Home » Newcomers » Newcomers » How to see J2EE API documentation when hovering mouse over a class or method?
How to see J2EE API documentation when hovering mouse over a class or method? [message #107816] Thu, 06 October 2005 17:31 Go to next message
Originally posted by: wonblee1.yahoo.com
I can see the yellow popup from the Javadocs of my application, but how do
you incorporate the J2EE 1.4 API documentation? For example if I hover my
mouse over ActionForward, I only see
org.apache.struts.action.ActionForward in the yellow popup, but not the
description of it. I've downloaded the J2EE 1.4 API from Sun. Under
Project/Properties/Javadoc Location, I have the Javadoc location path set
to: file:/C:/j2eeapidocs/, which I can validate.
thanks a lot,
Won
Re: How to see J2EE API documentation when hovering mouse over a class or method? [message #107999 is a reply to message #107816] Fri, 07 October 2005 14:01 Go to previous message
Originally posted by: eclipse3.rizzoweb.com
wbl33 wrote:
> do you incorporate the J2EE 1.4 API documentation? For example if I
> hover my mouse over ActionForward, I only see
> set to: file:/C:/j2eeapidocs/, which I can validate.
1) This is a FAQ - please search previous messages before posting questions.
2) Eclipse uses the source attachment to generate the tool-tips (yellow
popup help boxes), not the Javadoc attachment. So you must attach the
source to the JARs you're using. There is a bugzilla request to change
that behavior, but it is not yet implemented.
3) the Struts code you are talking about is not part of J2EE - Struts is
an independent project from Jakarta/Apache, not Sun.
HTH,
Eric
Previous Topic:Uninstall plug-ins safely?
Next Topic:Are separate plugin directories possible ?
Current Time: Wed Aug 13 12:19:22 EDT 2025
Powered by FUDForum. Page generated in 0.07615 seconds
