Home » Archived » BIRT » Problem in deployement of Reports
Problem in deployement of Reports [message #106165] Mon, 09 January 2006 07:29
I have create jar file which contains the .class file and .rptdesign files
Class file contains the engine api's .But i got following error
2006-01-09 05:58:55 Message [Extension loading error]
Exception [org.eclipse.birt.report.model.metadata.MetaDataException:
Message:Duplicate extension name when adding the extension [Chart] to the
meta-data dictionary. Error code:DUPLICATE_EXTENSION_NAME
org.eclipse.birt.report.model.metadata.MetaDataDictionary.ad dExtension(MetaDataDictionary.java:749)
org.eclipse.birt.report.model.metadata.PeerExtensionLoader$P eerExtensionElementLoader.loadElement(PeerExtensionLoader.ja va:189)
org.eclipse.birt.report.model.metadata.PeerExtensionLoader.l oadExtension(PeerExtensionLoader.java:74)
org.eclipse.birt.report.model.metadata.ExtensionLoader.doLoa d(ExtensionLoader.java:112)
org.eclipse.birt.report.model.metadata.ExtensionLoader.load( ExtensionLoader.java:63)
org.eclipse.birt.report.model.metadata.ExtensionManager.init ialize(ExtensionManager.java:39)
org.eclipse.birt.report.model.api.DesignEngine.initialize(De signEngine.java:107)
org.eclipse.birt.report.model.api.DesignEngine.newSession(De signEngine.java:148)
org.eclipse.birt.report.engine.parser.ReportParser.parse(Rep ortParser.java:79)
org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.o penReportDesign(ReportEngineHelper.java:87)
org.eclipse.birt.report.engine.api.ReportEngine.openReportDe sign(ReportEngine.java:216)
at Parameter.getReport(Parameter.java:47)
at test1.main(test1.java:15)
Previous Topic:how to remove the blue border of the chart with url?
Next Topic:InputStream as input to XML DataSource
Current Time: Tue Jul 15 07:10:28 EDT 2025
Powered by FUDForum. Page generated in 0.32104 seconds
