Home » Archived » M2M (model-to-model transformation) » [ATL] - How can I get the result from the amount of abstract classes (ECORE)
[ATL] - How can I get the result from the amount of abstract classes (ECORE) [message #106713] |
Wed, 17 June 2009 17:57 |
Lucas Schubert Messages: 11 Registered: July 2009 |
Hey all,
I've one question!
I'm trying to count the amount of abstract classes from one EPackage using
ATL. (ECore)
If I execute the following command line in Interactive OCL, it works:
self.eClassifiers->select(c|c.oclIsTypeOf(EClass)).oclAsType(EClass)- >select(d|
d.abstract = true)->size()
The following code, is the implementation in ATL!
helper context Source!EPackage def: getQtAbstractClasses : Integer =
self.eClassifiers-> select(c|c.oclIsTypeOf(Source!EClass)).oclAsType(Source!ECla ss)- >select(d|
d.abstract = true)->size();
P.S.: Source = ECORE
This implementation is not working, the error msg is shown bellow:
SEVERE: ****** BEGIN Stack Trace
SEVERE: message: ERROR: could not find operation oclAsType on
Sequence(OclAny) having supertypes: [Collection(OclAny)]
SEVERE: A.main() : ??#36 null
SEVERE: local variables = {self=ATL_NOCM : ASMModule}
SEVERE: local stack = []
SEVERE: A.__exec__() : ??#8 null
SEVERE: local variables = {self=ATL_NOCM : ASMModule, e=TransientLink
{rule = 'MainBody', sourceElements = {vs = IN!Airplane}, targetElements =
{vResults = OUT!<unnamed>, vResult2 = OUT!<unnamed>, vResult =
OUT!<unnamed>}, variables = {}}}
SEVERE: A.__applyMainBody(1 : NTransientLink;) : ??#83 25:20-25:41
SEVERE: local variables = {vResults=OUT!<unnamed>,
vResult2=OUT!<unnamed>, vs=IN!Airplane, self=ATL_NOCM : ASMModule,
vResult=OUT!<unnamed>, link=TransientLink {rule = 'MainBody',
sourceElements = {vs = IN!Airplane}, targetElements = {vResults =
OUT!<unnamed>, vResult2 = OUT!<unnamed>, vResult = OUT!<unnamed>},
variables = {}}}
SEVERE: local stack = [OUT!<unnamed>, OUT!<unnamed>, ATL_NOCM : ASMModule]
SEVERE: MSource!EPackage;.__initgetAbstractClasses() : ??#23 10:4-10:86
SEVERE: local variables = {self=IN!Airplane, null=IN!Body}
SEVERE: local stack = [Sequence {}]
SEVERE: ****** END Stack Trace
INFO: Execution terminated due to error (see launch configuration to allow
continuation after errors).
SEVERE: ERROR: could not find operation oclAsType on Sequence(OclAny)
java.lang.RuntimeException: ERROR: could not find operation oclAsType on
at
org.eclipse.m2m.atl.engine.vm.SimpleDebugger.error(SimpleDeb ugger.java:195)
at
org.eclipse.m2m.atl.engine.vm.StackFrame.printStackTrace(Sta ckFrame.java:95)
at
org.eclipse.m2m.atl.engine.vm.StackFrame.printStackTrace(Sta ckFrame.java:91)
at
org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny.invoke(ASM OclAny.java:103)
at
org.eclipse.m2m.atl.engine.vm.ASMOperation.realExec(ASMOpera tion.java:240)
at org.eclipse.m2m.atl.engine.vm.ASMOperation.exec(ASMOperation .java:171)
at
org.eclipse.m2m.atl.engine.vm.ASMExecEnv.getHelperValue(ASME xecEnv.java:322)
at
org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny.getHelper( ASMOclAny.java:168)
at
org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModelElement.get(A SMEMFModelElement.java:138)
at
org.eclipse.m2m.atl.engine.vm.ASMOperation.realExec(ASMOpera tion.java:301)
at
org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny.invoke(ASM OclAny.java:143)
at
org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny.invoke(ASM OclAny.java:101)
at
at
org.eclipse.m2m.atl.engine.vm.ASMOperation.realExec(ASMOpera tion.java:338)
at
at
at
at
org.eclipse.m2m.atl.engine.vm.ASMInterpreter.<init>(ASMInterpreter.java:299)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:169)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:111)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:87)
at
org.eclipse.m2m.atl.adt.launching.AtlRegularVM.runAtlLaunche r(AtlRegularVM.java:326)
at
org.eclipse.m2m.atl.adt.launching.AtlRegularVM.runAtlLaunche r(AtlRegularVM.java:426)
at
org.eclipse.m2m.atl.adt.launching.AtlRegularVM.launch(AtlReg ularVM.java:398)
at
org.eclipse.m2m.atl.adt.launching.AtlLaunchConfigurationDele gate.launch(AtlLaunchConfigurationDelegate.java:42)
at
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:764)
at
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:614)
at
org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:865)
at
org.eclipse.debug.internal.ui.DebugUIPlugin$8.run(DebugUIPlu gin.java:1068)
Could some one help me? Or maybe tell me where I can get more information
about it? 8)
Thanks in advance,
Lucas
Re: [ATL] - How can I get the result from the amount of abstract classes (ECORE) [message #106757 is a reply to message #106713] |
Thu, 18 June 2009 06:38 |
William Piers Messages: 301 Registered: July 2009 |
According to the doc
(http://wiki.eclipse.org/ATL/User_Guide#OclAny_operations), oclAsType
isn't implemented in ATL.
Here is a previous question similar to yours:
http://dev.eclipse.org/mhonarc/newsLists/news.eclipse.modeli ng.m2m/msg01963.html
In your case, as you previously did a "select", I think the "oclAsType"
is not mandatory.
William
Lucas a écrit :
> Hey all,
> I've one question! I'm trying to count the amount of abstract classes
> from one EPackage using ATL. (ECore)
> e=TransientLink {rule = 'MainBody', sourceElements = {vs = IN!Airplane},
> targetElements = {vResults = OUT!<unnamed>, vResult2 = OUT!<unnamed>,
> vResult = OUT!<unnamed>}, variables = {}}}
> variables = {}}}
> ASMModule]
> allow continuation after errors).
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> information about it? 8)
> Thanks in advance,
> Lucas
Current Time: Tue Jun 04 20:02:41 GMT 2024
Powered by FUDForum. Page generated in 0.04077 seconds
