AJDT Plugin Loading / Build Errors 2 [message #9675] |
Fri, 08 November 2002 04:30  |
Hi, got the same problem that was posted severall times:
Attempt to load class "org.eclipse.ajdt.internal.builder.Builder" from
deactivated plug-in
"org.eclipse.ajdt.ui".
However, this plug-in does not seem to be deactivated, as I still can
compile and run my aspectj project.
It happens, when I use a WizardNewFileCreationPage (subclassed in my plugin)
that creates a text file.
I attached the stacktrace. Maybe someone could give me a hint, what the
problem is.
!ENTRY org.eclipse.core.resources 4 2 Nov 08, 2002 10:23:41.462
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.core.resources".
!STACK 0
org.eclipse.core.internal.boot.DelegatingURLClassLoader$Dele gatingLoaderExce
ption: Attempt to load class "org.eclipse.ajdt.internal.builder.Builder"
from deactivated plug-in "org.eclipse.ajdt.ui".
org.eclipse.core.internal.plugins.PluginClassLoader.shouldLo okForClass(Plugi
nClassLoader.java:206)
org.eclipse.core.internal.plugins.PluginClassLoader.findClas sParentsSelf(Plu
ginClassLoader.java:125)
org.eclipse.core.internal.boot.DelegatingURLClassLoader.load Class(Delegating
URLClassLoader.java:750)
URLClassLoader.java:730)
at java.lang.ClassLoader.loadClass(ClassLoader.java:255)
org.eclipse.core.internal.plugins.PluginDescriptor.createExe cutableExtension
(PluginDescriptor.java:127)
(PluginDescriptor.java:164)
org.eclipse.core.internal.plugins.ConfigurationElement.creat eExecutableExten
sion(ConfigurationElement.java:102)
org.eclipse.core.internal.events.BuildManager.instantiateBui lder(BuildManage
r.java:486)
org.eclipse.core.internal.events.BuildManager.initializeBuil der(BuildManager
..java:441)
org.eclipse.core.internal.events.BuildManager.getBuilder(Bui ldManager.java:3
27)
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:1
65)
86)
org.eclipse.core.internal.events.BuildManager$1.run(BuildMan ager.java:146)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java
:839)
at org.eclipse.core.runtime.Platform.run(Platform.java:416)
60)
org.eclipse.core.internal.events.BuildManager.build(BuildMan ager.java:211)
org.eclipse.core.internal.resources.Workspace.endOperation(W orkspace.java:74
5)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1383)
org.eclipse.ui.actions.WorkspaceModifyOperation.run(Workspac eModifyOperation
..java:78)
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext
..java:98)
!ENTRY org.eclipse.core.resources 4 2 Nov 08, 2002 10:23:41.472
!STACK 0
r.java:486)
..java:441)
27)
65)
86)
:839)
60)
5)
..java:78)
..java:98)
Re: AJDT Plugin Loading / Build Errors 2 [message #11476 is a reply to message #9675] |
Tue, 26 November 2002 17:36  |
Originally posted by: Mik.Kersten.parc.com
Hi Alexander,
Could you please describe the details of how you got into this state and
submit a bug report at:
http://bugs.eclipse.org/bugs/enter_bug.cgi?product=AJDT ?
The previous post that you refer to has a work-around for getting out of the
deactivated plug-in state, but I've never encountered a deactivated ajdt
plug-in that could still compile. Also let us know whether or not this
state persisted across Eclipse invocations.
Mik
"Alexander Ny
FUDForum. Page generated in 0.08394 seconds
