Home » Language IDEs » C / C++ IDE (CDT) » Variables don't appear while debugging
Variables don't appear while debugging [message #106031] Sun, 13 June 2004 14:33 Go to next message
Originally posted by: sgray.wooster.edu
I am using Eclipse Platform 2.1.3 Mac OS X Carbon on a Mac G4 running OS X
10.3.4. I
have used CDT 1.2.0 Linux GTK and CDT 1.2.0 Linux Motif with the same
results.
I am able to create, compile and run projects using the C/C++ development
perspective.
I can also use the debugging perspective to step through a program, see
the stack etc.
This includes proper highlighting of the line to execute. However I cannot
get any
variables to appear in the variables window. Any ideas why this might be
or, better, how
to fix it?
I understand that Mac OS is not listed as one of the supported OSes for
CDT, however it
seems odd that everything else seems to display properly using the Linux
distributions.
- Simon
Re: Variables don't appear while debugging [message #106536 is a reply to message #106031] Wed, 16 June 2004 21:36 Go to previous messageGo to next message
Originally posted by: ramanand_mandayam.yahoo.com
Simon,
I ran into a similar problem and one of the ways I made it go away
(or rather do the right thing but in a different window) was by activating
the "Window->New Window" menu. This launched another window with the
properly refreshed views but then I was left with two windows both trying
to present a debug perspective....
Hope this helps somewhat.
Cheers
Ramanand
> 10.3.4. I
> results.
> perspective.
> the stack etc.
> get any
> or, better, how
> to fix it?
> CDT, however it
> distributions.
> - Simon
Re: Variables don't appear while debugging [message #106622 is a reply to message #106536] Thu, 17 June 2004 11:03 Go to previous messageGo to next message
Hmm...you did this on a Mac under OS X? Which version of Eclipse and CDT
are you using?
I tried launching the debugger, then opening a new window. No difference.
Thanks for trying.
- Simon
Ramanand wrote:
> Simon,
> Cheers
> Ramanand
> > 10.3.4. I
> > results.
> > perspective.
> > the stack etc.
> > get any
> > or, better, how
> > to fix it?
> > CDT, however it
> > distributions.
> > - Simon
Re: Variables don't appear while debugging [message #106689 is a reply to message #106622] Thu, 17 June 2004 15:23 Go to previous messageGo to next message
Simon,
Sorry I did not qualify my answer completely. I was using Windows XP
professional so my solution may be a bit of a stretch...
Cheers
Ramanand
> are you using?
> Thanks for trying.
> - Simon
> Ramanand wrote:
> > Simon,
> > Cheers
> > Ramanand
X
> > > 10.3.4. I
> > > results.
> > > perspective.
> > > the stack etc.
cannot
> > > get any
> > > or, better, how
> > > to fix it?
> > > CDT, however it
> > > distributions.
> > > - Simon
Re: Variables don't appear while debugging [message #768690 is a reply to message #106031] Tue, 20 December 2011 11:07 Go to previous message
I had a very similar problem. Make sure the compiler flag -pg is used and the optimization is set to zero for the project and all dependent projects. This worked for me.
Previous Topic:Installation on (K)Ubuntu Linux
Next Topic:Debug view freezes
Current Time: Thu Jul 17 21:27:50 EDT 2025
Powered by FUDForum. Page generated in 0.08671 seconds
