Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [CDO][0.8.0] Give more informations to StoreWriter
[CDO][0.8.0] Give more informations to StoreWriter [message #106340] Mon, 07 January 2008 08:56 Go to next message
Hi Eike,
I have an object database implementation using CDO.
TO persist my objects in that objects databases some informations such as
who refer to him will be very useful.
Do you see any way where StoreWriter could have access to the context of the
transaction before doing anything ?
I would like to have access to deltas...at the beginning of my transactions
so I can calculate where my objects will go.
Or to an extension point somewhere in the transaction process... so I can
talk with my specific IStoreWriter.
Thank you
Simon
Re: [CDO][0.8.0] Give more informations to StoreWriter [message #106354 is a reply to message #106340] Mon, 07 January 2008 09:31 Go to previous messageGo to next message
Originally posted by: stepper.sympedia.de
Simon McDuff schrieb:
> Hi Eike,
Do you mean the user(name)?
What exactly do you mean by "transaction"
- CDOTransaction at client side?
- IView with type TANSACTION at server side?
- ITransaction<IStoreWriter> like in IStoreWriter.rollback()?
- Transaction of your OODB (must be encapsulated somewhere in your
IStoreWriter implementation)
Basically I'm not a fan of this because the idea of the storage
framework is a separate layer below the repository layer. I admit that I
was not very strict with this separation myself: interface IStore
extends IRepositoryElement ;-( But we should make the story only worse
if it's absolutely necessary.
Can you describe in more detail where exactly you'd like to hook in?
I have the feeling that additional/changed API in the storage framework
could already be sufficient.
Eike Stepper
http://wiki.eclipse.org/CDO
http://wiki.eclipse.org/Net4j
Re: [CDO][0.8.0] Give more informations to StoreWriter [message #106368 is a reply to message #106354] Mon, 07 January 2008 09:49 Go to previous messageGo to next message
"Eike Stepper" <stepper@sympedia.de> wrote in message
news:fltd3c$fvn$1@build.eclipse.org...
>> Hi Eike,
No I mean if I have an new objectA (transient) that is link with objectB
(persisted)... I would like to know it so I can persit objectA in a specific
spot in the database. Object database doesn't have table or such things. It
is a big memory. When we create an object you tell the system where in the
memory you would like to persist it. In this case, I would like to put
objectB close to objectA for performance reason.
>> the transaction before doing anything ?
>> transactions so I can calculate where my objects will go.
> Basically I'm not a fan of this because the idea of the storage framework
> is a separate layer below the repository layer. I admit that I was not
> very strict with this separation myself: interface IStore extends
> IRepositoryElement ;-( But we should make the story only worse if it's
Storage layer that are object database really needs the context to where to
put objects. I believed it will be a value for them.
I agree.
A solution could be
void IStoreWriter.begin(ITransactionContext context);
interface ITransactionContext
getNewPackages();
getNewResources();
getNewsObjects();
getDirtyObjects();
> Eike Stepper
Re: [CDO][0.8.0] Give more informations to StoreWriter [message #106409 is a reply to message #106368] Mon, 07 January 2008 11:19 Go to previous messageGo to next message
>>> Hi Eike,
I think the direction of your "link" makes a big difference. Are you
interested in the referers, particularly the transient ones? I don't
think that it's possible at all to reflect arbitrary referers.
BTW. what's the difference in performance like?
I can see no value in having access to the ITransaction.
May be that's the reason why rollback() doesn't use it either.
I should remove it from the IStoreWriter API.
By "context of the transaction" do you really mean
ITransaction.getContext()?
This method simply returns the IStoreWriter instance which you're in
already.
Bear with me, I can't follow.
The best discriminators I can imagine of to partition your OODB space in
order to optimize access are
- Repository name (you have it in your store writer via
getStore().getRepository(), although I said that this API is currently
breaking layer separation)
- Resource of the object (you have it in your writeRevision()
implementation via revision.getData().getResourceID(), if you need it in
the new deltas as well we'll possibly have to enhance the deltas)
> I agree.
> A solution could be
> getNewPackages();
> getNewResources();
> getNewsObjects();
> getDirtyObjects();
I think I begin to understand what you mean by "transaction" and its
"context". You really mean an equivalent of the information in the
client side CDOTransactionImpl, which (at some point in time) is
equivalent to the information in the CommitTransactionIndication.
If so, I'd propose a different solution:
By passing all together the values down before passing them down
separately again I'd rather pass a sort of "revisionDataFinished" event
down to the store writer. Then it's up to your store implementation to
gather all the needed infos (without updating the database) within the
separate data calls and finally do the database update in one chunk at
the end (revisionDataFinished event).
Would that be ok?
Eike Stepper
Re: [CDO][0.8.0] Give more informations to StoreWriter [message #106420 is a reply to message #106409] Mon, 07 January 2008 11:38 Go to previous messageGo to next message
> interested in the referers, particularly the transient ones? I don't think
Big differences. It is working like a filesystem.
So The databases read pages.
On 1 page you can store around 500 pages.
If we really do a read on the disk... it is very slow.
Worst case to read 500 objects == 500 pages on disk
Best case to read 500 objects == 1 page on disk.
Same logic for write.
In the case of random read/write... it is even slower...
>> I agree.
>> A solution could be
>> getNewPackages();
>> getNewResources();
>> getNewsObjects();
>> getDirtyObjects();
> "context". You really mean an equivalent of the information in the client
> side CDOTransactionImpl, which (at some point in time) is equivalent to
> separate data calls and finally do the database update in one chunk at the
> Would that be ok?
Sounds goods...
Right now as we read the data from the stream we call primeNewObjects.
This would have to change ? Right ? Because I want to make these call after
I gather all the infos.
Simon
Re: [CDO][0.8.0] Give more informations to StoreWriter [message #106434 is a reply to message #106420] Mon, 07 January 2008 12:36 Go to previous messageGo to next message
>> Would that be ok?
> Sounds goods...
Funny that it was you who wanted to have the primeNewObject method in
the storage API ;-)
I see your problem but I don't see an easy solution for it. For all your
optimizations I see more and more repository responsibilities walking
down to the store. In the end we can spare it completely and simply pass
an InputStream down to the store. Just joking!
But seriously, can you tell me, how the mapping of tempIDs and metaIDs
should work then?
Eike Stepper
Re: [CDO][0.8.0] Give more informations to StoreWriter [message #106447 is a reply to message #106434] Mon, 07 January 2008 13:06 Go to previous messageGo to next message
news:fltnv4$ci7$2@build.eclipse.org...
>>> Would that be ok?
>> Sounds goods...
>> after I gather all the infos.
I don't have a problem with primeNewObjects... it is when we call it that I
have a problem with.
We seems to mix up serialization and processing at many places.
Should not we unserialize data... and then apply changes to have a real
transaction scope.
Right now we do both of them at the same time.
I would like to see a separation between two different processes.
It is strange because we create ITransaction.. and in fact we already did
apply some changes to the graph.
If we do all modifications after reading from the stream.. it will be easier
to manage stuff in my StoreWriter.
> Funny that it was you who wanted to have the primeNewObject method in the
> storage API ;-)
> optimizations I see more and more repository responsibilities walking down
> to the store. In the end we can spare it completely and simply pass an
> should work then?
> Eike Stepper
Re: [CDO][0.8.0] Give more informations to StoreWriter [message #106460 is a reply to message #106434] Mon, 07 January 2008 13:12 Go to previous messageGo to next message
Another things...
When we call readNewPackages or readNewResources or readDirtyObjects we do
not add revisions to the storeWriter ... neither to the RevisionManager.
Why we do it with primeNewObject in readNewObjects ?
>>> Would that be ok?
>> Sounds goods...
> storage API ;-)
> should work then?
> Eike Stepper
Re: [CDO][0.8.0] Give more informations to StoreWriter [message #106474 is a reply to message #106460] Mon, 07 January 2008 13:32 Go to previous messageGo to next message
> Another things...
Correct.
IStoreWriter.primeNewObject is called for new objects and for new
resources. You should know best why we have this method. I changed a lot
of things just because you wanted to have it and I didn't need it for my
store implementation...
Eike Stepper
>>>> Would that be ok?
>>> Sounds goods...
>> storage API ;-)
>> should work then?
>> Regards,
>> Eike Stepper
Re: [CDO][0.8.0] Give more informations to StoreWriter [message #106490 is a reply to message #106447] Mon, 07 January 2008 13:39 Go to previous messageGo to next message
Simon,
I suggest that you open an enhancement request and I'll see if I can
come up with a different design.
Please note that I'll be absent from 9th to 16th.
Eike Stepper
>>>> Would that be ok?
>>> Sounds goods...
> transaction scope.
>> storage API ;-)
>> should work then?
>> Regards,
>> Eike Stepper
Re: [CDO][0.8.0] Give more informations to StoreWriter [message #106502 is a reply to message #106474] Mon, 07 January 2008 14:07 Go to previous messageGo to next message
news:fltr7m$ci7$3@build.eclipse.org...
>> Another things...
>> do not add revisions to the storeWriter ... neither to the
>> RevisionManager.
> Correct.
The only things I asked was to change the responsability of the ID from
CDOID newID = getRepository().getNextCDOID();
to
CDOID newID = storeWriter.primeNewObject(revision.getCDOClass());
Not that many changes.
If you want to integrate with other databases like Hibernate that have more
accessor than CDO you have no choice to delegate the responsability to the
store. Otherwise you performance will not be very good.
Don't you see the advantage ?
> Eike Stepper
>>>>> event down to the store writer. Then it's up to your store
>>>>> implementation to gather all the needed infos (without updating the
>>>>> database) within the separate data calls and finally do the database
>>>>> update in one chunk at the end (revisionDataFinished event).
>>>>> Would that be ok?
>>>> Sounds goods...
>>> the storage API ;-)
>>> should work then?
>>> Regards,
>>> Eike Stepper
Re: [CDO][0.8.0] Give more informations to StoreWriter [message #106514 is a reply to message #106502] Mon, 07 January 2008 14:16 Go to previous messageGo to next message
>>> Another things...
>>> RevisionManager.
>> Correct.
> to
I didn't say that this change was bad. I remember well that discussion,
also with respect to possible store-controlled CDOID formats.
I only wanted to say that before this change the store was not in the
game at this time (readNewObjects).
But that's not important now. Let's see if something cool comes out of
your request: https://bugs.eclipse.org/bugs/show_bug.cgi?id=214526
Eike Stepper
>> Regards,
>> Eike Stepper
>>>>>> Would that be ok?
>>>>> Sounds goods...
>>>> the storage API ;-)
>>>> should work then?
>>>> Regards,
>>>> Eike Stepper
Re: [CDO][0.8.0] Give more informations to StoreWriter [message #106528 is a reply to message #106490] Mon, 07 January 2008 14:28 Go to previous messageGo to next message
You are going in vacation again!! :-) Lucky you!!!
news:fltrkp$ci7$4@build.eclipse.org...
> Simon,
> I suggest that you open an enhancement request and I'll see if I can come
> Eike Stepper
>>>>> Would that be ok?
>>>> Sounds goods...
>> that I have a problem with.
>> transaction scope.
>> easier to manage stuff in my StoreWriter.
>>> the storage API ;-)
>>> should work then?
>>> Regards,
>>> Eike Stepper
Re: [CDO][0.8.0] Give more informations to StoreWriter [message #106630 is a reply to message #106528] Tue, 08 January 2008 17:39 Go to previous message
Just a week in NY, my friend found a very cheap flight ;-)
CU
/Eike
>> Simon,
>> Regards,
>> Eike Stepper
>>>>>> Would that be ok?
>>>>> Sounds goods...
>>> transaction scope.
>>>> the storage API ;-)
>>>> should work then?
>>>> Regards,
>>>> Eike Stepper
Re: [CDO][0.8.0] Give more informations to StoreWriter [message #613945 is a reply to message #106340] Mon, 07 January 2008 09:31 Go to previous message
> Hi Eike,
Eike Stepper
Re: [CDO][0.8.0] Give more informations to StoreWriter [message #613948 is a reply to message #106354] Mon, 07 January 2008 09:49 Go to previous message
>> Hi Eike,
I agree.
A solution could be
getNewPackages();
getNewResources();
getNewsObjects();
getDirtyObjects();
> Eike Stepper
Re: [CDO][0.8.0] Give more informations to StoreWriter [message #613954 is a reply to message #106368] Mon, 07 January 2008 11:19 Go to previous message
>>> Hi Eike,
already.
> I agree.
> A solution could be
> getNewPackages();
> getNewResources();
> getNewsObjects();
> getDirtyObjects();
Would that be ok?
Eike Stepper
Re: [CDO][0.8.0] Give more informations to StoreWriter [message #613956 is a reply to message #106409] Mon, 07 January 2008 11:38 Go to previous message
>> I agree.
>> A solution could be
>> getNewPackages();
>> getNewResources();
>> getNewsObjects();
>> getDirtyObjects();
> Would that be ok?
Sounds goods...
Simon
Re: [CDO][0.8.0] Give more informations to StoreWriter [message #613957 is a reply to message #106420] Mon, 07 January 2008 12:36 Go to previous message
>> Would that be ok?
> Sounds goods...
the storage API ;-)
should work then?
Eike Stepper
Re: [CDO][0.8.0] Give more informations to StoreWriter [message #613958 is a reply to message #106434] Mon, 07 January 2008 13:06 Go to previous message
>>> Would that be ok?
>> Sounds goods...
transaction scope.
> storage API ;-)
> should work then?
> Eike Stepper
Re: [CDO][0.8.0] Give more informations to StoreWriter [message #613959 is a reply to message #106434] Mon, 07 January 2008 13:12 Go to previous message
Another things...
>>> Would that be ok?
>> Sounds goods...
> storage API ;-)
> should work then?
> Eike Stepper
Re: [CDO][0.8.0] Give more informations to StoreWriter [message #613960 is a reply to message #106460] Mon, 07 January 2008 13:32 Go to previous message
> Another things...
Correct.
Eike Stepper
>>>> Would that be ok?
>>> Sounds goods...
>> storage API ;-)
>> should work then?
>> Regards,
>> Eike Stepper
Re: [CDO][0.8.0] Give more informations to StoreWriter [message #613961 is a reply to message #106447] Mon, 07 January 2008 13:39 Go to previous message
Simon,
Eike Stepper
>>>> Would that be ok?
>>> Sounds goods...
> transaction scope.
>> storage API ;-)
>> should work then?
>> Regards,
>> Eike Stepper
Re: [CDO][0.8.0] Give more informations to StoreWriter [message #613962 is a reply to message #106474] Mon, 07 January 2008 14:07 Go to previous message
>> Another things...
>> RevisionManager.
> Correct.
to
> Eike Stepper
>>>>> Would that be ok?
>>>> Sounds goods...
>>> the storage API ;-)
>>> should work then?
>>> Regards,
>>> Eike Stepper
Re: [CDO][0.8.0] Give more informations to StoreWriter [message #613963 is a reply to message #106502] Mon, 07 January 2008 14:16 Go to previous message
>>> Another things...
>>> RevisionManager.
>> Correct.
> to
Eike Stepper
>> Regards,
>> Eike Stepper
>>>>>> Would that be ok?
>>>>> Sounds goods...
>>>> the storage API ;-)
>>>> should work then?
>>>> Regards,
>>>> Eike Stepper
Re: [CDO][0.8.0] Give more informations to StoreWriter [message #613964 is a reply to message #106490] Mon, 07 January 2008 14:28 Go to previous message
> Simon,
> Eike Stepper
>>>>> Would that be ok?
>>>> Sounds goods...
>> transaction scope.
>>> the storage API ;-)
>>> should work then?
>>> Regards,
>>> Eike Stepper
Re: [CDO][0.8.0] Give more informations to StoreWriter [message #613971 is a reply to message #106528] Tue, 08 January 2008 17:39 Go to previous message
CU
/Eike
>> Simon,
>> Regards,
>> Eike Stepper
>>>>>> Would that be ok?
>>>>> Sounds goods...
>>> transaction scope.
>>>> the storage API ;-)
>>>> should work then?
>>>> Regards,
>>>> Eike Stepper
Previous Topic:GMF mindmap example problem
Next Topic:[Compare] using separate model resource sets for left/right/ancestor
Current Time: Tue Jul 15 23:45:22 EDT 2025
Powered by FUDForum. Page generated in 0.52262 seconds
