Home » Archived » Test and Performance Tools Platform (TPTP) » AGR suites in JUnit
AGR suites in JUnit [message #106623] |
Thu, 26 July 2007 08:30  |
Originally posted by: cl.silistix.com
--------------010904070309050007050509
Hi all,
I've been trying to launch my AGR test suites in a JUnit Suite but am
having no luck. Is there a reliable way to do this?
At the moment I am attempting to use AutomationClientAdapter to launch
the suite.. the second instance of eclipse will launch but no cases will
be executed. The eclipse instance I used to launch the test reports the
attached error.
The code I am using to launch my test suite is also attached.
I am running eclipse3.3, TPTP4.4 on RHEL4.
Is there another way to launch AGR suites programatically? How are they
launched in standard mode within eclipse? Is there anything documenting
how eclipse launches AGR suites?
Any help/documents would be much appreciated.
Craig
name="code"
Content-Disposition: inline;
filename="code"
public class AllTests {
public static Test suite() {
TestSuite suite = new TestSuite("Test for com.silistix.csl.tests");
//$JUnit-BEGIN$
AutomationClientAdapter adapter = new AutomationClientAdapter("/home/cl/CA-Testing/eclipse/");
Properties props = new Properties();
props.setProperty("workspace", "/home/cl/workspace");
props.setProperty("project", "com.silistix.csl.tests");
props.setProperty("suite", "tests/DesignFlowTestsPass.testsuite");
adapter.execute("org.eclipse.hyades.test.tools.core.execute ", props);
//$JUnit-END$
return suite;
name="error"
filename="error"
Exception in thread "WorkbenchTestable" org.eclipse.swt.SWTException: Failed to execute runnable (java.lang.NoClassDefFoundError: junit/framework/Test)
at org.eclipse.swt.SWT.error(SWT.java:3563)
at org.eclipse.swt.SWT.error(SWT.java:3481)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.j ava:178)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchroniz er.java:118)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:3897)
at org.eclipse.ui.internal.testing.WorkbenchTestable.runTest(Wo rkbenchTestable.java:109)
at org.eclipse.pde.internal.junit.runtime.UITestApplication.run Tests(UITestApplication.java:120)
at org.eclipse.ui.internal.testing.WorkbenchTestable$1.run(Work benchTestable.java:68)
at java.lang.Thread.run(Thread.java:595)
Caused by: java.lang.NoClassDefFoundError: junit/framework/Test
at java.lang.Class.getDeclaredMethods0(Native Method)
at java.lang.Class.privateGetDeclaredMethods(Class.java:2365)
at java.lang.Class.getMethod0(Class.java:2611)
at java.lang.Class.getMethod(Class.java:1579)
at org.junit.internal.requests.ClassRequest.hasSuiteMethod(Clas sRequest.java:62)
at org.junit.internal.requests.ClassRequest.getRunnerClass(Clas sRequest.java:50)
at org.junit.internal.requests.ClassRequest.getRunner(ClassRequ est.java:28)
at org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.<init >(JUnit4TestReference.java:26)
at org.eclipse.jdt.internal.junit4.runner.JUnit4TestClassRefere nce. <init>(JUnit4TestClassReference.java:24)
at org.eclipse.jdt.internal.junit4.runner.JUnit4TestLoader.crea teTest(JUnit4TestLoader.java:40)
at org.eclipse.jdt.internal.junit4.runner.JUnit4TestLoader.load Tests(JUnit4TestLoader.java:30)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:445)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:673)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(R emoteTestRunner.java:386)
at org.eclipse.pde.internal.junit.runtime.RemotePluginTestRunne r.main(RemotePluginTestRunner.java:58)
at org.eclipse.pde.internal.junit.runtime.UITestApplication$1.r un(UITestApplication.java:122)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3296)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2974)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:461)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:106)
at org.eclipse.pde.internal.junit.runtime.UITestApplication.sta rt(UITestApplication.java:52)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:153)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 504)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:443)
at org.eclipse.equinox.launcher.Main.run(Main.java:1169)
at org.eclipse.equinox.launcher.Main.main(Main.java:1144)
--------------010904070309050007050509--
Re: AGR suites in JUnit [message #106667 is a reply to message #106653] |
Thu, 26 July 2007 09:52   |
Thanks Craig,
Are you doing this work in a Java project, or in a Plug-in Project? I
suggest, for simplicity, that you do it in a Plug-in Project. If we get
it working there, you can alway work backward to get the build/class
path correct in a Java Project.
So, in a Plug-in Project, please make sure you have a dependency on
org.junit and on org.eclipse.hyades.execution, and try to run the test
again. Please let me know how it goes.
--Joe
Craig Lang wrote:
> Hi Joe,
> Ahh yes my bad there.. I forgot to re-add junit to my projects
> dependencies.
> The trace I should have shown you is this one:
> org/eclipse/hyades/automation/client/adapters/java/Automatio nClientAdapter
> at com.silistix.csl.testsgui.AllTests.suite(AllTests.java:15)
> at
> at
> at org.junit.runners.AllTests.testFromSuiteMethod(AllTests.java :36)
> at org.junit.runners.AllTests.<init>(AllTests.java:25)
> at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Nativ e
> Method)
> at
> sun.reflect.NativeConstructorAccessorImpl.newInstance(Native ConstructorAccessorImpl.java:39)
> at
> sun.reflect.DelegatingConstructorAccessorImpl.newInstance(De legatingConstructorAccessorImpl.java:27)
> at java.lang.reflect.Constructor.newInstance(Constructor.java:4 94)
> at
> org.junit.internal.requests.ClassRequest.buildRunner(ClassRe quest.java:33)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Joe Toomey wrote:
>> Hi Craig,
>> I see no reason why what you're attempting should not work. I took a
>> look at the error stack, and it's not at all what I was expecting.
>> The error says that the junit.framework.Test class can't be found,
>> which is just part of the junit framework, and has nothing to do with
>> your invocation of ASF services. Can you confirm that, if you comment
>> out the ASF code, the test runs correctly? My guess is that it would
>> still fail.
>> Please let me know. Thanks,
>> --Joe
Re: AGR suites in JUnit [message #106708 is a reply to message #106667] |
Thu, 26 July 2007 10:18   |
Hi Joe,
I was working in a plug-in project. I had tptp-automation-client.jar
added to my build path originally.. removing that and adding a
dependency on org.eclipse.hyades.execution as you suggested allows my
tests to be launched.
I'm trying to launch my tests as a JUnit plugin so I can use EclEmma to
get code coverage stats. I'm not sure if it'll even work but I will keep
you informed.
Thanks for you help,
Craig
Joe Toomey wrote:
> Thanks Craig,
> --Joe
> Craig Lang wrote:
>> Hi Joe,
>> dependencies.
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> Method)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Joe Toomey wrote:
>>> Hi Craig,
>>> comment out the ASF code, the test runs correctly? My guess is that
>>> it would still fail.
>>> --Joe
Re: AGR suites in JUnit [message #106722 is a reply to message #106708] |
Thu, 26 July 2007 10:54  |
That's great news, Craig. Please keep us posted on your progress with
Emma -- I know Paul Slauenwhite (test project lead) has been doing some
work there, so he may have some tips as well.
--Joe
Current Time: Thu Jul 24 01:07:55 EDT 2025
Powered by FUDForum. Page generated in 0.06565 seconds
