CDT Managed BUild System Extensibility [message #108267] |
Wed, 30 June 2004 05:44  |
Originally posted by: Han . Hoekstra . WirelessValue . Nl
Hey all,
I have a question concerning the extension of the managed make projects.
Currently I am working with Eclipse 2.1.3 and CDT 1.2.1, but I want to move
to Eclipse 3.0 RC1 and CDT 2.0M9. However when I do that my projects won't
build anymore. I have written 2 toolchain plug-ins so that I can use the
cross-compiler with the managed make process. I think the problem lies here,
because I also can not set any properties anymore for the build process in
the project properties. Is there any doc that says what I have to change in
my toolchain plug-in for it to work with the new environment ?
Greetings,
Han
Re: CDT Managed BUild System Extensibility [message #108335 is a reply to message #108267] |
Wed, 30 June 2004 09:54   |
Hello Han,
I'm using Eclipse Workbench 3.0 and CDT 2.0M9
I'm facing the same problems.
The .log file gives me the java.lang.NullPointerException's:
When changing options:
org.eclipse.cdt.managedbuilder.ui.properties.BuildToolSettin gsPage.parseAllOptions(BuildToolSettingsPage.java:250)
When building:
org.eclipse.cdt.managedbuilder.internal.core.GeneratedMakefi leBuilder.fullBuild(GeneratedMakefileBuilder.java:258)
I'm considering to rewrite the plugin's,... an alternative would be to fix
the actual problem,...
I did see a new Management Build System Proposal for CDT3.0 (CDT-dev
mailing list), maybe that can give some insight in case you consider using
the new schema (only then you will see the latest features in the
extension).
I hope future versions will be backwards compatible,...
Marco
Han Hoekstra wrote:
> Hey all,
> Greetings,
> Han
Re: CDT Managed BUild System Extensibility [message #108380 is a reply to message #108267] |
Wed, 30 June 2004 15:06  |
Guys,
If you are having problems, open a bugzilla report and put the log file
contents in it. Give me enough information to debug the problem, of
course :-).
Sean
Han Hoekstra wrote:
> Hey all,
> Greetings,
> Han
FUDForum. Page generated in 0.06429 seconds
