Problem creating links programatically using CreateRelationshipRequest [message #107992] |
Thu, 01 March 2007 01:46  |
Originally posted by: ganesh.mohan.hp.com
I have implemented a wizard which opens as soon as a user double clicks on
a building block say - "source-element" (using the OpenEditPolicy
installed on that element's editpart). The wizard provides a option for
the user to create new elements. depending upon the number of elements
entered by the user, those elements are created on the editor. I am using
the "CreateElementRequest" and executing a command by passing this request.
The problem i am facing now is, I want to create a link between the
"source element" and the new elements that are being created. I am not
able to get the reference of the new elements created to provide as a
"target" parameter to the CreateRelationshipRequest. I want these links to
be created along with the element creation. Is there any way i can achieve
this?? Can anyone please help me in resolving this issue.
Thanx,
Ganesh
Re: Problem creating links programatically using CreateRelationshipRequest [message #108544 is a reply to message #107992] |
Fri, 02 March 2007 09:50  |
Ganesh,
You can use a DeferredCreateConnectionViewAndElementCommand for this
purpose. Looks like there's an example of its use in
MindmapCreateSubtopicAction.
Cherie
Ganesh Mohan wrote:
> Hello,
> on a building block say - "source-element" (using the OpenEditPolicy
> using the "CreateElementRequest" and executing a command by passing this
> request.
> to be created along with the element creation. Is there any way i can
> achieve this?? Can anyone please help me in resolving this issue.
> Thanx,
> Ganesh
FUDForum. Page generated in 0.04683 seconds
