Error Message whenever i close Visual Editor [message #105574] |
Wed, 07 September 2005 15:28  |
I keep getting the following error whenever i close the visual editor.
!ENTRY org.eclipse.ui.workbench 4 2 2005-09-07 14:21:22.00
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.ui.workbench".
!STACK 0
org.eclipse.ve.internal.cde.core.EditDomain.setPaletteViewer (EditDomain.java:79)
org.eclipse.gef.ui.views.palette.PaletteViewerPage.dispose(P aletteViewerPage.java:73)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$CustomPalettePage.dispose(JavaVisualEditorPart.java :2531)
org.eclipse.gef.ui.views.palette.PaletteView.doDestroyPage(P aletteView.java:74)
at org.eclipse.ui.part.PageBookView.removePage(PageBookView.jav a:718)
at org.eclipse.ui.part.PageBookView.partClosed(PageBookView.jav a:644)
org.eclipse.ui.internal.PartListenerList$3.run(PartListenerL ist.java:102)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1044)
at org.eclipse.core.runtime.Platform.run(Platform.java:783)
org.eclipse.ui.internal.PartListenerList.fireEvent(PartListe nerList.java:58)
org.eclipse.ui.internal.PartListenerList.firePartClosed(Part ListenerList.java:100)
org.eclipse.ui.internal.PartService.firePartClosed(PartServi ce.java:100)
org.eclipse.ui.internal.WorkbenchPagePartList.firePartClosed (WorkbenchPagePartList.java:38)
at org.eclipse.ui.internal.PartList.partClosed(PartList.java:21 2)
at org.eclipse.ui.internal.PartList.removePart(PartList.java:14 7)
org.eclipse.ui.internal.WorkbenchPage.disposePart(WorkbenchP age.java:1431)
org.eclipse.ui.internal.WorkbenchPage.handleDeferredEvents(W orkbenchPage.java:1259)
org.eclipse.ui.internal.WorkbenchPage.deferUpdates(Workbench Page.java:1243)
org.eclipse.ui.internal.WorkbenchPage.closeEditors(Workbench Page.java:1217)
org.eclipse.ui.internal.WorkbenchPage.closeAllEditors(Workbe nchPage.java:1028)
at org.eclipse.ui.internal.WorkbenchPage.dispose(WorkbenchPage. java:1479)
org.eclipse.ui.internal.WorkbenchWindow.closeAllPages(Workbe nchWindow.java:763)
org.eclipse.ui.internal.WorkbenchWindow.hardClose(WorkbenchW indow.java:1392)
org.eclipse.ui.internal.WorkbenchWindow.busyClose(WorkbenchW indow.java:646)
org.eclipse.ui.internal.WorkbenchWindow.access$0(WorkbenchWi ndow.java:627)
at org.eclipse.ui.internal.WorkbenchWindow$2.run(WorkbenchWindo w.java:728)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at org.eclipse.ui.internal.WorkbenchWindow.close(WorkbenchWindo w.java:726)
at org.eclipse.jface.window.WindowManager.close(WindowManager.j ava:108)
at org.eclipse.ui.internal.Workbench$11.run(Workbench.java:588)
at org.eclipse.ui.internal.Workbench.busyClose(Workbench.java:5 85)
at org.eclipse.ui.internal.Workbench.access$8(Workbench.java:52 2)
at org.eclipse.ui.internal.Workbench$13.run(Workbench.java:713)
at org.eclipse.ui.internal.Workbench.close(Workbench.java:711)
at org.eclipse.ui.internal.Workbench.close(Workbench.java:686)
org.eclipse.ui.internal.WorkbenchWindow.busyClose(WorkbenchW indow.java:643)
at org.eclipse.jface.window.Window.handleShellCloseEvent(Window .java:727)
at org.eclipse.jface.window.Window$3.shellClosed(Window.java:67 4)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:159)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:867)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:852)
at org.eclipse.swt.widgets.Decorations.closeWidget(Decorations. java:257)
at org.eclipse.swt.widgets.Decorations.WM_CLOSE(Decorations.jav a:1649)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3040 )
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.j ava:1582)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:3706 )
at org.eclipse.swt.internal.win32.OS.DefWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.DefWindowProc(OS.java:1651 )
at org.eclipse.swt.widgets.Shell.callWindowProc(Shell.java:410)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3123 )
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:16 56)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2711)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
FUDForum. Page generated in 0.06663 seconds
