Home » Language IDEs » AspectJ » Problem with dependant projects
Problem with dependant projects [message #9696] Sun, 10 November 2002 18:32 Go to next message
When I have to aspectj projects in my workspace and I include one of them in
the other (as a dependant) project, I am not able to compile my project, as
the class files are not found.
(Taking two normal java project this works).
Is this a bug in the plugin or do I have to handle it in a different way
than when using two normal java projects?
Greeting,
Alex
Re: Problem with dependant projects [message #11511 is a reply to message #9696] Tue, 26 November 2002 17:59 Go to previous message
Originally posted by: Mik.Kersten.parc.com
Hi Alex,
Inter-project dependencies are not currently supported for AspectJ projects.
You can work around this by producing a ".lst" file that contains the
dependancy. So if you have projects A and B one way to achieve that would
be to create a new configuration file (using the wizard) in prject B, and
add a reference to A's default configuration file by editing the text of
B/defaul.lst to include:
@../A/default.lst
Sine A/default.lst is generated automatically for every build of project A
this will keep the list of sources that you're depending on in A up-to-date.
This is a bit akward, and we do plan on improving the UI for project
dependencies.
Mik
"Alexander Ny
Re: Problem with dependant projects [message #563043 is a reply to message #9696] Tue, 26 November 2002 17:59 Go to previous message
Hi Alex,
@../A/default.lst
dependencies.
Mik
"Alexander Ny
Previous Topic:AJDT Plugin Loading / Build Errors 2
Next Topic:Icons dont't display properly what can I do (bug?)
Current Time: Sat Jul 26 02:28:37 EDT 2025
Powered by FUDForum. Page generated in 0.03303 seconds
