Home » Archived » BIRT » Designer runtime exception
Designer runtime exception [message #106057] Mon, 09 January 2006 03:30 Go to next message
Originally posted by: jan.tanis.coas.com
I'm having some trouble on the RC1. When I design a report in it and
click preview it says: "HTTP STATUS 500 type Exception report". The
runtime environment on tomcat work well after adding axis libs and
discarding the frameset thing. Does anyone know how to view report in
designer again?
Thanks in advance, Jan Tanis.
Re: Designer runtime exception [message #106483 is a reply to message #106057] Mon, 09 January 2006 21:35 Go to previous messageGo to next message
This is a multipart message in MIME format.
--=_alternative 000E398A852570F2_=
Content-Type: text/plain; charset="US-ASCII"
I think this may be a problem when you copied the axis jars. You might
have copied the commons-logging-1.0.4.jar to the viewer plugin lib
directory by accident. You don't need this jar.
You can verify if this is a problem by looking at the
catalina.<timestamp>.log log file. It should be under <BIRT RCP
directory>\.metadata\.plugins\org.eclipse.tomcat\catalina.<timestamp >.log
Look at the last exception that is thrown.
I had this same a problem
Content-Type: text/html; charset="US-ASCII"
<br><font size=2 face="sans-serif">I think this may be a problem when you
copied the axis jars. &nbsp; You might have copied the commons-logging-1.0.4.jar
to the viewer plugin lib directory by accident. &nbsp;You don't need this
jar.</font>
<br>
<br><font size=2 face="sans-serif">You can verify if this is a problem
by looking at the catalina.&lt;timestamp&gt;.log log file. &nbsp;It should
be under &lt;BIRT RCP directory&gt;\.metadata\.plugins\org.eclipse.tomcat\cata lina.&lt;timestamp&gt;.log </font>
<br>
<br><font size=2 face="sans-serif">Look at the last exception that is thrown.
</font>
<br>
<br><font size=2 face="sans-serif">&nbsp;I had this same a problem </font>
<br>
<br>
--=_alternative 000E398A852570F2_=--
Re: Designer runtime exception [message #108148 is a reply to message #106483] Thu, 12 January 2006 07:39 Go to previous messageGo to next message
That was not the problem. I did as you told, but the preview function
still gives an http 500 error.
Re: Designer runtime exception [message #109179 is a reply to message #108148] Fri, 13 January 2006 14:53 Go to previous messageGo to next message
What does the <BIRT RCP
contain?
On Thu, 12 Jan 2006 13:39:00 +0100, Jan Tanis <jan.tanis@coas.com>
Re: Designer runtime exception [message #109568 is a reply to message #109179] Mon, 16 January 2006 02:26 Go to previous messageGo to next message
--------------060103010505080503000603
Ok, here's my latest catalina.log from the /workspace/.metadata/.plugins
folder.
Regards, Jan Tanis.
> contain?
>>>directory>\.metadata\.plugins\org.eclipse.tomcat\catalina. <timestamp>.log
name="catalina.2006-01-12.log"
Content-Disposition: inline;
filename="catalina.2006-01-12.log"
WebappLoader[]: Deploying class repositories to work directory C:\Documents and Settings\Jan Tanis\Desktop\birt-rcp-report-designer-2.0RC1\workspace\.met adata\.plugins\org.eclipse.tomcat\ROOT
ContextConfig[]: Added certificates -> request attribute Valve
StandardManager[]: Seeding random number generator class java.security.SecureRandom
StandardManager[]: Seeding of random number generator has been completed
StandardWrapper[:default]: Loading container servlet default
StandardWrapper[:invoker]: Loading container servlet invoker
CoyoteConnector Coyote can't register jmx for protocol
WebappLoader[/viewer]: Deploying class repositories to work directory C:\Documents and Settings\Jan Tanis\Desktop\birt-rcp-report-designer-2.0RC1\workspace\.met adata\.plugins\org.eclipse.tomcat\viewer
WebappLoader[/viewer]: Deploy JAR /WEB-INF/lib/viewservlets.jar to c:\Documents and Settings\Jan Tanis\Desktop\birt-rcp-report-designer-2.0RC1\plugins\org.ec lipse.birt.report.viewer_2.0.0\birt\WEB-INF\lib\viewservlets .jar
ContextConfig[/viewer]: Added certificates -> request attribute Valve
StandardManager[/viewer]: Seeding random number generator class java.security.SecureRandom
StandardManager[/viewer]: Seeding of random number generator has been completed
StandardWrapper[/viewer:default]: Loading container servlet default
StandardWrapper[/viewer:invoker]: Loading container servlet invoker
StandardWrapperValve[ViewerServlet]: Allocate exception for servlet ViewerServlet
javax.servlet.ServletException: Error allocating a servlet instance
at org.apache.catalina.core.StandardWrapper.allocate(StandardWr apper.java:672)
at org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:210)
at org.apache.catalina.core.StandardPipeline$StandardPipelineVa lveContext.invokeNext(StandardPipeline.java:643)
at org.apache.catalina.core.StandardPipeline.invoke(StandardPip eline.java:480)
at org.apache.catalina.core.ContainerBase.invoke(ContainerBase. java:995)
at org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.java:191)
at org.apache.catalina.valves.CertificatesValve.invoke(Certific atesValve.java:246)
at org.apache.catalina.core.StandardPipeline$StandardPipelineVa lveContext.invokeNext(StandardPipeline.java:641)
at org.apache.catalina.core.StandardContext.invoke(StandardCont ext.java:2422)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:180)
at org.apache.catalina.valves.ErrorDispatcherValve.invoke(Error DispatcherValve.java:171)
at org.eclipse.tomcat.internal.EclipseErrorReportValve.invoke(E clipseErrorReportValve.java:153)
at org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java:174)
at org.apache.coyote.tomcat4.CoyoteAdapter.service(CoyoteAdapte r.java:199)
at org.apache.coyote.http11.Http11Processor.process(Http11Proce ssor.java:828)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHand ler.processConnection(Http11Protocol.java:700)
at org.apache.tomcat.util.net.TcpWorkerThread.runIt(PoolTcpEndp oint.java:584)
at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.ru n(ThreadPool.java:683)
at java.lang.Thread.run(Unknown Source)
----- Root Cause -----
java.lang.NoClassDefFoundError: org/apache/axis/transport/http/AxisServlet
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
at java.security.SecureClassLoader.defineClass(Unknown Source)
at org.apache.catalina.loader.WebappClassLoader.findClassIntern al(WebappClassLoader.java:1679)
at org.apache.catalina.loader.WebappClassLoader.findClass(Webap pClassLoader.java:968)
at org.apache.catalina.loader.WebappClassLoader.loadClass(Webap pClassLoader.java:1409)
at org.apache.catalina.loader.WebappClassLoader.loadClass(Webap pClassLoader.java:1289)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at org.apache.catalina.core.StandardWrapper.loadServlet(Standar dWrapper.java:885)
at org.apache.catalina.core.StandardWrapper.allocate(StandardWr apper.java:668)
NamingContextListener[/null/localhost]: Creation of the naming context failed: javax.naming.NamingException: Context is read only
WebappLoader[/help]: Deploying class repositories to work directory C:\Documents and Settings\Jan Tanis\Desktop\birt-rcp-report-designer-2.0RC1\workspace\.met adata\.plugins\org.eclipse.tomcat\help
WebappLoader[/help]: Deploy JAR /WEB-INF/lib/jsp.jar to c:\Documents and Settings\Jan Tanis\Desktop\birt-rcp-report-designer-2.0RC1\plugins\org.ec lipse.help.webapp_3.1.0\WEB-INF\lib\jsp.jar
WebappLoader[/help]: Deploy JAR /WEB-INF/lib/servlets.jar to c:\Documents and Settings\Jan Tanis\Desktop\birt-rcp-report-designer-2.0RC1\plugins\org.ec lipse.help.webapp_3.1.0\WEB-INF\lib\servlets.jar
ContextConfig[/help]: Added certificates -> request attribute Valve
StandardManager[/help]: Seeding random number generator class java.security.SecureRandom
StandardManager[/help]: Seeding of random number generator has been completed
StandardWrapper[/help:default]: Loading container servlet default
StandardWrapper[/help:invoker]: Loading container servlet invoker
--------------060103010505080503000603--
Re: Designer runtime exception [message #109633 is a reply to message #106057] Mon, 16 January 2006 03:17 Go to previous messageGo to next message
I solved it. It was missing the axis libraries. I think it would be very
usefull when 2.0 has all the libraries it needs come along with it.
Regards and thank, Jan Tanis.
Jan Tanis wrote:
> designer again?
Re: Designer runtime exception [message #117120 is a reply to message #109568] Thu, 26 January 2006 03:52 Go to previous messageGo to next message
Hi all,
I still can't use the preview function. Whether I'm using the standalone
or SDK I'm getting the error: action cancelled.
My log only contains the following lines:
C:\eclipse\workspace\.metadata\.plugins\org.eclipse.tomcat\R OOT
WebappLoader[]: Deploy JAR /WEB-INF/lib/axis.jar to
c:\eclipse\plugins\org.eclipse.tomcat_4.1.30.1\webapps\ROOT\ WEB-INF\lib\axis.jar
WebappLoader[]: Deploy JAR /WEB-INF/lib/commons-discovery-0.2.jar to
c:\eclipse\plugins\org.eclipse.tomcat_4.1.30.1\webapps\ROOT\ WEB-INF\lib\commons-discovery-0.2.jar
WebappLoader[]: Deploy JAR /WEB-INF/lib/commons-logging-1.0.4.jar to
c:\eclipse\plugins\org.eclipse.tomcat_4.1.30.1\webapps\ROOT\ WEB-INF\lib\commons-logging-1.0.4.jar
WebappLoader[]: Deploy JAR /WEB-INF/lib/jaxrpc.jar to
c:\eclipse\plugins\org.eclipse.tomcat_4.1.30.1\webapps\ROOT\ WEB-INF\lib\jaxrpc.jar
WebappLoader[]: Deploy JAR /WEB-INF/lib/saaj.jar to
c:\eclipse\plugins\org.eclipse.tomcat_4.1.30.1\webapps\ROOT\ WEB-INF\lib\saaj.jar
WebappLoader[]: Deploy JAR /WEB-INF/lib/wsdl4j-1.5.1.jar to
c:\eclipse\plugins\org.eclipse.tomcat_4.1.30.1\webapps\ROOT\ WEB-INF\lib\wsdl4j-1.5.1.jar
So in that there is no problem.
Does anyone encounter the same problem or knows a solution? Thanks.
Regards, Jan.
Re: Designer runtime exception [message #122735 is a reply to message #106057] Wed, 01 February 2006 10:21 Go to previous message
Originally posted by: dawidek.interia.pl
i'm having the same problem... anybody knows how to solve it???
Previous Topic:group header
Next Topic:Scrollbars in programatically engineered bar charts
Current Time: Sun Aug 31 13:27:20 EDT 2025
Powered by FUDForum. Page generated in 0.04431 seconds
