[TCS]Create left-recursive syntax [message #9799] |
Mon, 31 March 2008 11:06  |
assuming I'd have a metamodel like this:
abstract class Expression {
class BinaryExpression extends Expression {
attribute left : Expression;
attribute right : Expression;
class Value extends Expression {
attribute value: String;
And assuming I'd have a syntax like that:
template BinaryExpression
: left "=" right
template Value
: value
Then this syntax is obviously left-recursive, and ANTLR writes the
following error:
[antlr:antlr3] error(210): The following sets of rules are mutually
left-recursive [binaryExpression, expression]
However, in theory it is possible to create ANTLR Grammars that can do
what I indended above, by using more grammar rules (separating recursive
from non-recursive rules).
Is there any way to achieve this for the scenario above without changing
the metamodel? What would be the best approach to create such a syntax?
Re: [TCS]Create left-recursive syntax [message #9825 is a reply to message #9799] |
Mon, 31 March 2008 12:16  |
When you have left recursion, you should use operatorTempltates and the
operator table.
You can for instance have a look at the FPath project from the TCS Zoo.
Frédéric Jouault
Thibault a écrit :
> : left "=" right
> template Value
> : value
> following error:
FUDForum. Page generated in 0.03887 seconds
