Home » Eclipse Projects » GEF » Eclipse 3.0M5 and GEF doesn't work
Eclipse 3.0M5 and GEF doesn't work [message #108040] Fri, 05 December 2003 12:12 Go to next message
Originally posted by: markku.saarela.entra.fi
Have anybody install GEF plugin to Eclipse 3.0M5?
Manage Configurations doesn't regonize at all GEF.
Latest version that I tried was integration build 20031204 runtime.
rgds, Markku
Re: Eclipse 3.0M5 and GEF doesn't work [message #108055 is a reply to message #108040] Fri, 05 December 2003 12:47 Go to previous messageGo to next message
There were two builds yesterday (with the first one being broken). Did you
use the second one?
"Markku Saarela" <markku.saarela@entra.fi> wrote in message
news:bqqeao$ob6$1@eclipse.org...
> rgds, Markku
Re: Eclipse 3.0M5 and GEF doesn't work [message #108090 is a reply to message #108055] Sat, 06 December 2003 00:48 Go to previous messageGo to next message
Yes i use this second 16:31 build and using on win xp.
> use the second one?
> > Hi,
> > rgds, Markku
Re: Eclipse 3.0M5 and GEF doesn't work [message #108328 is a reply to message #108090] Mon, 08 December 2003 18:54 Go to previous messageGo to next message
Well, I tested it and GEF shows up just fine under "Manage Configurations."
Did you download the GEF SDK and the GEF Examples zip files from the same
build and extract them to the eclipse directory? Was your workbench closed
when you did that? Pending changes doesn't catch anything?
news:bqrqj4$3c9$1@eclipse.org...
you
> > use the second one?
> > > Hi,
> > > rgds, Markku
Re: Eclipse 3.0M5 and GEF doesn't work [message #108421 is a reply to message #108328] Tue, 09 December 2003 05:41 Go to previous message
Thanks, that finishing pending changes do the trick.
I forgot that one.
Markku :-)
> you
> > > use the second one?
> > > > Hi,
> > > > rgds, Markku
Previous Topic:Adding Polygons
Next Topic:Programmatically select EditPart
Current Time: Sun Aug 31 13:34:56 EDT 2025
Powered by FUDForum. Page generated in 0.03823 seconds
