Home » Modeling » Epsilon » Ant and epsilon.loadModel
Ant and epsilon.loadModel [message #9653] Wed, 28 January 2009 16:42 Go to next message
Hi list,
I've been tried to play with build.xml ant and epsilon tasks, but I stuck
on a problem :
Buildfile: /home/user/workspaces/symfonymodel1/mytestproj/build.xml
init:
[propertyfile] Updating property file:
/home/user/workspaces/symfonymodel1/mytestproj/properties
loadModel:
[epsilon.loadModel] java.lang.NullPointerException
[epsilon.loadModel] at
org.eclipse.epsilon.emc.emf.EmfUtil.collectDependencies(EmfU til.java:64)
org.eclipse.epsilon.emc.emf.EmfModel.loadModel(EmfModel.java :157)
org.eclipse.epsilon.emc.emf.EmfModel.load(EmfModel.java:91)
org.eclipse.epsilon.emc.emf.EmfModel.load(EmfModel.java:85)
org.eclipse.epsilon.workflow.tasks.LoadModelTask.executeImpl (LoadModelTask.java:49)
org.eclipse.epsilon.workflow.tasks.EpsilonTask.execute(Epsil onTask.java:41)
org.apache.tools.ant.UnknownElement.execute(UnknownElement.j ava:288)
sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
[epsilon.loadModel] at java.lang.reflect.Method.invoke(Method.java:597)
org.apache.tools.ant.dispatch.DispatchUtils.execute(Dispatch Utils.java:105)
[epsilon.loadModel] at org.apache.tools.ant.Task.perform(Task.java:348)
org.apache.tools.ant.Target.execute(Target.java:357)
org.apache.tools.ant.Target.performTasks(Target.java:385)
org.apache.tools.ant.Project.executeSortedTargets(Project.ja va:1329)
org.apache.tools.ant.Project.executeTarget(Project.java:1298 )
org.apache.tools.ant.helper.DefaultExecutor.executeTargets(D efaultExecutor.java:41)
org.eclipse.ant.internal.core.ant.EclipseDefaultExecutor.exe cuteTargets(EclipseDefaultExecutor.java:32)
org.apache.tools.ant.Project.executeTargets(Project.java:118 1)
org.eclipse.ant.internal.core.ant.InternalAntRunner.run(Inte rnalAntRunner.java:623)
org.eclipse.ant.internal.core.ant.InternalAntRunner.run(Inte rnalAntRunner.java:456)
org.eclipse.ant.core.AntRunner.run(AntRunner.java:378)
org.eclipse.ant.internal.ui.launchConfigurations.AntLaunchDe legate$1.run(AntLaunchDelegate.java:247)
[epsilon.loadModel] at java.lang.Thread.run(Thread.java:619)
BUILD FAILED
/home/user/workspaces/symfonymodel1/mytestproj/build.xml:36:
Total time: 99 milliseconds
Here is my build.xml :
28 janv. 2009 22:05:18
generatePhp5Model
Generate Php5 artefacts from a Php5 Model instance
user
<project name="generatePhp5Model" default="default">
<description>
</description>
target: default
<target name="default" depends="init, loadModel" description="Generate
Php5 artefacts from a Php5 Model instance">
<epsilon.egl
src="platform:/php5.generator/src/php5/generator/generator.egl ">
</epsilon.egl>
</target>
target: init
<target name="init">
<propertyfile file="properties"></propertyfile>
</target>
target: loadModel
<target name="loadModel">
<epsilon.loadModel name="myModel" type="EMF">
<parameter name="modelFile" value="${inputModel}"/>
<parameter name="metamodelFile" value="http://php5"/>
<parameter name="isMetamodelFileBased" value="false"/>
<parameter name="readOnLoad" value="true"/>
<parameter name="storeOnDisposal" value="true"/>
</epsilon.loadModel>
</target>
</project>
I set the JRE as same as workspace as precised earlier in this list.
Thanks for any help !
Re: Ant and epsilon.loadModel [message #9676 is a reply to message #9653] Wed, 28 January 2009 16:51 Go to previous messageGo to next message
Hi Stephane,
Off the top of my head, the following two lines:
should be instead:
<parameter name="modelFile" file="${inputModel}"/>
<parameter name="metamodelUri" value="http://php5"/>
Hope this helps. If not, I'll have a closer look at it tomorrow morning.
Dimitris
Stephane wrote:
> Hi list,
> stuck on a problem :
> init:
> loadModel:
> BUILD FAILED
> 28 janv. 2009
> 22:05:18
> generatePhp5Model Generate Php5 artefacts from a Php5 Model
> instance
> user
> <description>
> </description>
> <!-- ================================= target:
> default ================================= -->
> description="Generate Php5 artefacts from a Php5 Model instance">
> <epsilon.egl
> </epsilon.egl>
> </target>
> <!-- - - - - - - - - - - - - - - - - - target:
> init - - - - - - - - - - - - - - - - - -->
> </target>
> loadModel - - - - - - - - - - - - - - - - -
> </target>
> </project>
Re: Ant and epsilon.loadModel [message #9697 is a reply to message #9676] Wed, 28 January 2009 17:38 Go to previous messageGo to next message
Thanks !
It's not fully working because I use the ${inputModel} and I don't know
why it doesn't work. Anyway I put model/php5.model but I still get error
about FileNotFound.
In fact, I have the .egl file in one project, and a build.xml in another
project.
The build.xml call the egl in the first project.
The problem here is that I don't know how to address a egl cross projects
(at dev time, what about when exported as plugin ?)
This is the error stacktrace :
init:
loadModel:
default:
[../php5.generator/src/php5/generator/generator.egl] EXCEPTION:
java.io.FileNotFoundException:
/home/user/workspaces/symfonymodel1/mytestproj/\/../php5.gen erator/src/php5/generator/generator.egl
(Aucun fichier ou dossier de ce type)
[../php5.generator/src/php5/generator/generator.egl] at
java.io.FileInputStream.open(Native Method)
java.io.FileInputStream.<init>(FileInputStream.java:106)
java.io.FileReader.<init>(FileReader.java:55)
org.eclipse.epsilon.egl.EglModule.parse(EglModule.java:116)
org.eclipse.epsilon.workflow.tasks.ExecutableModuleTask.exec uteImpl(ExecutableModuleTask.java:77)
BUILD FAILED
/home/user/workspaces/symfonymodel1/mytestproj/build.xml:19:
Total time: 165 milliseconds
And the changes made to the build.xml :
<epsilon.egl src="../php5.generator/src/php5/generator/generator.egl">
instead of platform:/ which was not working too
<parameter name="modelFile" file="model/php5.model"/>
Thanks !!!
Re: Ant and epsilon.loadModel [message #9710 is a reply to message #9697] Thu, 29 January 2009 04:48 Go to previous messageGo to next message
--------------050200000902060808080606
Hi Stephane,
Having the EGL template and the ANT build file in two separate projects
should not cause any problems. To test this I've created two projects
XEGL1 and XEGL2 where the first contains the template and the second
contains the build file and it seems to work fine. I've attached the
projects. Could you please let me know if this minimal example runs OK
in your environment?
Dimitrios
Stephane wrote:
> Thanks !
> about FileNotFound.
> project.
> projects (at dev time, what about when exported as plugin ?)
> init:
> loadModel:
> default:
> BUILD FAILED
> Thanks !!!
Content-Type: application/x-zip-compressed;
name="xegl.zip"
Content-Disposition: inline;
filename="xegl.zip"
UEsDBAoAAAAAACVNPToAAAAAAAAAAAAAAAAGAAAAWEVHTDIvUEsDBBQAAAAI AAtNPTqg5EBK
gAAAANEAAAAOAAAAWEVHTDIvLnByb2plY3Szsa/IzVEoSy0qzszPs1Uy1DNQ UkjNS85PycxL
t1UKDXHTtVCyt+Plsikoys9KTS5xSS1OLsosKAGqBopy2uQl5qbaRbi6+xjZ 6IPZIMHk/Nzc
1LwSOxt9GAskCjWhGMzRR+EllWbmpAQXpCZD5FC5eYklpUWpUG0IDtwIVCcB AFBLAwQUAAAA
CABHTT06huxtMZMAAAAqAQAADwAAAFhFR0wyL2J1aWxkLnhtbIWQsQ4CIQyG Z0nuHSo7R1wN
sBkXH8CVcPWC4YAAvr+HR1Cn+6e2+fL/bUVM4YmmwIQP/XJF0kVbT9VADuLI GMg9AYGuotOM
5QzVAv70hfYNGVMfXGx24PWCba11y4h+ypLWMptkY7HBr63qCQJjti74EWcH ORlJx5HfL9fb
iVePOq7ndZz/8C2Yb8mKDETw9iD1BlBLAwQKAAAAAAAUTT06AAAAAAAAAAAA AAAABgAAAFhF
R0wxL1BLAwQUAAAACAAGTT06LpyDC4AAAADRAAAADgAAAFhFR0wxLy5wcm9q ZWN0s7GvyM1R
KEstKs7Mz7NVMtQzUFJIzUvOT8nMS7dVCg1x07VQsrfj5bIpKMrPSk0ucUkt Ti7KLCgBqgaK
ctrkJeam2kW4uvsY2uiD2SDB5Pzc3NS8EjsbfRgLJAo1oRjM0UfhJZVm5qQE F6QmQ+RQuXmJ
JaVFqVBtCA7cCFQnAQBQSwMECgAAAAAAHE09Or11Q0obAAAAGwAAAA4AAABY RUdMMS9tYWlu
LmVnbFslDQoJJ0hlbGxvJy5wcmludGxuKCk7DQolXVBLAQIUAAoAAAAAACVN PToAAAAAAAAA
AAAAAAAGAAAAAAAAAAAAEAAAAAAAAABYRUdMMi9QSwECFAAUAAAACAALTT06 oORASoAAAADR
AAAADgAAAAAAAAABACAAAAAkAAAAWEVHTDIvLnByb2plY3RQSwECFAAUAAAA CABHTT06huxt
MZMAAAAqAQAADwAAAAAAAAABACAAAADQAAAAWEVHTDIvYnVpbGQueG1sUEsB AhQACgAAAAAA
FE09OgAAAAAAAAAAAAAAAAYAAAAAAAAAAAAQAAAAkAEAAFhFR0wxL1BLAQIU ABQAAAAIAAZN
PTounIMLgAAAANEAAAAOAAAAAAAAAAEAIAAAALQBAABYRUdMMS8ucHJvamVj dFBLAQIUAAoA
AAAAABxNPTq9dUNKGwAAABsAAAAOAAAAAAAAAAEAIAAAAGACAABYRUdMMS9t YWluLmVnbFBL
BQYAAAAABgAGAFkBAACnAgAAAAA=
--------------050200000902060808080606--
Re: Ant and epsilon.loadModel [message #10223 is a reply to message #9710] Thu, 29 January 2009 08:25 Go to previous messageGo to next message
Hi Dimitrios,
Thanks for your try, but I still get the same error, it's about filepath.
Buildfile: /home/user/workspaces/symfonymodel1/xegl1/build.xml
main:
[../xegl2/main.egl] EXCEPTION: java.io.FileNotFoundException:
/home/user/workspaces/symfonymodel1/xegl1/\/../xegl2/main.eg l (Aucun
[../xegl2/main.egl] at java.io.FileInputStream.open(Native Method)
[../xegl2/main.egl] at java.io.FileReader.<init>(FileReader.java:55)
[../xegl2/main.egl] at java.lang.reflect.Method.invoke(Method.java:597)
[../xegl2/main.egl] at org.apache.tools.ant.Task.perform(Task.java:348)
[../xegl2/main.egl] at java.lang.Thread.run(Thread.java:619)
BUILD FAILED
/home/user/workspaces/symfonymodel1/xegl1/build.xml:3:
Total time: 134 milliseconds
I don't know why I get a \/ before the content of the src=""
<project default="main">
<target name="main" depends="" description="">
<epsilon.egl src='../xegl2/main.egl'></epsilon.egl>
</target>
</project>
I really don't know what's the point here.
Still searching, thanks !
Re: Ant and epsilon.loadModel [message #10250 is a reply to message #10223] Thu, 29 January 2009 08:39 Go to previous messageGo to next message
From your paths it seems you are on a Linux box. I'll try to find a
Linux box myself and troubleshoot this.
Dimitris
Stephane wrote:
> Hi Dimitrios,
> main:
> BUILD FAILED
> </target>
> </project>
Re: Ant and epsilon.loadModel [message #10283 is a reply to message #10250] Thu, 29 January 2009 08:41 Go to previous messageGo to next message
Exact I'm on a virtual machine exactly, but doesn't matter here.
Ubuntu 8.10 with vmware fusion
Thanks !
Re: Ant and epsilon.loadModel [message #10316 is a reply to message #10283] Thu, 29 January 2009 10:49 Go to previous messageGo to next message
I've managed to reproduce the problem under Linux. Could you please open
a new bug about this for tracking purposes?
Dimitris
> Thanks !
Re: Ant and epsilon.loadModel [message #10348 is a reply to message #10316] Thu, 29 January 2009 11:12 Go to previous messageGo to next message
I (think I) have fixed it. If you use Epsilon from the SVN please update
to pick up the fix. If you have installed through the update site and do
not wish to switch to SVN you can patch your existing installation by
replacing org.eclipse.epsilon.workflow.jar under
plugins\org.eclipse.epsilon.workflow_xxx\lib with the newest version:
http://dev.eclipse.org/viewsvn/index.cgi/trunk/plugins/org.e clipse.epsilon.workflow/lib/org.eclipse.epsilon.workflow.jar ?revision=221&root=Modeling_EPSILON
Thanks for reporting this!
Dimitris
> Cheers,
> Dimitris
>> Thanks !
Re: Ant and epsilon.loadModel [message #10382 is a reply to message #10348] Thu, 29 January 2009 11:36 Go to previous messageGo to next message
Hi Dimitrios,
Thanks for your rapid update !!
It definitively works as I get new errors =D
BUILD FAILED
/home/user/workspaces/symfonymodel1/mytestproj/build.xml:19: Undefined
variable, type or model: 'Class'
(/home/user/workspaces/symfonymodel1/php5.generator/src/php5 /generator/generator.egl@8:14)
The generator.egl works fine when ran from Eclipse Run as EGL, but not as
within a Ant task.
Here is the build.xml:
generatePhp5Model
user
<description>
</description>
target: default
</epsilon.egl>
</target>
target: init
</target>
target: loadModel
</target>
</project>
And the launch configuration (using export as launch) :
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<launchConfiguration
type=" org.epsilon.egl.eclipse.dt.launching.EglLaunchConfigurationD elegate ">
<booleanAttribute key="appendToFile" value="false"/>
<intAttribute key="generateTo" value="1"/>
<listAttribute key="models">
<listEntry value="#&#10;#Wed Jan 28 19:54:02 CET
2009&#10;isMetamodelFileBased=false&#10;name=model&a mp;#10;readOnLoad=true&#10;storeOnDisposal=true&#10; aliases=&#10;metamodelUri=http\://php5&#10 ;type=BridgeEMF&#10;modelFile=/mytestproj/model/php5.mod el&#10;expand=false&#10;metamodelFile=&#10; "/>
</listAttribute>
<listAttribute key="org.eclipse.debug.ui.favoriteGroups">
<listEntry value="org.eclipse.debug.ui.launchGroup.run"/>
</listAttribute>
<stringAttribute key="outputFilePath" value=""/>
<stringAttribute key="source"
value="/php5.generator/src/php5/generator/generator.egl"/>
</launchConfiguration>
Re: Ant and epsilon.loadModel [message #10413 is a reply to message #10382] Thu, 29 January 2009 11:43 Go to previous messageGo to next message
I've tried with file based, but got the same error :
<parameter name="metamodelFile" file="../php5.model/model/php5.ecore"/>
<parameter name="isMetamodelFileBased" value="true"/>
</target>
Complete stack trace:
init:
loadModel:
default:
[generator.egl] EXCEPTION: Undefined variable, type or model: 'Class'
[generator.egl] at
org.eclipse.epsilon.egl.EglModule.execute(EglModule.java:191 )
[generator.egl] at
org.eclipse.epsilon.egl.EglModule.execute(EglModule.java:1)
[generator.egl] at
org.eclipse.epsilon.workflow.tasks.ExecutableModuleTask.exec uteImpl(ExecutableModuleTask.java:106)
[generator.egl] at
[generator.egl] at
[generator.egl] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native
Method)
[generator.egl] at
[generator.egl] at
[generator.egl] at java.lang.reflect.Method.invoke(Method.java:597)
[generator.egl] at
[generator.egl] at org.apache.tools.ant.Task.perform(Task.java:348)
[generator.egl] at org.apache.tools.ant.Target.execute(Target.java:357)
[generator.egl] at
[generator.egl] at
[generator.egl] at
[generator.egl] at
[generator.egl] at
[generator.egl] at
[generator.egl] at
[generator.egl] at
Method)
[generator.egl] at
[generator.egl] at
[generator.egl] at org.eclipse.ant.core.AntRunner.run(AntRunner.java:378)
[generator.egl] at
[generator.egl] at java.lang.Thread.run(Thread.java:619)
[generator.egl] Caused by: Undefined variable, type or model: 'Class'
[generator.egl] at
org.eclipse.epsilon.eol.execute.NameExecutor.execute(NameExe cutor.java:86)
[generator.egl] at
org.eclipse.epsilon.eol.execute.NameExecutor.execute(NameExe cutor.java:99)
[generator.egl] at
org.eclipse.epsilon.eol.execute.ExecutorFactory.executeAST(E xecutorFactory.java:184)
[generator.egl] at
org.eclipse.epsilon.eol.execute.PointExecutor.execute(PointE xecutor.java:35)
[generator.egl] at
org.eclipse.epsilon.eol.execute.PointExecutor.execute(PointE xecutor.java:122)
[generator.egl] at
[generator.egl] at
org.eclipse.epsilon.eol.execute.ForStatementExecutor.execute (ForStatementExecutor.java:44)
[generator.egl] at
[generator.egl] at
org.eclipse.epsilon.eol.execute.StatementBlockExecutor.execu te(StatementBlockExecutor.java:25)
[generator.egl] at
[generator.egl] at
org.eclipse.epsilon.eol.EolModule.execute(EolModule.java:57)
[generator.egl] at
org.eclipse.epsilon.egl.EglModule.execute(EglModule.java:176 )
[generator.egl] ... 26 more
BUILD FAILED
Total time: 207 milliseconds
Re: Ant and epsilon.loadModel [message #10446 is a reply to message #10413] Thu, 29 January 2009 12:13 Go to previous messageGo to next message
Do you reference the model in the epsilon.egl task?
e.g.
<epsilon.egl src="my.egl">
<model ref="myModel"/>
</epsilon.egl>
Dimitris
> </target>
> init:
> loadModel:
> default:
> [generator.egl] at
> [generator.egl] at
> [generator.egl] at
> [generator.egl] at
> [generator.egl] at
> [generator.egl] at
> [generator.egl] at
> [generator.egl] at
> [generator.egl] at
> [generator.egl] at
> [generator.egl] at
> [generator.egl] at
> [generator.egl] at
> [generator.egl] at
> [generator.egl] at
> [generator.egl] at
> [generator.egl] at
> [generator.egl] at
> [generator.egl] at
> [generator.egl] at
> [generator.egl] at
> [generator.egl] at
> [generator.egl] at
> [generator.egl] at
> [generator.egl] at
> [generator.egl] at
> [generator.egl] at
> [generator.egl] at
> [generator.egl] at
> [generator.egl] at
> [generator.egl] at
> [generator.egl] at
> [generator.egl] at
> [generator.egl] at
> BUILD FAILED
Re: Ant and epsilon.loadModel [message #10480 is a reply to message #10446] Thu, 29 January 2009 12:19 Go to previous message
It definitively works !!!!!
I'm on my way re rtfm ^^
Thank you !
Re: Ant and epsilon.loadModel [message #564252 is a reply to message #9653] Wed, 28 January 2009 16:51 Go to previous message
Hi Stephane,
should be instead:
Dimitris
Stephane wrote:
> Hi list,
> init:
> loadModel:
> BUILD FAILED
> 28 janv. 2009
> 22:05:18
> instance
> user
> <description>
> </description>
> <epsilon.egl
> </epsilon.egl>
> </target>
> </target>
> </target>
> </project>
Re: Ant and epsilon.loadModel [message #564273 is a reply to message #9676] Wed, 28 January 2009 17:38 Go to previous message
Thanks !
about FileNotFound.
project.
init:
loadModel:
default:
BUILD FAILED
Thanks !!!
Re: Ant and epsilon.loadModel [message #564294 is a reply to message #9697] Thu, 29 January 2009 04:48 Go to previous message
Hi Stephane,
Dimitrios
Stephane wrote:
> Thanks !
> about FileNotFound.
> project.
> init:
> loadModel:
> default:
> BUILD FAILED
> Thanks !!!
name="xegl.zip"
filename="xegl.zip"
Re: Ant and epsilon.loadModel [message #564319 is a reply to message #9710] Thu, 29 January 2009 08:25 Go to previous message
Hi Dimitrios,
main:
BUILD FAILED
</target>
</project>
Re: Ant and epsilon.loadModel [message #564333 is a reply to message #10223] Thu, 29 January 2009 08:39 Go to previous message
Dimitris
Stephane wrote:
> Hi Dimitrios,
> main:
> BUILD FAILED
> </target>
> </project>
Re: Ant and epsilon.loadModel [message #564350 is a reply to message #10250] Thu, 29 January 2009 08:41 Go to previous message
Thanks !
Re: Ant and epsilon.loadModel [message #564371 is a reply to message #10283] Thu, 29 January 2009 10:49 Go to previous message
Dimitris
> Thanks !
Re: Ant and epsilon.loadModel [message #564388 is a reply to message #10316] Thu, 29 January 2009 11:12 Go to previous message
Dimitris
> Cheers,
> Dimitris
>> Thanks !
Re: Ant and epsilon.loadModel [message #564399 is a reply to message #10348] Thu, 29 January 2009 11:36 Go to previous message
Hi Dimitrios,
BUILD FAILED
within a Ant task.
generatePhp5Model
user
<description>
</description>
target: default
</epsilon.egl>
</target>
target: init
</target>
target: loadModel
</target>
</project>
</listAttribute>
</listAttribute>
Re: Ant and epsilon.loadModel [message #564414 is a reply to message #10382] Thu, 29 January 2009 11:43 Go to previous message
</target>
init:
loadModel:
default:
[generator.egl] at
[generator.egl] at
[generator.egl] at
[generator.egl] at
[generator.egl] at
Method)
[generator.egl] at
[generator.egl] at
[generator.egl] at
[generator.egl] at
[generator.egl] at
[generator.egl] at
[generator.egl] at
[generator.egl] at
[generator.egl] at
[generator.egl] at
[generator.egl] at
Method)
[generator.egl] at
[generator.egl] at
[generator.egl] at
[generator.egl] at
[generator.egl] at
[generator.egl] at
[generator.egl] at
[generator.egl] at
[generator.egl] at
[generator.egl] at
[generator.egl] at
[generator.egl] at
[generator.egl] at
[generator.egl] at
[generator.egl] at
BUILD FAILED
Re: Ant and epsilon.loadModel [message #564430 is a reply to message #10413] Thu, 29 January 2009 12:13 Go to previous message
e.g.
</epsilon.egl>
Dimitris
> </target>
> init:
> loadModel:
> default:
> [generator.egl] at
> [generator.egl] at
> [generator.egl] at
> [generator.egl] at
> [generator.egl] at
> [generator.egl] at
> [generator.egl] at
> [generator.egl] at
> [generator.egl] at
> [generator.egl] at
> [generator.egl] at
> [generator.egl] at
> [generator.egl] at
> [generator.egl] at
> [generator.egl] at
> [generator.egl] at
> [generator.egl] at
> [generator.egl] at
> [generator.egl] at
> [generator.egl] at
> [generator.egl] at
> [generator.egl] at
> [generator.egl] at
> [generator.egl] at
> [generator.egl] at
> [generator.egl] at
> [generator.egl] at
> [generator.egl] at
> [generator.egl] at
> [generator.egl] at
> [generator.egl] at
> [generator.egl] at
> [generator.egl] at
> [generator.egl] at
> BUILD FAILED
Re: Ant and epsilon.loadModel [message #564453 is a reply to message #10446] Thu, 29 January 2009 12:19 Go to previous message
Thank you !
Previous Topic:Ant and epsilon.loadModel
Next Topic:EVL constraints over instance pairs/triples/etc
Current Time: Thu Jul 17 20:12:24 EDT 2025
Powered by FUDForum. Page generated in 0.18408 seconds
