO? [message #614303 is a reply to message #109126] |
Hi Eike,
comments below ...
> Stefan,
>> *** disclaimer ***
>> CDO and Teneo.
>> quite subjective.
>> requirements):
>> Pros:
>> Cons:
>> users
>> Pros:
>> Cons:
>> the infrastructure
tutorial ;-)).
>> and CDO.
> solution.
Stefan
Re: Teneo or CDO? [message #614319 is a reply to message #110090] |
>>> the infrastructure
> steps.
internal structure.
>>> and CDO.
>> solution.
Eike Stepper
Re: Teneo or CDO? [message #614362 is a reply to message #110166] |
Stefan
Re: Teneo or CDO? [message #614368 is a reply to message #111208] |
Eike Stepper
Current Time: Mon Jul 21 21:37:39 EDT 2025
Powered by FUDForum. Page generated in 0.28253 seconds
