Home » Modeling » GMF (Graphical Modeling Framework) » Problem with Mindmap Tutorial and M5
Problem with Mindmap Tutorial and M5 [message #106685] Sun, 25 February 2007 11:10 Go to next message
Originally posted by: sven.kaffille.wiai.uni-bamberg.de
--------------070403050704030903070801
Content-Type: text/plain; charset=ISO-8859-15
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hello everybody,
I tried to follow the Mindmap Tutorial Part 1 with eclipse 3.3 both M4
and M5.
When generating the GMF generator model (in both versions) I get the
error message:
Validation failed unexpectedly for 'Gen Top Level Node TopicEditPart'.
See log for details.
The log (attached to this message) shows 2 NullpointerExceptions.
Has anybody else the same problem or is there something wrong with my
eclipse installation?
Kind regards
sven
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.5 (MingW32)
iD8DBQFF4bUCJkyiyyNQFhIRAgUaAJ9s93nX+44uG4XgyqKDdNkB5A5B3gCe NHNT
diIXnPi1PS+yoiLAeAj+K2Q=
=vHIv
-----END PGP SIGNATURE-----
name=".log"
Content-Disposition: inline;
filename=".log"
!SESSION 2007-02-25 17:03:10.625 -----------------------------------------------
eclipse.buildId=I20070222-0951
java.version=1.5.0_10
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Framework arguments: -launcher c:\Programme\eclipse-SDK-3.3M5eh\eclipse\eclipse.exe -name Eclipse -startup c:\Programme\eclipse-SDK-3.3M5eh\eclipse\plugins\org.eclipse .equinox.launcher_1.0.0.v20070208a.jar
Command-line arguments: -os win32 -ws win32 -arch x86 -launcher c:\Programme\eclipse-SDK-3.3M5eh\eclipse\eclipse.exe -name Eclipse -startup c:\Programme\eclipse-SDK-3.3M5eh\eclipse\plugins\org.eclipse .equinox.launcher_1.0.0.v20070208a.jar
!ENTRY org.eclipse.core.resources 4 368 2007-02-25 17:05:10.906
!MESSAGE Resource '/mindmap/build.properties' does not exist.
!ENTRY org.eclipse.core.resources 4 368 2007-02-25 17:05:22.593
!MESSAGE Resource '/mindmap.edit/build.properties' does not exist.
!ENTRY org.eclipse.gmf.validate 4 300 2007-02-25 17:06:07.890
!MESSAGE Validation failed unexpectedly for 'Gen Top Level Node TopicEditPart'. See log for details.
!STACK 0
at org.eclipse.gmf.codegen.gmfgen.impl.GenNodeImpl.getReoriente dIncomingLinks(GenNodeImpl.java:524)
at org.eclipse.gmf.codegen.gmfgen.impl.GenNodeImpl.eIsSet(GenNo deImpl.java:327)
at org.eclipse.gmf.codegen.gmfgen.impl.GenTopLevelNodeImpl.eIsS et(GenTopLevelNodeImpl.java:122)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eIsSet(BasicEObj ectImpl.java:1190)
at org.eclipse.emf.ecore.util.EContentsEList$FeatureIteratorImp l.hasNext(EContentsEList.java:427)
at org.eclipse.emf.ecore.util.EContentsEList$FeatureIteratorImp l.next(EContentsEList.java:581)
at org.eclipse.emf.ecore.util.EObjectValidator.validate_EveryPr oxyResolves(EObjectValidator.java:339)
at org.eclipse.emf.ecore.util.EObjectValidator.validate_EveryDe faultConstraint(EObjectValidator.java:188)
at org.eclipse.emf.ecore.util.EObjectValidator.validate(EObject Validator.java:173)
at org.eclipse.emf.ecore.util.EObjectValidator.validate(EObject Validator.java:174)
at org.eclipse.gmf.internal.validate.ValidatorChain.validate(Va lidatorChain.java:67)
at org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostic ian.java:127)
at org.eclipse.gmf.internal.bridge.transform.ValidationHelper$S martDiagnostician.validate(ValidationHelper.java:96)
at org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostic ian.java:107)
at org.eclipse.emf.ecore.util.Diagnostician.doValidateContents( Diagnostician.java:146)
at org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostic ian.java:130)
at org.eclipse.emf.ecore.util.Diagnostician.doValidateContents( Diagnostician.java:142)
at org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostic ian.java:87)
at org.eclipse.gmf.internal.bridge.transform.ValidationHelper.v alidate(ValidationHelper.java:288)
at org.eclipse.gmf.internal.bridge.transform.TransformToGenMode lOperation.validate(TransformToGenModelOperation.java:370)
at org.eclipse.gmf.internal.bridge.transform.TransformToGenMode lOperation.executeTransformation(TransformToGenModelOperatio n.java:264)
at org.eclipse.gmf.internal.bridge.transform.TransformToGenMode lWizard$1.run(TransformToGenModelWizard.java:127)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:369)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:313)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 890)
at org.eclipse.gmf.internal.bridge.transform.TransformToGenMode lWizard.performFinish(TransformToGenModelWizard.java:130)
at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:695)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:367)
at org.eclipse.jface.dialogs.Dialog$3.widgetSelected(Dialog.jav a:638)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:215)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3490)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3104)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:820 )
at org.eclipse.jface.window.Window.open(Window.java:796)
at org.eclipse.gmf.internal.bridge.transform.TransformToGenMode lAction.run(TransformToGenModelAction.java:55)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:253)
at org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:545)
at org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:490)
at org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:402)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2264)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2228)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 03)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:457)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:452)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:101)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:146)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:354)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:169)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 476)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:416)
at org.eclipse.equinox.launcher.Main.run(Main.java:1124)
!ENTRY org.eclipse.gmf.validate 4 300 2007-02-25 17:06:07.906
!MESSAGE Validation failed unexpectedly for 'Type Model Facet'. See log for details.
!STACK 0
at org.eclipse.emf.ecore.util.EcoreUtil$CrossReferencer.handleC rossReference(EcoreUtil.java:1643)
at org.eclipse.emf.ecore.util.EcoreUtil$CrossReferencer.crossRe ference(EcoreUtil.java:1618)
at org.eclipse.emf.ecore.util.EcoreUtil$ExternalCrossReferencer .findExternalCrossReferences(EcoreUtil.java:1855)
at org.eclipse.emf.ecore.util.EcoreUtil$ExternalCrossReferencer .find(EcoreUtil.java:1867)
at org.eclipse.gmf.internal.validate.ExternModelImport.intializ eExternPackages(ExternModelImport.java:124)
at org.eclipse.gmf.internal.validate.AbstractValidator.getExpre ssion(AbstractValidator.java:74)
at org.eclipse.gmf.internal.validate.AbstractValidator.getExpre ssion(AbstractValidator.java:58)
at org.eclipse.gmf.internal.validate.AnnotatedOclValidator$Cons traintHandler.handleEAnnotation(AnnotatedOclValidator.java:1 29)
at org.eclipse.gmf.internal.validate.AnnotatedOclValidator$Cons traintHandler.handleMetaModel(AnnotatedOclValidator.java:225 )
at org.eclipse.gmf.internal.validate.AnnotatedOclValidator.vali dateOCL(AnnotatedOclValidator.java:91)
at org.eclipse.gmf.internal.validate.AnnotatedOclValidator.vali date(AnnotatedOclValidator.java:75)
!MESSAGE Validation failed unexpectedly for 'Type Link Model Facet RelationshipTypeLinkCreateCommand'. See log for details.
!STACK 0
at org.eclipse.gmf.internal.validate.AnnotatedOclValidator$Cons traintHandler.handleMetaModel(AnnotatedOclValidator.java:233 )
--------------070403050704030903070801--
Re: Problem with Mindmap Tutorial and M5 [message #106701 is a reply to message #106685] Sun, 25 February 2007 12:39 Go to previous message
Hash: SHA1
I think I resolved the problem.
The gmfmap model was not valid, but I do not exactly know where I made
the mistake so I started from scratch.
Kind regards
sven
iD8DBQFF4cm0JkyiyyNQFhIRAv1hAJ0dryKQ36VMFZ7wdj3ZOtYMbBy4RACe NmiD
c+MOmQ1nHCLIP/IvoBY4fm8=
=SwTR
Previous Topic:Strange thing about View.getChildren
Next Topic:How can I add a new Listener to a SematicElement
Current Time: Fri Jul 18 10:19:19 EDT 2025
Powered by FUDForum. Page generated in 0.08055 seconds
