Home » Eclipse Projects » Equinox » importing existing projects programmatically
importing existing projects programmatically [message #107485] Wed, 02 April 2008 19:17
Originally posted by: sureshpendap.gmail.com
I have a set of eclipse projects with .project and the .classpath files on
the filesystem. I would like import thse projects into a new workspace
programatically (something similar to new --> java project --> import from
existing source in the eclipse workbench). It would be better if the
source is not literally copied into the workspace directory.
Is it possible to acheive the above task programmatically. I googled for
some solution but all the links provide ways of creating fresh java
projects programmatically.
Previous Topic:using p2 to replace a plugin in 3.4m6
Next Topic:M6 with p2 removed - still not detecting some plugins
Current Time: Wed Aug 13 14:21:54 EDT 2025
Powered by FUDForum. Page generated in 0.03432 seconds
