Home » Eclipse Projects » Equinox » 3.4m6 and readonly directories.
3.4m6 and readonly directories. [message #107689] Mon, 07 April 2008 20:05 Go to next message
Originally posted by: r-c-l-e-v-e-n-g-remove-dashes.g-m-ai-l.com
I've been digging through the archive and wiki, but can't find anything
on this.
I grabbed the 3.4M6 SDK archive (eclipse-SDK-3.4M6-linux-gtk.tar.gz) and
unzipped it into /opt/eclipse (as I did with 3.3) as root where it's
read only for all users.
When I run eclipse as my user, I get an exception at startup, however if
I make /opt/eclipse writable it works.
Here's the command I use: /opt/eclipse/eclipse -configuration
/tmp/eclipse34config -data /tmp/eclipse34workspace
Here's the exception:
!SESSION 2008-04-07 16:44:14.933
eclipse.buildId=I20080330-1350
java.version=1.6.0_01
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Command-line arguments: -os linux -ws gtk -arch x86 -data /tmp/w4
!ENTRY org.eclipse.osgi 4 0 2008-04-07 16:44:15.441
!MESSAGE Application error
!STACK 1
java.lang.IllegalStateException: Unable to acquire application service.
Ensure that the org.eclipse.core.runtime bundle is resolved and started
(see config.ini).
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:74)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:362)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:175)
Is this a bug, or just a limitation that will go away with the next
milestone.
Rob
Re: 3.4m6 and readonly directories. [message #107741 is a reply to message #107689] Tue, 08 April 2008 09:34 Go to previous message
Hi Rob,
You should log a bug to help ensure it's not in the next milestone ;)
-Simon
"Rob Clevenger" <r-c-l-e-v-e-n-g-remove-dashes@g-m-ai-l.com> wrote in
message news:ftecs9$5tj$1@build.eclipse.org...
> I've been digging through the archive and wiki, but can't find anything on
> this.
> unzipped it into /opt/eclipse (as I did with 3.3) as root where it's read
> only for all users.
> When I run eclipse as my user, I get an exception at startup, however if I
> !SESSION 2008-04-07
> 16:44:14.933 -----------------------------------------------
> !STACK 1
> (see config.ini).
> at
> at
> at
> at
> at
> at java.lang.reflect.Method.invoke(Method.java:597)
> at
> milestone.
> Rob
Previous Topic:ClassCastException when using BundleContext.getService()
Next Topic:Equinox base Application/Applet
Current Time: Sun Aug 31 13:26:18 EDT 2025
Powered by FUDForum. Page generated in 0.03121 seconds
