Build problem after VE crash [message #107008] |
Sat, 17 September 2005 17:20  |
Originally posted by: kevin.atg.ca
I tried to use VE to open a view that I had started to create manually. VE didn't render it properly and when I closed the view my system blue-screened. Now I can't build the project, I get the following in the error log (3 nested errors).
Error 2005-09-16 12:34:03.788 JavaBuilder handling ImageBuilderInternalException while building: Test Web Monitor
org.eclipse.core.internal.resources.ResourceException: Problems encountered while copying resources.
at org.eclipse.core.internal.localstore.FileSystemResourceManag er.copy(FileSystemResourceManager.java:147)
at org.eclipse.core.internal.resources.Resource.copy(Resource.j ava:536)
at org.eclipse.jdt.internal.core.builder.BatchImageBuilder$4.vi sit(BatchImageBuilder.java:228)
at org.eclipse.core.internal.resources.Resource$1.visitElement( Resource.java:50)
at org.eclipse.core.internal.watson.ElementTreeIterator.doItera tion(ElementTreeIterator.java:81)
at org.eclipse.core.internal.watson.ElementTreeIterator.doItera tion(ElementTreeIterator.java:85)
at org.eclipse.core.internal.watson.ElementTreeIterator.iterate (ElementTreeIterator.java:126)
at org.eclipse.core.internal.resources.Resource.accept(Resource .java:60)
at org.eclipse.jdt.internal.core.builder.BatchImageBuilder.copy ExtraResourcesBack(BatchImageBuilder.java:198)
at org.eclipse.jdt.internal.core.builder.BatchImageBuilder.clea nOutputFolders(BatchImageBuilder.java:131)
at org.eclipse.jdt.internal.core.builder.BatchImageBuilder.buil d(BatchImageBuilder.java:36)
at org.eclipse.jdt.internal.core.builder.JavaBuilder.buildAll(J avaBuilder.java:213)
at org.eclipse.jdt.internal.core.builder.JavaBuilder.build(Java Builder.java:141)
at org.eclipse.core.internal.events.BuildManager$2.run(BuildMan ager.java:593)
at org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1044)
at org.eclipse.core.runtime.Platform.run(Platform.java:783)
at org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:168)
at org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:202)
at org.eclipse.core.internal.events.BuildManager$1.run(BuildMan ager.java:231)
at org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:234)
at org.eclipse.core.internal.events.BuildManager.basicBuildLoop (BuildManager.java:253)
at org.eclipse.core.internal.events.BuildManager.build(BuildMan ager.java:282)
at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBu ildJob.java:139)
at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJ ob.java:200)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:76)
Error 2005-09-16 12:34:03.788 Problems encountered while copying resources.
Error 2005-09-16 12:34:03.788 Could not read metadata for: C:\data\workspace\.metadata\.plugins\org.eclipse.core.resour ces\.projects\Test Web Monitor\.indexes\85\81\c9\86\properties.index.
java.io.EOFException
at java.io.DataInputStream.readByte(Unknown Source)
at org.eclipse.core.internal.properties.PropertyBucket.readEntr yValue(PropertyBucket.java:251)
at org.eclipse.core.internal.localstore.Bucket.load(Bucket.java :300)
at org.eclipse.core.internal.properties.PropertyBucket.load(Pro pertyBucket.java:243)
at org.eclipse.core.internal.localstore.Bucket.load(Bucket.java :267)
at org.eclipse.core.internal.localstore.BucketTree.internalAcce pt(BucketTree.java:89)
at org.eclipse.core.internal.localstore.BucketTree.accept(Bucke tTree.java:67)
at org.eclipse.core.internal.properties.PropertyManager2.copyPr operties(PropertyManager2.java:96)
at org.eclipse.core.internal.properties.PropertyManager2.copy(P ropertyManager2.java:83)
at org.eclipse.core.internal.localstore.CopyVisitor.copyPropert ies(CopyVisitor.java:104)
at org.eclipse.core.internal.localstore.CopyVisitor.copy(CopyVi sitor.java:65)
at org.eclipse.core.internal.localstore.CopyVisitor.visit(CopyV isitor.java:185)
at org.eclipse.core.internal.localstore.UnifiedTree.accept(Unif iedTree.java:83)
at org.eclipse.core.internal.localstore.FileSystemResourceManag er.copy(FileSystemResourceManager.java:144)
eclipse.buildId=I20050627-1435
Any suggestions ?
Kevin McBrearty
Re: Build problem after VE crash [message #108080 is a reply to message #107275] |
Sat, 24 September 2005 15:42  |
Thanks Dave,
Checked around as you suggested but couldn't find anything suspicious. I finally just created a new project and imported the old one into it; everything seems to be working again.
Re: Build problem after VE crash [message #610802 is a reply to message #107008] |
Mon, 19 September 2005 09:56  |
Originally posted by: richkulp.us.NO_SPAM.ibm.com
This isn't related to the VE itself. It looks like the metadata cache
for JDT has got corrupted. Try doing a Project->Clean->Clean All and see
if that helps.
Rich Kulp
Re: Build problem after VE crash [message #610808 is a reply to message #107121] |
Mon, 19 September 2005 12:53  |
Hi Rich,
I tried that but no luck. I'm thinking of trying to import this project into a new project and see if that works, unless you can suggest something else.
Re: Build problem after VE crash [message #610814 is a reply to message #107199] |
Mon, 19 September 2005 22:58  |
Kevin McBrearty wrote:
> Hi Rich,
Check to make sure that none of the non java files in your source
directories are corrupted. If one of them is corrupted, it may not be
able to be copied to the output folder. Also check to make sure that
there are not corrupted files in your output folder. Also make sure
that non of the files in the output folder are read-only. This could
prevent the corresponding resource in the source folder from being
Re: Build problem after VE crash [message #610865 is a reply to message #107275] |
Thanks Dave,
FUDForum. Page generated in 0.28505 seconds
