Home » Language IDEs » ServerTools (WTP) » Configure TCP/IP monitor WTP 1.0M4
Configure TCP/IP monitor WTP 1.0M4 [message #108324] Tue, 31 May 2005 05:59 Go to next message
Originally posted by: UE004584.guest.telecomitalia.it
How can I configure TCP/IP monitor?
Re: Configure TCP/IP monitor WTP 1.0M4 [message #108352 is a reply to message #108324] Tue, 31 May 2005 10:21 Go to previous messageGo to next message
From the TCP/IP monitor view select the down arrow from the top right of
the view. Select Properties... This will display a list of all the TCP/IP
monitor properties.
You can now add a monitor by selecting Add... Enter the local port you
will use, the remote host, and the remote port. Click OK.
Your monitor has been added. Now select your monitor from the list and
click Start.
Click OK on the properties window and you're good to go.
Lawrence
Re: Configure TCP/IP monitor WTP 1.0M4 [message #108492 is a reply to message #108352] Wed, 01 June 2005 04:50 Go to previous messageGo to next message
I'm trying to set up tcpmon to monitor a remote web service, but not sure
what to put in the boxes
The web serice endpint is this
http://services.xmethods.net:80/soap/servlet/rpcrouter
The web service wsdl is this
http://www.xmethods.net/sd/2001/TemperatureService.wsdl
The wevb site is this www.xmethods.net
If i click add in the proerties for the tcpmon what goes in the hostname?
i've tired all klinks above and get no activity
Thanks for any help
<lmandel@ca.ibm.com> wrote in message news:d7hrt8$8rt$1@news.eclipse.org...
> monitor properties.
> click Start.
> Lawrence
Re: Configure TCP/IP monitor WTP 1.0M4 [message #108849 is a reply to message #108492] Wed, 01 June 2005 18:11 Go to previous message
You want to put your remote host in the host field. In your case,
services.xmethods.net. The remote port will be 80. You also need to tell
your Web service client to point to your local machine at the port your
specified. Assuming you specified port 8080 on your local machine, your
Web service client will make requests for the Web service to
http://localhost:8080/soap/servlet/rpcrouter (if your client is not
located on your local machine substitute your ip address for localhost)
Your monitor will then receive and requests sent to your local machine and
forward them on to the remote service returning the results to your
client.
Lawrence
>Hi,
>Thanks for any help
Previous Topic:possible to import wsdl from filesystem?
Next Topic:Installation
Current Time: Sat Jul 26 09:16:39 EDT 2025
Powered by FUDForum. Page generated in 0.05294 seconds
