Home » Modeling » GMF (Graphical Modeling Framework) » Question about Feature Seq Initializer
Question about Feature Seq Initializer [message #107521] Wed, 28 February 2007 05:35 Go to next message
Hy there,
I want to get the creation of a child node, if the parent node will be
created. In the Feature Value Spec of the parent node there is the
ability to create a java body. Can I only put the name of the method
there? And then if the code of .gmfgen is generated, I have to put the
implementation for the method in the ElementInitializer.java of the
generated code for the .diagram? I also checked the way to overwrite
the doDefaultElementCreation() of the parent node.
The both results are perfect.
The only problem I have, is that everytime I regenerate the diagram with
..gmfgen, the code is away.
Is there an ability to get the code locked or to implement the code
somewhere in the .gmfmap or .gmfgen?
Greetings
Jens
Re: Question about Feature Seq Initializer [message #107616 is a reply to message #107521] Wed, 28 February 2007 06:19 Go to previous messageGo to next message
Hello Jens,
> with .gmfgen, the code is away.
Specify "@generated NOT" javadoc comment (or remove "@generated" tag) to
save custom method on next regeneration.
Alex Shatalin
Re: Question about Feature Seq Initializer [message #107705 is a reply to message #107616] Wed, 28 February 2007 07:51 Go to previous message
oh yeah thanks! Now I can see that the hint was already in the generated
source code. :(
Greetings
Jens
Alex Shatalin schrieb:
> Hello Jens,
> Alex Shatalin
Previous Topic:issue with "duplicate" feature and compartments
Next Topic:conditional display patterns?
Current Time: Thu Jul 17 20:36:31 EDT 2025
Powered by FUDForum. Page generated in 0.05907 seconds
