Home » Archived » Test and Performance Tools Platform (TPTP) » TPTP profiler using SSH tunnel
TPTP profiler using SSH tunnel [message #106736] Thu, 26 July 2007 13:52 Go to next message
I am trying to profile a web application deployed on production
environment. I have successfully installed and tested the agent
controller on remote machine. I have modified the catalina.sh to
including profiling agent parameters and every thing is working fine. I
could verify from the logs (using MARTINI log setup).
I have created a ssh tunnel to the remove host. I could test the tunnel
successfully with telnet (telnet localhost 10002) and I see the port
accepting the connection.
However, Eclipse workbench is not able to attach to remote agent
controller. I have tried all listening port (10002, 10005, 10006).
Testing connection from Profile dialog box says Agent Controller is not
running or port is not correct. My thinking is Eclipse Profiler should
attach to SSH tunneled agent controller in a similar way to controller
running on the same machine (BTW, I tried it with local running agent
controller and it works fine).
Has anyone experienced similar problem?
Raj
Re: TPTP profiler using SSH tunnel [message #106804 is a reply to message #106736] Fri, 27 July 2007 15:11 Go to previous message
Replying to my thread. May be it can help others:
When open ssh tunnel give bind local bind address to a IP (e.g.
192.168.x.x) address other than loopback address
Raj
Raj Saini wrote:
> Raj
Previous Topic:When AGR resolvers are not used....
Next Topic:TPTP AGR runs from Linux with remote AC@Win32 but Freeze when collecting results
Current Time: Sun Aug 31 17:47:28 EDT 2025
Powered by FUDForum. Page generated in 0.03300 seconds
