Home » Language IDEs » C / C++ IDE (CDT) » Hung when saving files
Hung when saving files [message #106370] Tue, 15 June 2004 11:11 Go to next message
This is a multipart message in MIME format.
--=_alternative 0054437785256EB4_=
Content-Type: text/plain; charset="US-ASCII"
I got very frustrated when I tried to save files and JRE hangs and I have
to kill eclipses and lose the changes. I am using eclipse RC2/CDT M9. I
reinstalled JRE 1.4.2_4, and issue is there, Anyone has the same
experience?
Content-Type: text/html; charset="US-ASCII"
<br><font size=2 face="sans-serif">I got very frustrated when I tried to
save files and JRE hangs and I have to kill eclipses and lose the changes.
I am using eclipse RC2/CDT M9. I reinstalled JRE 1.4.2_4, and issue is
there, Anyone has the same experience?</font>
--=_alternative 0054437785256EB4_=--
Re: Hung when saving files [message #106384 is a reply to message #106370] Tue, 15 June 2004 16:34 Go to previous messageGo to next message
Most likely the hang is related to an infinite loop in the parser. If you
have a piece of source code that you can reproduce this with (that isn't
proprietary) I would suggest you raise a critical defect on CDT, CDT-Parser
w/the source attached.
JohnC
<huani@us.ibm.com> wrote in message news:can3jp$fa3$1@eclipse.org...
I got very frustrated when I tried to save files and JRE hangs and I have to
reinstalled JRE 1.4.2_4, and issue is there, Anyone has the same experience?
Re: Hung when saving files [message #106522 is a reply to message #106370] Wed, 16 June 2004 16:10 Go to previous messageGo to next message
------=_NextPart_000_0048_01C453A3.574C7660
charset="iso-8859-1"
I had the same problem with similar configuration (RC2 + M9 + JDK 1.4 + =
gcc3.3.3) on HP-UX.
Robert Fu
I got very frustrated when I tried to save files and JRE hangs and I =
have to kill eclipses and lose the changes. I am using eclipse RC2/CDT =
M9. I reinstalled JRE 1.4.2_4, and issue is there, Anyone has the same =
experience?
<HTML><HEAD>
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2800.1400" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>I had the same problem with similar =
configuration=20
(RC2 + M9 + JDK 1.4 + gcc3.3.3) on HP-UX.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>Thanks,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Robert Fu</FONT></DIV>
<BLOCKQUOTE=20
<DIV>&lt;<A href=3D"mailto:huani@us.ibm.com">huani@us.ibm.com</A>&gt; =
wrote in=20
message <A=20
href=3D"news:can3jp$fa3$1@eclipse.org">news:can3jp$fa3$1@eclipse.org</A>.=
...</DIV><BR><FONT=20
face=3Dsans-serif size=3D2>I got very frustrated when I tried to save =
files and=20
JRE hangs and I have to kill eclipses and lose the changes. I am using =
eclipse=20
RC2/CDT M9. I reinstalled JRE 1.4.2_4, and issue is there, Anyone has =
the same=20
experience?</FONT></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_0048_01C453A3.574C7660--
Re: Hung when saving files [message #106676 is a reply to message #106522] Thu, 17 June 2004 14:51 Go to previous messageGo to next message
Does this happen for all files or just one in particular?
If so, in order to fix it I require the source code or a cleaned up example
if the source is proprietary...
JohnC
"Robert Fu" <qrobertfu@yahoo.com> wrote in message
news:caq91s$97u$1@eclipse.org...
gcc3.3.3) on HP-UX.
Robert Fu
Re: Hung when saving files [message #106704 is a reply to message #106676] Thu, 17 June 2004 16:43 Go to previous messageGo to next message
Hi John,
I tried it again, and it hung again. The status at the botton right corner
showed something like this: "C/C++ Indexer" 66%. Here is the code I
downloaded it from HP site to test if gdb/CDT works on HP-UX 11.11. The file
is also attached. My configuration is in my previous email.
BTW, do you know if anyone made debugging with CDT/gdb/gcc worked on HP-UX
11.11? I just want to know if it's possible.
Thanks a lot,
Robert Fu
------------------------ code -----------------
/* "average.c" */
#include <stdio.h>
#define num 10
#define first 0
#define last num-1
static int my_list[num] = {3,4,2,0,2,1,8,3,6,7};
int sum(int list[], int low, int high)
int i, s = 0;
for (i = low; i <= high; i++)
s += list[i];
return(s);
void print_average(int list[], int low, int high)
int total, num_elements, average;
total = sum(list, low, high);
num_elements = high - low; /* note this is an off-by-one bug */
average = total / num_elements;
printf("%10.d\n", average);
int main(void)
/* Try two test cases. */
print_average (my_list, first, last);
print_average (my_list, first, last - 3);
return 0;
"johnc" <jcamelon@ca.ibm.com> wrote in message
news:casp0l$3mk$1@eclipse.org...
example
> JohnC
> gcc3.3.3) on HP-UX.
> Robert Fu
to
experience?
  • Attachment: average.c
    (Size: 0.69KB, Downloaded 87 times)
Re: Hung when saving files [message #106759 is a reply to message #106704] Fri, 18 June 2004 16:44 Go to previous message
I've fixed some things today regarding error handling and infinite hangs ...
with these fixes that I have committed, I do not get a hang saving this
source code. Try it out on a build next week and let me know what you
think.
JohnC
news:casvr4$c0f$1@eclipse.org...
> Hi John,
file
> Thanks a lot,
> Robert Fu
> /* "average.c" */
> #include <stdio.h>
> #define num 10
> #define first 0
> #define last num-1
> int i, s = 0;
> s += list[i];
> return(s);
> int main(void)
> return 0;
> example
> > JohnC
> > gcc3.3.3) on HP-UX.
> > Thanks,
> > Robert Fu
have
> to
> experience?
Previous Topic:xml File Viewer
Next Topic:Received a SIGSEGV when starting debugging on HP-UX 11.11 with RC2 and M9
Current Time: Sat Jul 26 06:10:32 EDT 2025
Powered by FUDForum. Page generated in 0.05994 seconds
