Home » Language IDEs » C / C++ IDE (CDT) » Zip Exceptions in running Automated test suites
Zip Exceptions in running Automated test suites [message #107760] Mon, 28 June 2004 02:42
Hi all,
I have Eclipse RC2 with compatible CDT on Windows XP.
I got Zip exceptions when I ran the automated test suites for CDT-Debug UI
feature.
I have installed Zip,Unzip and other utilities properly and the necessary
variables are also set.
Could any help me to run these automated test sucessfully.
Thanks in Advance.
---------- have pasted the errors below for your perusal.---------------
testDebug Error error in opening zip file
java.util.zip.ZipException: error in opening zip file
at java.util.zip.ZipFile.open(Native Method)
at java.util.zip.ZipFile.<init>(ZipFile.java:124)
at java.util.zip.ZipFile.<init>(ZipFile.java:72)
org.eclipse.cdt.debug.testplugin.CProjectHelper.createCProje ctWithImport(CProjectHelper.java:50)
at org.eclipse.cdt.debug.core.tests.DebugTests.setUp(DebugTests .java:83)
at org.eclipse.test.EclipseTestRunner.run(EclipseTestRunner.jav a:322)
at org.eclipse.test.EclipseTestRunner.run(EclipseTestRunner.jav a:198)
at org.eclipse.test.EclipseTestRunner.main(EclipseTestRunner.ja va:133)
at org.eclipse.test.UITestApplication$3.run(UITestApplication.j ava:180)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:106)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:2916)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2645)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1375)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1346)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:252)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:96)
org.eclipse.test.UITestApplication.runApplication(UITestAppl ication.java:123)
at org.eclipse.test.UITestApplication.run(UITestApplication.jav a:55)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:272)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:128)
at org.eclipse.core.launcher.Main.basicRun(Main.java:186)
at org.eclipse.core.launcher.Main.run(Main.java:647)
at org.eclipse.core.launcher.Main.main(Main.java:631)
0.790
unknown Error error in opening zip file
org.eclipse.cdt.debug.core.tests.BreakpointTests.oneTimeSetU p(BreakpointTests.java:90)
org.eclipse.cdt.debug.core.tests.BreakpointTests$1.setUp(Bre akpointTests.java:150)
at junit.extensions.TestSetup$1.protect(TestSetup.java:18)
at junit.extensions.TestSetup.run(TestSetup.java:23)
0.000
testIsEquals Error error in opening zip file
org.eclipse.cdt.debug.core.tests.LocationTests.setUp(Locatio nTests.java:84)
Previous Topic:Which CDT version with eclipse 3.0.0?
Next Topic:Can't debug with CDT2.0M9 + Eclipse3.0M9
Current Time: Tue Jul 22 07:26:20 EDT 2025
Powered by FUDForum. Page generated in 0.02965 seconds
