backward compatibility of the 2.0RC designer [message #106687] |
Tue, 10 January 2006 05:34 |
Originally posted by: gilles.vandaele.advalvas.be
I have done many reports with previous versions of BIRT (Eclipse BIRT
Designer Version 1.0.1 Build <20051027-0843>)
They are not compatible with next designers:
When opening with a BIRT 2.0RC(0), I get a message:
'Unable to create this part due to an internal error. Reason for the
failure: An exception was thrown during initialization'
and I get the following stack trace in the 'Details' pane:
java.lang.ClassCastException
org.eclipse.birt.report.designer.internal.ui.editors.parts.A bstractMultiPageLayoutEditor.superSetInput(AbstractMultiPage LayoutEditor.java:558)
org.eclipse.birt.report.designer.ui.editors.IDEReportEditor. superSetInput(IDEReportEditor.java:252)
org.eclipse.birt.report.designer.internal.ui.editors.parts.A bstractMultiPageLayoutEditor.init(AbstractMultiPageLayoutEdi tor.java:723)
Is there no backward compatibility for the designer?
Is there a way to fix that quickly? (an XSL Transformation between
versions of the design files?)
Where can I find doc on the compatibility of versions.
Why doesn't the rptdesign xml files refers to a DTD or a schema to
validate them?
Can I find more info on the reason of the failure produced at
initialization?
Thanks.
FUDForum. Page generated in 0.02479 seconds
