JDT Hacking Questions (CVS, Branches, Config, etc) [message #107506] |
Sat, 18 October 2003 12:22  |
Originally posted by: derisor.arcor.de
Greetings,
I am interested in doing some stuff on the JDT core (sepcifically the code
formatter). I read abotu how to use CVS on the site and still I have some
questions.
1) Is the M4 development on the Head of the repository? If not, what tag do I
use to pull this from the repository.
2) How should one submit patches?
3) In order do develop on the JDT core, what do I need to do to my eclipse
platform so that the runtime workbench runs the JDT I am developing on and not
the one that comes with eclipse.
4) Is there anthign else I should know about messing with the JDT code? Gotchas
or things that will make me tear out what little hair I have left?
TIA
-- Robert
Re: JDT Hacking Questions (CVS, Branches, Config, etc) [message #107625 is a reply to message #107612] |
Sun, 19 October 2003 14:01   |
"Daniel Megert" <daniel.megert@gmx.net> wrote in message
news:bmui3c$igd$1@eclipse.org...
> Robert Simmons wrote:
> >Greetings,
> >questions.
> No. HEAD is the newest code. There is no overall tag for M4. You have to
> checkout org.eclipse.releng tagged "v200310101454".
Ok but the latest version is probably what I want to submit on. Fewer conflicts.
> Attach to the corresponding bug report or feature request.
What I mean is do I send in diffs, full files, what ?.
not
> Nothing special assuming you launch using Run-time Workbench.
I checked out the followign modules
org.eclipse.jdt.core
org.eclipse.jdt.core.tests.builder
org.eclipse.jdt.core.tests.compiler
org.eclipse.jdt.core tests.model
org.eclipse.jdt.ui
However, I get multiple compiler bugs with classes not found. Specifically
projects not found.
ie:
Severity Description Resource In Folder Location Creation Time
Project org.eclipse.jdt.core is missing required Java project:
'org.eclipse.text'. org.eclipse.jdt.core October 19, 2003 8:00:16 PM
'org.apache.ant'. org.eclipse.jdt.core October 19, 2003 8:00:16 PM
etc....
Do I have to check out the source to the entire eclipse or can I just use the
other parts Im not editing?
> HTH
> Dani
Gotchas
> >TIA
> >-- Robert
FUDForum. Page generated in 0.02591 seconds
