CorruptDataException with (MAT+DTFJ) when reading a jextracted core [message #9636] |
Wed, 25 March 2009 06:41  |
Dear All,
I am generating a core from J2RE 1.4.2 IBM AIX build ca142-20080923 (SR12)
using gencore and process the genenrated core on the same AIX machine
using jextract.
I the transfer all the 3 generated file (core + sdff.hdr + sdff) on a
machine (OS=win32, ARCH=x86_64) and open it using MAT + DTFJ.
Has any one seen the parse error (pasted below) before ?
Francois
!ENTRY org.eclipse.mat.ui 4 0 2009-03-25 11:17:53.272
!MESSAGE Problem finding class loaders
!STACK 0
com.ibm.dtfj.image.CorruptDataException: IOException java.io.IOException:
Negative seek offset, could not read address 0x3000308
com.ibm.dtfj.sov.java.imp.JavaClassLoaderProxyImpl.getObject (JavaClassLoaderProxyImpl.java:614)
com.ibm.dtfj.sov.imp.JavaClassLoaderEffigy.getObject(JavaCla ssLoaderEffigy.java:101)
at org.eclipse.mat.dtfj.DTFJIndexBuilder.fill(DTFJIndexBuilder. java:327)
org.eclipse.mat.parser.internal.SnapshotFactoryImpl.parse(Sn apshotFactoryImpl.java:183)
org.eclipse.mat.parser.internal.SnapshotFactoryImpl.openSnap shot(SnapshotFactoryImpl.java:101)
org.eclipse.mat.snapshot.SnapshotFactory.openSnapshot(Snapsh otFactory.java:87)
org.eclipse.mat.ui.snapshot.ParseHeapDumpJob.run(ParseHeapDu mpJob.java:54)
FUDForum. Page generated in 0.04288 seconds
