Re: Configure TCP/IP monitor WTP 1.0M4 [message #108849 is a reply to message #108492] |
Wed, 01 June 2005 18:11  |
You want to put your remote host in the host field. In your case,
services.xmethods.net. The remote port will be 80. You also need to tell
your Web service client to point to your local machine at the port your
specified. Assuming you specified port 8080 on your local machine, your
Web service client will make requests for the Web service to
http://localhost:8080/soap/servlet/rpcrouter (if your client is not
located on your local machine substitute your ip address for localhost)
Your monitor will then receive and requests sent to your local machine and
forward them on to the remote service returning the results to your
client.
Lawrence
>Hi,
>I'm trying to set up tcpmon to monitor a remote web service, but not sure
>what to put in the boxes
>The web serice endpint is this
>http://services.xmethods.net:80/soap/servlet/rpcrouter
>The web service wsdl is this
>http://www.xmethods.net/sd/2001/TemperatureService.wsdl
>The wevb site is this www.xmethods.net
>If i click add in the proerties for the tcpmon what goes in the hostname?
>i've tired all klinks above and get no activity
>Thanks for any help
FUDForum. Page generated in 0.08084 seconds
