Home » Archived » M2M (model-to-model transformation) » [ATL] SideEffect example - ant build doesn't work
[ATL] SideEffect example - ant build doesn't work [message #106285] Tue, 09 June 2009 05:35 Go to next message
Hi all,
I've tried the SideEffect example from
http://www.eclipse.org/m2m/atl/basicExamples_Patterns/articl e.php?file=SideEffect/index.html
Unfortunately the ant tasks have changed in the meantime. I've adapted
the build.xml in the way as shown below.
But now on execution I obtain
[atl.saveModel] Saving model myTypeB to
D:\path\to\workspace\SideEffect\SampleModels\RootB.xmi
BUILD FAILED
D:\path\to\workspace\SideEffect\Transformations\build.xml:22 : No
Resource found, unable to extract to path:
file:/D:\path\to\workspace\SideEffect\SampleModels\RootB.xmi
If I change myTypeB to tmpTypeB it works.
Henrik
-------------------- build.xml ---------------------------------------
<project name="project" default="default">
<property name="project" value="../" />
<target name="default" depends="modelsLoading">
<atl.launch
path="${project}/Transformations/TypeA2TypeB_v3_firstStep.asm ">
<inModel name="a" model="myTypeA" />
<inModel name="TypeA" model="TypeA" />
<inModel name="TypeB" model="TypeB" />
<outModel name="b" model="tmpTypeB" metamodel="TypeB" />
</atl.launch>
<atl.launch
path="${project}/Transformations/TypeA2TypeB_v3_secondStep.asm ">
<inModel name="bIn" model="tmpTypeB" />
<outModel name="b" model="myTypeB" metamodel="TypeB" />
</atl.launch>
<atl.saveModel model="myTypeB" path="${project}/SampleModels/RootB.xmi" />
</target>
<target name="modelsLoading">
<atl.loadModel modelHandler="EMF" name="TypeA" metamodel="MOF"
path="${project}/Metamodels/TypeA.ecore" />
<atl.loadModel modelHandler="EMF" name="TypeB" metamodel="MOF"
path="${project}/Metamodels/TypeB.ecore" />
<atl.loadModel modelHandler="EMF" name="myTypeA" metamodel="TypeA"
path="${project}/SampleModels/RootA.xmi" />
</target>
</project>
Re: [ATL] SideEffect example - ant build doesn't work [message #106348 is a reply to message #106285] Tue, 09 June 2009 08:27 Go to previous messageGo to next message
The problem comes from the way the EMFVM manages models, which seems to
not support model reuse.
Could you please report a bug about that? (twice in a day,
congratulations ;-) ).
As a workaround, you can use the RegularVM instead into the ant file. I
just updated the SideEffect example on the website.
William
Henrik Rentz-Reichert a écrit :
> Hi all,
> BUILD FAILED
> Henrik
> <atl.launch
> </atl.launch>
> <atl.launch
> </atl.launch>
> </target>
> </target>
> </project>
Re: [ATL] SideEffect example - ant build doesn't work [message #106386 is a reply to message #106348] Tue, 09 June 2009 11:08 Go to previous messageGo to next message
William,
I can't see an update of the example project sources
( http://www.eclipse.org/m2m/atl/atlTransformations/SideEffect /SideEffect.zip
- maybe this is due to some latency due to caching in the system).
Also,
http://wiki.eclipse.org/AM3_Ant_Tasks#Parameters_specified_a s_attributes_2
doesn't mention an option to select a specific VM (this page needs an
overall update).
How can I pick the RegularVM?
Henrik
William Piers wrote:
> Hello,
> Best regards,
> William
>> Hi all,
>> BUILD FAILED
>> Thanks,
>> Henrik
>> <?xml version="1.0" encoding="UTF-8"?>
>> <atl.launch
>> </atl.launch>
>> <atl.launch
>> </atl.launch>
>> </target>
>> metamodel="TypeA"
>> </target>
>> </project>
Re: [ATL] SideEffect example - ant build doesn't work [message #106399 is a reply to message #106386] Tue, 09 June 2009 11:15 Go to previous messageGo to next message
Strange. When I download the zip I get the updated version.
Any way, to change the VM you have to put a parameter inside of the ant
project:
<property name="atl.launcher" value="Regular VM (with debugger)" />
<!-- transformation target -->
</project>
This is documented here:
http://wiki.eclipse.org/ATL/User_Guide#Launcher_configuratio n
William
> William,
> Also,
> overall update).
> Henrik
>> Hello,
>> Best regards,
>> William
>>> Hi all,
>>> BUILD FAILED
>>> Thanks,
>>> Henrik
>>> <atl.launch
>>> </atl.launch>
>>> <atl.launch
>>> </atl.launch>
>>> </target>
>>> metamodel="TypeA"
>>> </target>
>>> </project>
Re: [ATL] SideEffect example - ant build doesn't work [message #106415 is a reply to message #106399] Tue, 09 June 2009 13:07 Go to previous messageGo to next message
sorry, it still doesn't work.
The VM is found, but I get an error
BUILD FAILED
D:\path\to\workspace\SideEffect\Transformations\build.xml:8: null
in the line
<atl.launch
Henrik
> project:
> </project>
> Best regards,
> William
>> William,
>> Also,
>> overall update).
>> Thanks,
>> Henrik
>>> Hello,
>>> Best regards,
>>> William
>>>> Hi all,
>>>> BUILD FAILED
>>>> Thanks,
>>>> Henrik
>>>> <atl.launch
>>>> </atl.launch>
>>>> <atl.launch
>>>> </atl.launch>
>>>> </target>
>>>> metamodel="TypeA"
>>>> path="${project}/SampleModels/RootA.xmi" /> </target>
>>>> </project>
Re: [ATL] SideEffect example - ant build doesn't work [message #106428 is a reply to message #106348] Wed, 10 June 2009 01:55 Go to previous message
I filed
https://bugs.eclipse.org/bugs/show_bug.cgi?id=279739
for this issue
> Hello,
> Best regards,
> William
>> Hi all,
>> BUILD FAILED
>> Thanks,
>> Henrik
>> <atl.launch
>> </atl.launch>
>> <atl.launch
>> </atl.launch>
>> </target>
>> metamodel="TypeA"
>> </target>
>> </project>
Previous Topic:[ATL] several Resources in a ResourceSet
Next Topic:[ATL] Conditional Assignment - possible?
Current Time: Wed Jul 16 00:35:10 EDT 2025
Powered by FUDForum. Page generated in 0.07537 seconds
