RCP, eRCP, and OSGi best practices [message #106079] |
Mon, 10 March 2008 21:15  |
Originally posted by: jconlon.apache.org
Cut my teeth on OSGi with Felix before I was seduced into porting my GUI
to an Eclipse RCP Product. I love the tooling, but Now I will be moving
parts of it to eRCP and there is even a requirement to run some of our
bundles in a headless Equinox runtime.
So I need to start moving back towards an OSGi orientation without going
to far out on my own (ironically to be more standard). Are there any
guidelines published for us Eclipse product authors that need to start
moving our code so that it will run in more standard and diverse
Eclipse/Equinox/OSGi runtimes?
Specifically:
For starters, I need to create more generic bundles. Are there any tips
for breaking the required bundle habit? (For example, when creating a
simple bundle in an Eclipse Plugin, how can I just import
org.osgi.framework instead of using required bundle to get the framework?)
There are some wrapped bundles I am using that require log4j. What is
the best practice for logging within a hybrid set of bundles that maybe
used for Eclipse RCP products, eRCP mobile apps and Equinox headless
runtimes? Is the OSGi LogService a viable choice for these environments?
thanks for any suggestions,
John
Re: RCP, eRCP, and OSGi best practices [message #106138 is a reply to message #106110] |
Tue, 11 March 2008 10:55   |
Hi Ron,
The Quickfix addition to 3.4 is nice, but it doesn't appear to give me
anything I can't already do manually. I already export my packages and
use imports when I can with the current 3.3.
The most simple question in regard to creating cleaner bundles:
Is there a way when building an RCP application in the Eclipse PDE to
import the package org.osgi.framework so I can build a simple bundle
with out resorting to require bundle?
kind regards,
John
Ron Bermejo wrote:
> John E. Conlon wrote:
>> Specifically:
>> tips for breaking the required bundle habit? (For example, when
>> creating a simple bundle in an Eclipse Plugin, how can I just import
>> framework?)
> As of 3.4M2 PDE introduced some neat Quickfixes to help in this regard.
> http://download.eclipse.org/eclipse/downloads/drops/S-3.4M2- 200709210919/eclipse-news-M2.html
> Another possible solution for this would be to use the bnd tool:
> http://www.aqute.biz/Code/Bnd
> Hth!
> Ron
Re: RCP, eRCP, and OSGi best practices [message #106385 is a reply to message #106278] |
Sat, 15 March 2008 01:04  |
John E. Conlon schrieb:
> Can it be used for build full
> fledged RCP bundles that extend workbench for views and editors etc.?
Yes. From Eclipse side a plug-in is just a bundle. The only problem I
run into (with 3.3) is that PDE does not offer you all extension points
if you use Import-Package instead of Require-Bundle. However, that's
just a tooling problem and does not affect runtime.
>> After that I recommend using "Automated Management of Dependencies"
>> together with Import-Package (can be found on the Dependencies tab of
>> the Manifest editor).
> This too I've seen but have not used. Can I use it to convert from
> Require-Bundle to import and have it convert my manifests?
Let's say it that way ... it helps with "Import-Package" if you don't
know which packages you need. You simple select the bundles to be added
to the classpath. Later on, you invoke the "Organize Manifest" action
and PDE adds all the necessary "Import-Package" entries for you.
-Gunnar
Gunnar Wagenknecht
gunnar@wagenknecht.org
http://wagenknecht.org/
FUDForum. Page generated in 0.05690 seconds
