Home » Archived » Memory Analyzer (MAT) » How to get all objects which class implements specific interface?
How to get all objects which class implements specific interface? [message #9849] Tue, 31 March 2009 22:38 Go to next message
I was trying to get all objects which class implements specific interface,
1. (from reference)
SELECT * FROM ( SELECT *
FROM java.lang.Class c
WHERE c implements
com.sap.tools.memory.snapshot.model.IClass )
Result:
Problem reported:
Sub-Select must return an object list: SELECT * FROM java.lang.Class c
WHERE (c INSTANCEOF com.sap.tools.memory.snapshot.model.IClass)
2.
SELECT * FROM java.lang.Class c WHERE c implements
Result:
Your Query did not yield any result.
SELECT * FROM java.lang.Class c WHERE (c INSTANCEOF
3.
SELECT * FROM INSTANCEOF com.sap.tools.memory.snapshot.model.IClass
Result:
All three tries don't work, has anyone tried on same question?
Note:
I tried our interface and com.sap.tools.memory.snapshot.model.IClass, both
don't work. The Analyzer version is 0.7.100.
Samuel
Re: How to get all objects which class implements specific interface? [message #9897 is a reply to message #9849] Thu, 02 April 2009 08:20 Go to previous message
Hi Samuel,
I think that you wanted to write a query to get all objects which
implement a certain interface...
Unfortunately HPROF dumps from SUN virtual machines do not contain the
information about interfaces which would be necessary for such a query...
Kind regards,
Erwin
Previous Topic:can not get heap dump on win32 ?
Next Topic:CorruptDataException with (MAT+DTFJ) when reading a jextracted core
Current Time: Fri Jul 25 21:11:28 EDT 2025
Powered by FUDForum. Page generated in 0.03942 seconds
